Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 09-01-2022, 02:15 PM   #463
OkieSnuffBox
Drives: '23 BRZ Limited
Originally Posted by Petah78 View Post
Are you sure about this? I think the referenced 86Speed GR (video above) had mentioned that exact spec which require shaving of the rear fender. There are many documented cases where 17x9, +45 is already a VERY tight fit. 17x9.5, +40 is another 11mm poke from that.
You'll notice I said 245, and he explicitly calls out 255/265 wide tires. Especially the 200TW tires which run WAY wide for their size.
There is only one 245/35/18 200TW option, most go for the Conti ECS or the Yok Apex V601. So there is a slight stretch that clears the inner fender.
Go to the facebook page I mentioned and check out all the pics.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
The Following User Says Thank You to OkieSnuffBox For This Useful Post:
Petah78 (09-01-2022)
Old 09-01-2022, 02:26 PM   #464
patsimca
Drives: 2022 BRZ
So I've been thinking about a track set up.
I refuse to trim fenders and I don't particularly like spacers.
Given the geometry changes from coilovers and rear LCAs, would this theoretically work?
17x8 +35 on 245/40 R17
~2.5* front camber
~1.5* rear camber
patsimca is offline   Reply With Quote
Old 09-01-2022, 10:10 PM   #465
Clott
Clott's Avatar
Drives: 2013 Raven FRS(Sold): Fiesta ST
I have the same wheel, though they are not mounted yet, and from my readings, i am pretty sure they will clear with a 245 without issues. In fact, pretty sure they will clear with just natural rear camber.
There is also this thread that have some pics of the exact setup, though he is running a 225 but it looks like there is plenty of room: https://www*********/threads/simple-...an-build.2847/ Replace ** with GR86 . ORG
Start @ 1:00.
Thank you for the response. I currently am rocking the wheels with 225/40s but want a tad more meat. Just didn't want to worry about the rear if I went up a couple of sizes. I noticed quite a few Track cars in Japan with same size wheels were rocking 235/40s but like you mentioned, those low TW tires run larger.
Clott is offline   Reply With Quote
Old 09-02-2022, 08:21 AM   #466
_____That_-_GUY_____
Drives: 2022 GR86
~2.5* front camber
~1.5* rear camber
Who makes 17x8 +35 wheels? Sounds like a good size.
I feel like this would work, but I don't know personally.
235/40 R17 would be a bit safer.
Might need a bit more camber. 3* front & 2* rear.
_____That_-_GUY_____ is offline   Reply With Quote
Old 09-02-2022, 09:34 AM   #467
dreamwonder
Drives: GR86 2022
For gen2, 245/40/17 is pretty ideal with the criteria of not trimming rear fenders. 235/40/17 is a compromise, go for a offset that works for 245 instead. +42 ish (no less) is good. For example arc8 17x9 +42, or if you want a safer fit, go +45 or even +48 but that is going into the territory of needing front spacers. +35 requires rlca, +42 does not. For a casual track car the natural rear camber regardless of drop height is good enough, usually that comes out to -2.1ish for a 25mm drop. As for front camber, it depends, here is ballpark of what I would do (assuming car is daily 15k a year):
10 track days a year: -2.7
25 track days a year: -3.5
40+ track days a year: -4.2
dreamwonder is offline   Reply With Quote
Old 09-02-2022, 01:14 PM   #468
patsimca
Drives: 2022 BRZ
Rpf1 is available in 17x8 +35 which is ideal for MANY reasons from a track wheel perspective
Appearance (convex instead of concave) is irrelevant to me for a track wheel. Function over form.
I run 245-40 R17 on 17x8 +45 right now on my street setup no issues w the fat tire.
Sent from my Pixel 6 using Tapatalk
Old 09-04-2022, 10:13 PM   #469
rBobby
Drives: 2022 BRZ
Tire fitment issues in the rear
Installed 18x9 +47 Titan7s with 245/35/18 on stock suspension. Rear fits flush and no rubbing. About 3-4mm between front wheels and the strut with a 5mm spacer. Fronts had minor poke, but is now flush after fitting Pedders top hats.
Here is a quick picture over the weekend. Also, added another view since a few others have asked for pictures.
rBobby is offline   Reply With Quote
The Following 2 Users Say Thank You to rBobby For This Useful Post:
Ash_89 (09-13-2022), OkieSnuffBox (09-13-2022)
Old 09-12-2022, 03:53 PM   #470
OkieSnuffBox
We need pics!
Old 09-13-2022, 12:59 PM   #471
Decep
Drives: 2013 FR-S Series 10
Who started using the word fitment when squeezing tires onto a car? Why do we not use it when we are assessing how our pants fit? Or shoes fit? Always been curious. If you look it up it in the dictionary it doesn't seem to mean at all what people use it as.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
Old 09-13-2022, 02:45 PM   #472
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Just slang derived from the term "fit", in its verb state of form meaning "to conform correctly to the shape or size of" according to a dictionary.
So how well a wheel/tire "fits" on the car based on a variety of factors. Some these days even go as far as calling the wheels/tires on their vehicle shoes, which would further fortify the concept you question.
But in reality, the term fitment does not come from the term fit.
Dzmitry is offline   Reply With Quote
Old 09-13-2022, 03:22 PM   #473
OkieSnuffBox
There is no official "verb" form of fitment, that I can find. More just bastardized usage, like people saying "irregardless" when they mean "regardless."
It's a noun that means a fixed piece of furniture, like a cabinet or a piece of machinery.
Dzmitry (09-14-2022)
Old 09-14-2022, 10:18 AM   #474
Dzmitry
Dzmitry's Avatar
I didn't say verb form of fitment, but rather verb form of fit. As I mentioned, fit and fitment are two completely different terms.
Rear wheel alignment issues... HELP! Rambo305kid Issues | Warranty | Recalls / TSB 10 07-05-2020 10:05 PM
Wheel Fitment Issues. Need help. hay_frs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 04-06-2020 06:09 PM
Fitment issues Neal86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 05-07-2019 07:08 PM
Tire/Wheel fitment (rear) rikixass Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 01-17-2018 04:09 PM
Fitment Issues Silp3 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 01-02-2013 03:34 PM
