08-20-2022, 12:44 AM | #43 | |
Sr. Spiritual Advisor
Drives: 2023 BRZ Premium
I'm keeping the engine stock for sure, so I guess not much need for anything beyond 255-mm-wide. Speaking of tires, Apex has just released +48 offset 17x9 fitment for rear! https://www.apexraceparts.com/store/...brz-wheel.html Sooner or later, I'll have to buy another set for spare tires. Perhaps this would be it : )
'23 Subaru BRZ Premium Manual (Track Build Thread)
'22 Ford F150 Lariat Powerboost SuperCrew 6'5" 4x4 '21 Tesla Y Long Range AWD '19 Corvette Z06 Z07 (Track Build Thread) |
The Following User Says Thank You to X25 For This Useful Post: | whataboutbob (08-20-2022) |
08-20-2022, 01:25 PM | #44 | |
Drives: Frs
Ridiculous!
08-21-2022, 10:49 PM | #45 | |
Drives: Blue BRZ
I am asking because I am debating between these two fitments. Thank you! |
08-22-2022, 12:10 AM | #46 |
There's a long discussion that you might have also seen under 22+ BRZ section, and they mention change in the rear design, making the ideal offset higher. This pretty much means +42 will be more likely to rub in the rear on the outside, and we're not maximizing fitment clearances like a +48 would.
If available, I'd prefer a +48, and we'll see if +42 will rub or require an aggressive roll.
The Following User Says Thank You to X25 For This Useful Post: | Krokodil (08-22-2022) |
08-22-2022, 02:04 AM | #47 |
Drives: Blue BRZ
By the way
I run into same problem with Cusco rear arms. Looks like a bad design. Raced x arms look better |
08-22-2022, 02:16 AM | #48 | |
https://racerxfabrication.com/frs-br...r-control-arms I'll keep an eye on it, and if it ever moves again, I have an idea on how to secure it (nord lock??).
08-22-2022, 02:38 AM | #49 | |
Drives: Blue BRZ
And it cost more. That is why I got Cusco. Now had to keep eye on Cusco. |
08-22-2022, 11:04 AM | #50 | |
Drives: 2023 BRZ
Check out the Apex Race Parts fitment guide. It's great. I ordered the 48 offset for all four corners. Then in the front I ordered spacers. One set of 10mm and two sets of 3mm. This will allow me to dial in just the right clearance all around while still using a square wheel and tire package. I'd rather not deal with spacers if I don't have to, but if I want a square wheel and tire package using 245mm tires, yet would prefer not to trim the fender on my brand new car, this is really the best option. CSG Mike and Apex suggested this route. I won't have my car until January(ish) to confirm.
Director of Rocky Mountain 86CUP
08-22-2022, 11:47 AM | #51 |
I'd personally just get the +35 for fronts to stay optimal. You'll likely need longer studs with +13mm spacer, and even then, your lugs will be leveraged much more; why bother? : ) The tires last much longer on this platform as well; I'd not worry about it..
I have a fender roller, and will roll it a bit for clearance. Even then, I'd much rather use the +48s, but it was not available when I ordered them. Of course, what tire you put in also makes a difference.
08-22-2022, 12:20 PM | #52 | |
Drives: GR86 2022
08-22-2022, 02:39 PM | #53 | |
Drives: 2023 BRZ
I ordered longer studs, too. Are you sure there is more leverage on the longer studs? I thought they only provided a pulling force on the wheel, and the wheel/hub interface supported the vertical load as long as the lug nuts were tight. And regarding tire life...well, that depends greatly on one's use case, doesn't it?
08-22-2022, 02:49 PM | #54 |
Wheel's backface is mated with the hub's (rotor's) face directly, and nothing else is engaging for vertical load. Your stud will have a much longer moment arm (the point of mount of the stud on the hub vs. where the back surface of wheel starts and jerks the stud up and down as it hits stuff). Considering we don't hear failures, it should be fine, but it's definitely more leveraged now.
Since I have to deal with 345 wide tires at the rear of my other track car, everything feels very cheap in terms of tire options on this car. I'd be OK to leave a little bit of rubber life on the table : ))
08-22-2022, 03:17 PM | #55 |
Drives: Blue BRZ
I also calculated a need for 13mm spacer in front for 17x9 with 245 tire.
Surprisingly there are no 13mm hubcentric spacers for Subaru available. Really do not want to go sandwich of spacers route. |
08-22-2022, 03:19 PM | #56 |
Drives: Blue BRZ
Extended ARP studs was my first mod.
Similar Threads | ||||
$5K for track build | Kulebrero1 | Tracking / Autocross / HPDE / Drifting | 27 | 05-08-2022 09:51 PM |
GT86 CS V3 track car manual | ayau | Tracking / Autocross / HPDE / Drifting | 12 | 08-20-2013 11:03 PM |
White GT manual Jan Build availlable | 86•BRZ | AUSTRALIA | 2 | 01-01-2013 11:45 PM |
Black GTS Manual Nov/Dec build in ACT | FT86RR | Australia Classifieds | 1 | 08-23-2012 10:55 AM |
4/30 Build sheets for Manual and Auto FR-s | MrFRsLa | Scion FR-S / Toyota 86 GT86 General Forum | 0 | 04-30-2012 05:26 PM |
