Old 08-13-2022, 09:53 AM   #15
JD001
JD001's Avatar
Drives: Subaru BRZ
Originally Posted by LRNAD90 View Post
And are the first that I've seen to talk about power delivery differences ..
@Tcoat photobombing again!!
Old 08-13-2022, 11:08 AM   #16
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Nice review.
Old 08-13-2022, 11:57 AM   #17
PulsarBeeerz
Drives: JRSC BRZ SOLD
Originally Posted by jeepmor View Post
Same as before, Scion/86 more twitchy than the BRZ. And only 23 more horsepower, Weak. Still, these models and a boost package, those extra cc's come in handy for sure.
Also, wonder how much the ECU tuning is controlling the torque dip, is that entirely addressable at the tune level to make them all linear and upward like normal torque/hp profiles.
I do like the reports of a stiffer chassis too.
23hp? Have you not see any of the dyno's of the 2Gen? They were underrated regularly dynoing 40-50whp more. The torque dip, like the 1Gen cannot be resolved with tuning. It take a hardware change to the exhaust.
PulsarBeeerz is offline   Reply With Quote
Old 08-14-2022, 08:23 PM   #18
drift86
Drives: GT86, 22 BRZ
These guys should learn the difference between 'power delivery' and 'throttle tuning'...
drift86 is offline   Reply With Quote
Old 08-15-2022, 12:34 AM   #19
DriveDriftDogfight86
Drives: '23 BRZ Limited 6MT; '13 FR-S 6MT
As someone who is leaning more towards the second-gen BRZ, hearing that it behaves like the first-gen and they wouldn’t buy it while the GR86 “feels faster” pissed me off. I’m already ticked that the BRZ doesn’t display exact oil temp numbers like the GR86. Now I’m gonna have to hunt down a 2022 BRZ on Turo to make sure it’s power delivery is as good as the GR86 I drove. I wanna call BS on that segment, but hopefully at some point I can compare both of them for myself.
DriveDriftDogfight86 is offline   Reply With Quote
Old 08-15-2022, 01:19 AM   #20
ravenwrx
Drives: 2018 brz
I currently own a 2018 BRZ and a 2022 BRZ (drive them back to back regularly). I would disagree with some parts of the review. The steering feel and weight of the 2018 BRZ is better and way heavier than the 2022. The 2022 is super light in comparison although on track I don't mind it at all. The throttle pedal in the 2018 BRZ is tuned just like the 2022 GR86. Push the gas pedal down 40% strength and the engine gets 100% power. The 2022 BRZ push the gas pedal down 40% strength and the engine gets 40% power, its really that simple. When I jump in the 2022 BRZ from driving the 2018 I have to recalibrate my foot as the throttle mapping is way different. I have driven the 2022 gr86 and my 2022 BRZ back to back and can say that when you give the gas pedal 100% throttle on both cars they pull the exact same. Hope this helps.
ravenwrx is offline   Reply With Quote
Old 08-15-2022, 10:32 AM   #21
chipmunk
Drives: _
Turning the Traction Control off, or switching to Sport mode changes the throttle mapping on Gen 1 BRZs. So in this test video, was the BRZ tested with all aids on? Or did they turn them off?
chipmunk is offline   Reply With Quote
Old 08-15-2022, 05:51 PM   #22
OkieSnuffBox
I've never understood this line of reasoning. "Heavy steering feel" isn't necessarily better. As long as I can tell what the front is doing, I don't need an upper body workout out every time I drive a car.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
Old 08-15-2022, 06:20 PM   #23
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Where did you learn this? I don't recall there being any difference in throttle mapping. Just TCS and VSC intervention.
Old 08-16-2022, 06:13 AM   #24
chipmunk
Drives: _
From the feel of the foot. Turning TC off always made the engine sound raspier. Not just pressing the TC button once, but press+hold for 5 sec. There was a more direct response to input when it was turned off, especially when climbing uphills at low speeds - like driving up a steep driveway.
Old 08-18-2022, 02:45 AM   #25
benzz280
Drives: Toyota 86
Exactly said, throttle response is tuned differently between them as echoed by this video as well:
benzz280 is offline   Reply With Quote
Old 08-18-2022, 09:58 AM   #26
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
That was very interesting, thanks for posting. For those that didn't watch, he drives the GR86 on track with both the PS4 215s and PS 235s, says the latter make the car a little more stable.
I'd love to go 235s in a PS A/S4 - hopefully the greater tire width would compensate for the slightly less grippy nature of the A/S tire and I'd have a car with about the same grip characteristics as stock but a) better looks (I find the stock tires look too skinny) and b) no need to swap on winter tires (I won't be driving this in snow of any significance). Oh also c) better protection from rim curb rash due to the sidewall being pushed out further from the rim.
Does anyone know if 235s will fit on the stock rims without any wear, rubbing, or handling issues? Update: a cursory online search points to 235s being a bit too wide for a 7.5" rim for optimal driving characteristics. Maybe a 225?
Sport-Tech is offline   Reply With Quote
Old 08-18-2022, 12:03 PM   #27
Wrecky_Flowers_
Wrecky_Flowers_'s Avatar
Drives: '02 S2000; '22 GR86
Those tires in 235 will work fine on the stock wheels, but they will look a bit pinched (which sounds like what you're looking for). There are plenty of people putting much wider tires on the stock wheels for autocross and track driving, so you should be fine.
Wrecky_Flowers_ is offline   Reply With Quote
Old 08-20-2022, 08:15 AM   #28
benzz280
Drives: Toyota 86
From another reviewer who drove all 4 models back to back and highlighted their throttle responses:
HE also commented on the different behaviors from each car due to their suspension differences. This should provide more insights as to which model to choose based on own's preferences.
[Everyday Driver] GR86 vs MX5 RF (ND2) rawpoly GR86 General Topics (2nd Gen 2022+ Toyota 86) 13 02-14-2022 10:45 AM
Everyday Driver tests OFT Shiv@Openflash Software Tuning 12 02-02-2017 01:29 PM
Everyday Driver tests OFT Shiv@Openflash Engine, Exhaust, Transmission 32 01-23-2017 05:47 PM
Everyday Driver: BRZ vs WRX l0aded FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 11 07-04-2014 05:03 AM
FRS VS BRZ - EVERYDAY DRIVER Motopythons BRZ Photos, Videos, Wallpapers, Gallery Forum 19 07-03-2012 04:59 PM
