Old 08-22-2022, 03:18 AM   #15
AussieBRZ
AussieBRZ's Avatar
Drives: WRB BRZ
Originally Posted by Hydropkd View Post
Oh, yea it's 4k in every gear and if you don't change gears it will die and the tach gets stuck on 4k
Ok definitly sounds like limp mode, however that mode is usually trigfered by a fault in one or more of the cars systems and that generally trigfers some error codes in ECU and some dash lights like trac/vsc steering or CEL
if you got none of those lights im guessing is due to a tuje feature like launch or flat foot shift triggering or the tune itself has a rev limit mode that active, hence no associated cel lights
AussieBRZ is offline   Reply With Quote
The Following User Says Thank You to AussieBRZ For This Useful Post:
Hydropkd (04-16-2023)
Old 08-22-2022, 11:09 AM   #16
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
My tuner, unbeknownst to me, enabled flat foot shifting. When driving, engine would not rev. Sometimes 4500, sometimes 5500. Data logs showed the ign timing would drop to 0* It was fine at lower rpms and it worked perfectly when the tuner drove it.
@AussieBRZ may be on the right track. Another Aussie genius, @steve99, suggested fft was enabled. The next time I drove the car, I noticed that I would unconsciously, very lightly, rest my foot on the clutch before shifting. When I kept my foot off the pedal, it revved to 7300. The tuner disabled fft and my car and I are living happily ever after.
The disable switch is very sensitive. It will turn off the cruise control with even the slightest pressure on the clutch.
Check that you are not touching the clutch. If that's ruled out check the clutch pedal switch.
The Following 2 Users Say Thank You to blsfrs For This Useful Post:
Hydropkd (04-16-2023), soundman98 (08-22-2022)
Old 08-22-2022, 10:05 PM   #17
Hydropkd
Drives: 2013 frs
No change in tach when pulling back the cruise switch
Hydropkd is offline   Reply With Quote
Old 08-23-2022, 11:37 AM   #18
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
That is pretty odd, everything on a pre-facelift car should interchange. Does it run fine otherwise?
Without being able to see the live data, I don't think we are going to be able to help. You need a shop with a way to look at the live data via something like techstream.
Old 08-23-2022, 06:58 PM   #19
Hydropkd
Drives: 2013 frs
Runs fine otherwise, seeing what I can do about a data log, will post it when I get it
Old 08-23-2022, 06:59 PM   #20
Hydropkd
Drives: 2013 frs
Would a bad o2 sensor do what I have without a code?
Old 08-23-2022, 07:44 PM   #21
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Not likely.
Old 08-23-2022, 08:04 PM   #22
clio
Drives: 2013 Subaru BRZ
Did you change the crank reluctor wheel?
clio is offline   Reply With Quote
The Following User Says Thank You to clio For This Useful Post:
Old 08-23-2022, 08:34 PM   #23
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It's the same on pre facelift cars. Didn't change until 17'+. The early cars can't read the facelift reluctor and vise vera.
Old 08-23-2022, 11:36 PM   #24
clio
Oh right - thanks for clarifying
Old 09-06-2022, 10:52 PM   #25
Hydropkd
Drives: 2013 frs
Changed fuel injectors and spark plugs, and o2 sensor. Here is a log.
Old 09-07-2022, 10:14 AM   #26
blsfrs
blsfrs's Avatar
You might want to switch your log to Datazap.me.
The Following User Says Thank You to blsfrs For This Useful Post:
Old 04-16-2023, 10:13 PM   #27
Hydropkd
Drives: 2013 frs
https://datazap.me/u/hydropkd/log-16...g=0&data=24-41
Old 04-16-2023, 10:16 PM   #28
Hydropkd
Drives: 2013 frs
So we have still not got anywhere on this thing, found that techstream says that it needs an ecu update. Took it to dealer they said it needed it but it kept failing when they were trying to do it. Found in one of these posts that supposedly the ecu writes exhaust cam gear info on initial startup after reflash. If that's so do you guys think that my car is looking for the old cam gears?
2017 fa20 engine into 2013 car? ROADRACER Engine, Exhaust, Transmission 91 12-29-2021 12:52 AM
FS: Engine- 2015 BRZ FA20 56k miles FT86Logic Engine, Exhaust, Bolt-Ons 1 08-10-2018 08:07 AM
FS: 2013 FA20 engine w/spun bearing Bullnettles Engine, Exhaust, Bolt-Ons 9 04-05-2017 07:39 PM
FA20 Engine Wins Ward's 10 Best Engines of 2013 Jeffsu350 Scion FR-S / Toyota 86 GT86 General Forum 111 03-15-2015 04:39 AM
