Drives: 2014 Scion FR-S
'14 FRS cranks but won't turn over
So recently installed radium fuel rails, 300c fuel pump, 900cc fuel injectors, not turbo yet but preemptive for when I do get boosted. Also put on a flex fuel kit and got a delicious tuning ecutek. After all of this was installed there was a couple leaks on the passenger side fuel rail so got that patched up and started it. Got a little bit of white smoke and it stalled out. Started up again but would only run with my foot on the pedal. Recieved a base tune for the flex kit car would not run. Tuner told me to take the fuel injectors & pump out and put the stock back in. Did that and now the car cranks but won't turn over. Ecutek dtcs says no flags. The battery is brand new, no leaks that I can see, and all fuses have been checked. Anybody have any idea where the problem might be?
#2 |
Your "tuner" is probably the issue.
I would revisit the tune before looking for hardware problems.
| The Following User Says Thank You to Tcoat For This Useful Post: | alphasaur (08-23-2022) |
#3 |
It was actually two seals and a hose issue. Just went back through double checking everything I did & all connections. She's running good now.
| The Following 5 Users Say Thank You to BrittBlack For This Useful Post: | alphasaur (08-23-2022), bcj (08-23-2022), soundman98 (08-23-2022), Tcoat (08-23-2022), x808drifter (08-24-2022) |
#4 |
cranks = turn over
turn over < fires < starts
#5 | |
Still have an issue with a tuner that says "Put it back to stock" though. The whole point of having a tuner is to not be stock.
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | soundman98 (08-23-2022), Ultramaroon (08-23-2022) |
| Cranks but won't fire | tzbang | Scion FR-S / Toyota 86 GT86 General Forum | 30 | 03-18-2025 11:41 AM |
| 2013 Scion FR-S cranks but no start!!! | Btborja | Issues | Warranty | Recalls / TSB | 43 | 10-29-2023 09:30 PM |
| HELP! Cranks but won't start P0102 P0113 | Sum10clever | Issues | Warranty | Recalls / TSB | 2 | 09-05-2020 11:46 PM |
| Car cranks but wont start | yablonskiy11 | Issues | Warranty | Recalls / TSB | 15 | 01-02-2019 12:18 PM |
| It cranks but won't turnover | daironchef | Forced Induction | 2 | 05-31-2016 09:40 AM |
