Old 08-17-2017, 02:49 AM   #15
Hags86
Drives: Toyota GTS 86
I've confirmed this.
The Oil Pressure Switch is a 1/8" BSPT (tapered 28 threads per inch fitting).
NPT is 27 threads per inch.
I had to measure it with a thread gauge 10 times before I was certain it was 28TPI as they are so close it was very hard to tell. Given I could barely tell the difference I'd reckon you could probably jam a 1/8 NPT 27TPI fitting in there and it would seal. However it is definitely a 28TPI BSPT fitting.
Hags86 is offline   Reply With Quote
Old 08-20-2017, 05:43 PM   #16
LS1M
Drives: 2015 BRZ
I can vouch for the vs BSPT vs NPT thing. I originally threaded a 1/8" NPT fitting in there, started the engine, and sprayed oil all over the place. Lost probably a half-quart before I shut it down.
LS1M is offline   Reply With Quote
Old 08-10-2022, 04:59 AM   #17
ballsdeep
ballsdeep's Avatar
Drives: Ocho-Seis
Can anyone confirm the thread size of the oil temp sensor? It is bigger than the oil pressure sensor's 1/8PT.
Is it M12*1.5 or 1/4PT or?
ballsdeep is offline   Reply With Quote
Old 08-10-2022, 11:43 PM   #18
jeepmor
Drives: 84 CJ7, 08 Duramax, 2014 FRS
Note to self, buy a oil filter stacking setup for this.
jeepmor is offline   Reply With Quote
Old 08-11-2022, 09:25 AM   #19
KillerBMotorsport
KillerBMotorsport's Avatar
Originally Posted by @Art_Mighty View Post
Hello!
Does anybody know what metric threads the oil pressure switch and temp sensor uses? I'm trying to buy the right T-fitting to install an oil temp guage
Thanks!
Oil Pressure Switch is 1/8PT (BSPT)
Oil Temp is M10 x 1.25, but you don't want to Tee and take oil temps there. The better route is to get a Pan Drain Bolt Adapter. This will give you much better penetration into the oil vs a Tee that would be in stagnant oil.
We do offer a dual 1/8PT of you're looking to add oil pressure and retain the OEM pressure switch. It's made from billet Stainless and far stronger than a brass Tee.
[IMG]https://killerbmotorsports.sharepoint.com/:i:/g/EW8iyA88185Fn9bQkSs-eRkBkeMmT***1r8kDdUPcAsb0w?e=2CGSlN[/IMG]
We do have a drain plug adapter for the 2022+ BRZ/GR with 1/8 PT for oil temp sensors.
KillerBMotorsport is offline   Reply With Quote
The Following 2 Users Say Thank You to KillerBMotorsport For This Useful Post:
ballsdeep (08-11-2022), raisingAnarchy (08-11-2022)
Old 08-19-2022, 03:01 AM   #20
villainous_frx
Off to the track!
villainous_frx's Avatar
Drives: '14 Lava 86, '13 WRB BRZ
Originally Posted by KillerBMotorsport View Post
We do not yet have a drain plug adapter for the 2022+ BRZ/GR, but it is coming. Although... most temp sensors come in 1/8PT configuration which is we're planning to add unless the market demands otherwise.
Would this not work? M16x1.5 is the Gen1 drain plug fitment, and I would assume that carries over to Gen2.
https://www.killerbmotorsport.net/m1...t-adapter.html
villainous_frx is offline   Reply With Quote
Old 08-19-2022, 04:09 PM   #21
KillerBMotorsport
I'm going to say my coffee had not kicked in yet, because you're absolutely right. Thank you for catching that! I will update my previous post.
The Following User Says Thank You to KillerBMotorsport For This Useful Post:
villainous_frx (08-20-2022)
Old 09-03-2022, 03:51 PM   #22
orz
orz's Avatar
Drives: Halo
Here's the setup I used.
For Oil Pres/temp
For Water Temp 1/8pt fitting
orz is offline   Reply With Quote
OpenFlash Tablet: Tire pressure/Temp display? Shiv@Openflash Software Tuning 52 03-09-2018 02:26 AM
Oil Pressure and Temp Gauge Install BokChoiTV Cosmetic Modification (Interior/Exterior/Lighting) 14 12-29-2015 07:19 PM
Installing oil pressure/temp probes xwd Engine, Exhaust, Transmission 12 03-14-2015 01:07 AM
Anyone run Tyredog pressure/temp monitors? Thorpedo Tracking / Autocross / HPDE / Drifting 11 01-23-2015 02:51 AM
Stock clutch+flywheel+pressure plate+ ACT lightweight flywheel & pressure plate PineappleFriedRice Transmission and Driveline 0 11-08-2013 05:54 PM
