Old 08-14-2022, 11:26 AM   #1
Rafal
Drives: gr86 2013
Alarm activate when i try lock the door
I've been on Holiday for 3 week. When i turn home i try to start my gt86 - 2013 and nothing. Battery was dead. Not big deal. after charging car start and drive but i cant lock it. When i try lock door using key it behaviour like bonnet or trunk is open. The same after a few second when it try lock itself. It beeps a few time than alarm starts. What can i do? Maybe faulty sensor or immobiliser was the reason battery get flat?
Thanks
Rafal is offline   Reply With Quote
Old 08-14-2022, 11:53 AM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
the factory alarm or aftermarket alarm?
Old 08-14-2022, 11:55 AM   #3
Rafal
Drives: gr86 2013
Factory alarm
Old 08-14-2022, 12:19 PM   #4
soundman98
soundman98's Avatar
have you checked all the doors, and trunk that the sensors are working correctly?
Old 08-14-2022, 12:26 PM   #5
Rafal
Drives: gr86 2013
im not sure how check sensors. Car behaviour as usual. i try to find out how to check it. If you know how ill appreciate if you give me some tips
Old 08-14-2022, 12:48 PM   #6
soundman98
soundman98's Avatar
the dash open door indicator should display only when doors or trunk are open
Old 08-14-2022, 02:09 PM   #7
Rafal
Drives: gr86 2013
So it indicate all doors are closed.
Old 08-14-2022, 08:27 PM   #8
soundman98
soundman98's Avatar
3weeks, a stock vehicle generally shouldn't end up with a dead battery.
if the batteries slightly old, might just need to reset the car?
unplug the battery for a good hour or so, then reconnect.
you also checked all the door trunk switches that they're in proper operation?
Old 08-15-2022, 01:23 PM   #9
Rafal
Drives: gr86 2013
All seems to be fine. I take it to work today, drive all fine but simply don't want to close. Leave it for 8 hour with unplugged battery - the same. Most likely one of door/hood sensor get bad - but witch one? i think maybe trunk one cause hood one is really simple, and after i close door windows go back up so it seems like car know door is closed.
or some immobiliser iself is faulty - draining battery. But where immobiliser lives? i try google it - unsuccessfully :/
How to activate brz limited alarm Lee358 DIY (Do-It-Yourself) Guides 129 05-17-2024 09:21 AM
Door lock refresh stranger things Cosmetic Modification (Interior/Exterior/Lighting) 5 05-29-2017 09:56 PM
Don't forget to activate your alarm! BRZnut BRZ First-Gen (2012+) — General Topics 49 04-28-2016 02:23 PM
Activate your alarm!! engee NY / NJ / CT / PA 10 06-09-2015 01:45 PM
Lock door with fob while car is running? jhh3000 BRZ First-Gen (2012+) — General Topics 2 06-05-2014 01:04 AM
