Old 09-07-2022, 05:46 AM   #23829
Kaotic Lazagna
Drives: GR Corolla
Originally Posted by Busybee View Post
Thats Great! Was just a regular 60K maintenance or any signs for the sparks.
Does it need mechanic skills or could an average person do the task. Asking causes coming close (53K)
Just the maintenance schedule. Car didn't really feel any different, but my mpg was down. However, that was also harder to tell since I'm mainly doing city street driving now. I'm still on the same tank as before replacing the spark plugs, and the current average mpg has gone up a little, so I'm pretty sure the new spark plugs are helping.
I'll say this job needs more patience than anything else. As long as you know how to use the hand tools required, I think you should be able to DIY.
The Following 2 Users Say Thank You to Kaotic Lazagna For This Useful Post:
Busybee (09-08-2022), soundman98 (09-07-2022)
Old 09-07-2022, 05:48 AM   #23830
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Originally Posted by keenanok View Post
i bought some used bc racing extreme low coilovers and threw them on yesterday. they look phenomenal, the only problem is that the swift spring rates are 40k and the ride quality is terrible now lol. should i get new springs for the coilovers or just put back my rce yellow lowering springs?
Doesn't really seem worth the hassle to me. You'd be better off selling and putting the extra funds into a set of quality coils. Or just buy some B6 dampers to pair with your yellows.
The Following 2 Users Say Thank You to RToyo86 For This Useful Post:
Dadhawk (09-07-2022), keenanok (09-08-2022)
Old 09-07-2022, 10:30 AM   #23831
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
Originally Posted by Kaotic Lazagna View Post
Finished the right side. Was easier than the left. Total time took about 5 hours. 3ish for the left side, and 2ish for the right.
Which method did you use to do the plugs? (Motor lift, hand jam, fa delete)
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
Old 09-07-2022, 01:03 PM   #23832
Kaotic Lazagna
Drives: GR Corolla
I'll take hand jam for 800. LOL
I ended up removing the left strut tower brace cuz I couldn't get the fuel rail cover/thing off with it on.
I also removed the intake since I dropped the extension into the abyss. That didn't bother me too much since I was going to reinstall my Perrin intake tube anyway.
The Following 3 Users Say Thank You to Kaotic Lazagna For This Useful Post:
new2subaru (09-07-2022), RToyo86 (09-07-2022), Wally86 (09-07-2022)
Old 09-08-2022, 09:00 PM   #23833
orz
orz's Avatar
Drives: Halo
What's in the box?
Putting together a custom 2022 OEM+ GR86/brz Oil Cooler/Regulator kit. I got a sweet discount at a local Subaru dealer at San Bernando, CA so I put spent a lil extra on some nice hoses and adapters. The cooler lines measures 3/8" ID and the manifold measures 5/16" ID.
Oil Cooler Complete: 21311AA220
Oil Cooler Connector stem: 21317AA070
HPS Hose 3/8" ID (3ft)
HPS Hose (90deg) 5/16" ID
Reducer Adaptor 3/8"->5/16"
Subaru Coolant
x4 Worm Clamps ~16mm
x4 Spring Clamps ~16mm
Going to reschedule this install hopefully next week when it's not so hot outside.
orz is offline   Reply With Quote
The Following 3 Users Say Thank You to orz For This Useful Post:
Compelica (09-14-2022), MJones_RB (09-12-2022), Teseo (09-10-2022)
Old 09-10-2022, 12:13 AM   #23834
keenanok
keenanok's Avatar
Drives: 2013 Whiteout FR-S
Switched over to some Solo Werks S1 Coilovers from the BC’s with 40k swift springs, and the ride quality feels amazing! Also, what a wonder what a fresh wash and wax can do!
keenanok is offline   Reply With Quote
The Following 2 Users Say Thank You to keenanok For This Useful Post:
Tcoat (09-10-2022), Wally86 (09-12-2022)
Old 09-10-2022, 04:47 PM   #23835
Teseo
Drives: frs
Subaru Coolant
Those bended hose should make the install a breeze. I struggled with mine but was worth the effort. Oil temps doest spike
The Following 2 Users Say Thank You to Teseo For This Useful Post:
orz (09-10-2022), Wally86 (09-12-2022)
Old 09-14-2022, 04:28 AM   #23836
salotelsingha
Drives: RWE
I really wish it would stop raining. install vidmate get-mobdroapk.com
salotelsingha is offline   Reply With Quote
Old 09-14-2022, 11:22 AM   #23837
Compelica
Compelica's Avatar
Drives: 86 GT
Subaru Coolant
Nice! Any difference between the Forester and GR86 oil cooler units though?
Also, finally got around to servicing my coilovers - fresh oil, new dust boots and bump stops. And finally no more clunks, apparently from the worn spherical collar.
DIY stuff at Compelica Works
Compelica is offline   Reply With Quote
Old 09-14-2022, 01:24 PM   #23838
orz
orz's Avatar
Drives: Halo
Good question! Yes, there's a slight difference in the location of the coolant lines which makes hose management easier to work with the GR86 design. The Forrester measures somewhere around 3/8" ID and 1/2" ID. So you'll need a compatible hose and clamp that won't leak considering it will connect to the manifold lines at smaller ID.
Nice work on the rebuild. Fresh parts are always nice.
The Following User Says Thank You to orz For This Useful Post:
Old 09-21-2022, 07:41 PM   #23839
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Installed a TRD sandwich plate to put a defi oil pressure gauge in.
The Following 8 Users Say Thank You to DarkPira7e For This Useful Post:
jcw99 (09-23-2022), Kaotic Lazagna (09-22-2022), MJones_RB (09-27-2022), RToyo86 (09-23-2022), StraightOuttaCanadaEh (09-22-2022), Teseo (09-24-2022), villainous_frx (09-24-2022), Wally86 (09-27-2022)
Old 09-22-2022, 01:02 PM   #23840
Kaotic Lazagna
Drives: GR Corolla
Gave her a wash and got rid of the rust dust that got on the paint from parking right up against a chain link fence (ended up being super windy and rainy that day).
The Following 10 Users Say Thank You to Kaotic Lazagna For This Useful Post:
Clipdat (04-28-2023), DarkPira7e (09-22-2022), KMA KiCKz (09-23-2022), MJones_RB (09-27-2022), new2subaru (09-23-2022), NLSP (09-23-2022), RToyo86 (09-23-2022), Teseo (09-24-2022), Wally86 (09-27-2022), weederr33 (09-23-2022)
Old 09-22-2022, 01:37 PM   #23841
Qwimby1
Drives: 14 FRS Monogram, 05 Mazdasped Miata
Everything I've read here indicates those units are not sufficient for track. Am I wrong about that?
Qwimby1 is offline   Reply With Quote
Old 09-23-2022, 09:30 AM   #23842
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Purchased Billetworz 500g shift knob from @vfrqqq. My butt dyno says it added 2.57 hp. Feels really nice too.
The Following 5 Users Say Thank You to blsfrs For This Useful Post:
DarkPira7e (09-23-2022), MJones_RB (09-27-2022), Teseo (09-24-2022), vfrqqq (09-23-2022), Wally86 (09-27-2022)
