Old 08-22-2022, 04:45 PM   #1
Master Jedi
Drives: gr86
Changing the door panel insert to blue.
Here is the write up:
www.
gr86 . org
/threads/changing-the-insert-color.3088/page-3#post-60550
Removed the door panel per these instructions
Remove insert
Notice that all the screws are removed and I still have the pressed/melted fasteners For the melted tabs, drill out the center to 1/8inch depth and use a razor blade and cut under the insulation and shave it off so the black ring that is left by the drill and cut it and go by 14x1/2 or 1/4 in Phillips screws ( purple circles ) this will allow you to screw it back on like stock and is clean after.
Then remove the insert
Once the insert is removed wipe down with light soap and water and dry off
Then pull back the edge or the material with the backing only about 3-4 inch off and gradually and evenly apply the material to the insert.
Once the material is firmly in place turn over and cut excess off and remember to leave a little extra to wrap behind
Reinstall the insert, now with the holes you drilled take those 14 by 1/2 inch Phillips screws and screw in where you drilled out the metaled tabs.
once all the screws are back in re-install the door panel
Not hard and can be returned back to stock in 40 min.
Master Jedi is offline   Reply With Quote
The Following 4 Users Say Thank You to Master Jedi For This Useful Post:
Ash_89 (08-27-2022), Dzmitry (08-31-2022), JusTheG (08-23-2022), MyHybridBurnsGasAndTires (08-23-2022)
Old 08-22-2022, 05:27 PM   #2
Rustyoid
Drives: 2022 GR86
WOW that looks really good. I'd do the upper door panel and cluster bezel as well, ALL the alcantara!
Rustyoid is offline   Reply With Quote
The Following 2 Users Say Thank You to Rustyoid For This Useful Post:
Dzmitry (08-31-2022), Master Jedi (08-22-2022)
Old 08-22-2022, 07:08 PM   #3
Spektyr
Drives: GR86
Link is broken.
Spektyr is offline   Reply With Quote
The Following User Says Thank You to Spektyr For This Useful Post:
dawsonj87 (08-23-2022)
Old 08-22-2022, 07:19 PM   #4
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
You dont want color on the cluster hood for visibility reasons. It reflects on the inside of the windshield and hampers vision, that's why dash flock exists.
The Following 2 Users Say Thank You to RZNT4R For This Useful Post:
soundman98 (08-22-2022), Tcoat (08-22-2022)
Old 08-22-2022, 07:33 PM   #5
Beat me to it! I had a buddy do his dash in black and grey carbon fiber and as soon as the sun was bright it turned into an horrible checkerboard HUD on the windshield.
Dadhawk (08-23-2022), soundman98 (08-22-2022)
Old 08-23-2022, 12:58 AM   #6
Drives: what
MyHybridBurnsGasAndTires is offline   Reply With Quote
The Following User Says Thank You to MyHybridBurnsGasAndTires For This Useful Post:
soundman98 (08-23-2022)
Old 08-23-2022, 09:36 AM   #7
dawsonj87
dawsonj87's Avatar
Drives: 2023 GR86 Base MT
Originally Posted by Spektyr View Post
Link is broken.
The link is from *********. Tried linking to it myself and the same thing happens when you hit post. Where the **** is in the link, replace it with ********* and it should come up.
Alright then, this site is being a real pain. G R 8 6 . o r g.
dawsonj87 is offline   Reply With Quote
The Following 2 Users Say Thank You to dawsonj87 For This Useful Post:
Master Jedi (08-23-2022), soundman98 (08-23-2022)
Old 08-23-2022, 10:49 AM   #8
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
One of my old shop guys was telling me years ago his dad sprayed clear on the dash of his sisters car to make it look better, he said it was impossible to drive in the summer
OP: Looks good, but.......
Old 08-23-2022, 11:19 AM   #9
Master Jedi
Drives: gr86
Instructions and more pictures added
Old 08-23-2022, 11:38 AM   #10
VoltsFRS2013
VoltsFRS2013's Avatar
Drives: 2022' GR86 Premium 6MT
This looks pretty straightforward and honestly OEM+
I might have to find some material that closely matches what already comes on the door and knock it out.
22' Toyota GR86 - Trueno Blue - M/T (CURRENT)
18' Toyota 86 GT Black - Moonslate Gray - M/T (SOLD)
13' Scion FRS - Ultramarine - A/T (SOLD)
VoltsFRS2013 is offline   Reply With Quote
Old 08-23-2022, 02:21 PM   #11
Spektyr
Drives: GR86
OEM+ is exactly the kind of thing I like in mods. I'm kicking around the idea of doing this in black or dark blue on a Trueno GR86. Not completely sold on the idea, but it's growing on me (particularly since it's easy to undo and provides some protection to the original interior parts). If I end up doing it, I'll probably do some Dynamat while I have it apart.
My goal with any custom work on a car is to go for that "what if Toyota/etc. had offered a trim level above and beyond?" question. This is that. Not gaudy, not flashy, just an extra touch that fits the existing aesthetic.
Old 08-23-2022, 02:46 PM   #12
Master Jedi
Drives: gr86
Right! I like the OEM+ look, I'm right there with you. " if Toyota had done this would it look like this"
Old 08-23-2022, 02:48 PM   #13
Master Jedi
Drives: gr86
I wanted that as well, but I found that the fake leather rolls that had the adhesive backing wouldn't stretch to accommodate the bends needed to look clean. If you find some I might change it out. LOL
The Following User Says Thank You to Master Jedi For This Useful Post:
VoltsFRS2013 (08-23-2022)
Old 08-26-2022, 07:23 PM   #14
Stephen02
Stephen02's Avatar
Drives: 2013 Manual Trans FR-S
This is more subtle but it reminds me a lot of the colored interiors that Honda did with the S2k.
Stephen02 is offline   Reply With Quote
Door panel sagging. 86Craze Scion FR-S / Toyota 86 GT86 General Forum 12 10-03-2017 06:52 PM
****---> wtb door panel WATCHMEHEAL Want-To-Buy Requests 0 07-30-2014 11:58 PM
Changing out the door/courtesy lights - problem mikalem Cosmetic Modification (Interior/Exterior/Lighting) 19 02-10-2014 08:39 AM
How to remove door panel? Mo707 DIY (Do-It-Yourself) Guides 3 02-19-2013 11:35 AM
