Old 08-14-2022, 10:18 AM   #15
jflogerzi
jflogerzi's Avatar
Originally Posted by Icecreamtruk View Post
Buy a wing, build a splitter. Most of the shelf splitter are non functional or barely functional. Why? Main concern with those pieces is ground clearance, easy of install, no drilling holes, and looking pretty. Function is nowhere near the top of those priorities. Its almost always the same with wings, its just a lot easier to have a wing that is functional and looks pretty and install easily. Splitters are very height sensity and need very high rigidity to avoid bending underload and starving the underbody of air. Check profesionnaly awesome's page, they have a whole section dedicated to that and explains the mains dos and donts regarding building a splitter and other downforce generating devices.
I would wait for verus's front splitter. It's the mounting that makes or breaks a splitter. I just installed there 2 piece splitter with race upgrade. The combination of how it's mounted to the bumper and supported by 2 splitter arms which are mounted to the crash beam makes it's super ridged. There is no flex and I can even stand on it
Sent from my Pixel 6 using Tapatalk
2013 Series 10 FRS #553
Old 08-14-2022, 11:28 AM   #16
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The mounting on the two piece Verus unit isn’t that good. I built a bracket for mine that bolts to the lower rad support and it’s much stouter. I’ve still broken it twice and it always seems to get warped, it’s getting tossed for a homemade splitter this winter.
DocWalt (08-17-2022)
Old 08-14-2022, 02:53 PM   #17
jflogerzi
jflogerzi's Avatar
Did you have the race upgrade?
Old 08-14-2022, 02:57 PM   #18
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Yes. There is not enough support at the rear is the main issue I see so it hinges on the splitter rods. I also made a plate that mounts the halves together more solidly. In the end, with the amount of wing I have it isn't enough splitter anyway.
jflogerzi (08-14-2022)
Old 08-14-2022, 05:43 PM   #19
jflogerzi
jflogerzi's Avatar
Well that sucks! Keep me posted. What part of the rear? Closer to the edge or more in the center?
Old 08-14-2022, 05:47 PM   #20
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It's pretty much the whole back edge needs better support. Mounting to the bumper cover isn't that solid and the rear mounts that go under towards the back just are not enough to handle an off into the grass or a light curb strike. I supported it with a bracket about 8" across in the middle and mounted the splitter to that support and that support to the lower rad mount.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
DocWalt (08-17-2022), jflogerzi (08-14-2022)
Old 08-14-2022, 06:04 PM   #21
jflogerzi
jflogerzi's Avatar
Thank you for this info. Can you snap some photos?
Old 08-14-2022, 06:55 PM   #22
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I will try to.
norcalpb (08-14-2022)
Old 08-14-2022, 07:10 PM   #23
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
For my side splitters (2.0), I used 1/4" composite aluminum that I bought directly from Falken Design. There prices were good and their shipping was fast. Good source of material for the DIY crowd.
The Following 2 Users Say Thank You to blsfrs For This Useful Post:
NoHaveMSG (08-14-2022), norcalpb (08-14-2022)
Old 08-14-2022, 07:38 PM   #24
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Verus often does different versions DD depending on BRZ or FRS in the past if it warrants it. I really like my street defuser on 1st gen FRS. Mounting is really sturdy
I have a message in to them already. I don't know if they verified for BRZ, but I'm not too far south from them.
dragoontwo is online now   Reply With Quote
Old 08-14-2022, 11:15 PM   #25
jflogerzi
jflogerzi's Avatar
I will try to.
no rush to be honest. I am wondering if they will sell me the Mounting hardware from there adjustable splitter that ties into edge support and if it would work with the 2 piece.
Old 08-15-2022, 12:44 PM   #26
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Good to know. I ordered a sheet of alumalite last year and after months of waiting I was refunded my order. I will have to try those guys. It was tough to get for a while.
I would imagine it would fit. If you do notice that the rear part of the splitter is sagging get it off the car and fixed ASAP or it will start to warp it. I had to heat mine up and park the box truck on it over a weekend to get it somewhat flat again.
blsfrs (08-15-2022), jflogerzi (08-15-2022)
Old 08-15-2022, 02:41 PM   #27
Icecreamtruk
Drives: Track preped NA FRS
I find that to be the easy part. It takes me about a week to build a splitter (between the design, cutting and sanding the core, layup layers + dry time and then surface finish), but I can mount it to the car in an afternoon and that includes the time taken to go to a hardware store to get supplies.
Also, I dont mount the splitter to the bumper. I mount it to the chassis, the bumper just happens to be above the splitter, resting on it. I assume anyone building a splitter would do the same.
Icecreamtruk is offline   Reply With Quote
The Following 3 Users Say Thank You to Icecreamtruk For This Useful Post:
DocWalt (08-17-2022), jflogerzi (08-15-2022), NoHaveMSG (08-15-2022)
Old 08-19-2022, 03:37 PM   #28
dragoontwo
dragoontwo's Avatar
What's in the box?
The Following User Says Thank You to dragoontwo For This Useful Post:
norcalpb (08-19-2022)
2022+ BRZ/GR86 specific oil cooler options CSG Mike Tracking / Autocross / HPDE / Drifting 0 07-26-2022 08:25 PM
GR86 In R7 of the Toyota Gazoo Racing GT Cup + GR86 coming to Grand Turismo Sport Blighty GR86 General Topics (2nd Gen 2022+ Toyota 86) 37 07-18-2021 04:38 PM
Downforce for an FR-S? HachiRo Cosmetic Modification (Interior/Exterior/Lighting) 40 08-26-2014 11:24 PM
Scion FR-S options:what options did you have dealer installed? Scionshaun Scion FR-S / Toyota 86 GT86 General Forum 42 01-06-2014 02:35 AM
Bushing upgrades, geometry options and other component options? der_rainman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-26-2013 01:53 PM
