Old 05-30-2016, 04:00 PM   #1
daironchef
Drives:
It cranks but won't turnover
Hi, just want to see if anyone can shine some lights here, been running with my turbo for more than half a year everything check out fine. One morning it wouldn't start, seems like its starving for fuel, the fuel line is getting pressure, so not the fuel pump. Not my aftermarket autostart/alarm bypass because if its that it won't even crank. anyone want to put in their $0.02?
Sent from my Nexus 6P using Tapatalk
daironchef is offline   Reply With Quote
Old 05-30-2016, 04:36 PM   #2
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
check for bad ground. I had a badly ground out ECU after doing some maintenance work and the car would fire once or twice and then sputter out. Once I fixed the ground I was good to go.
Old 05-31-2016, 09:40 AM   #3
Ashikabi
Ashikabi's Avatar
Fuel filter? Shouldn't have pressure then right? Which set of injectors turns over the engine on startup?
Early problems - speaker rasp and long turnover Hawaiian Issues | Warranty | Recalls / TSB 44 08-30-2013 04:39 PM
