| GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
Drives: X5 35d, D90, CX-5 Turbo
Everyday Driver Compares GR86 to BRZ..
And are the first that I've seen to talk about power delivery differences ..
#2 |
Drives: GR86
I liked their approach with this video and in my limited exposure to all 3 cars, agree with their opinions.
#3 | ||
Drives: 2022 GR86
I call 100% BS. When using ft•lbs and hp units and starting axes at 0, power and torque curves always crossover exactly at and only at 5252. The graph in the GR86 uses a different scale, and has a clearly marked 100 Nm at the bottom of the y axis; the BRZ most likely has 0 at the bottom. That explains why the GR86 curve looks like a vertically stretched version of the BRZ curve. The WOT torque at each rpm is most likely identical between the 2022s, the only difference being the throttle pedal response tuning. Quote:
Follow the build thread for my GR86!
#4 |
Drives: 2023 BRZ
I thought the same thing, timurrrr.
#5 | |
Drives: 2018 Toyota Tacoma
Well if the throttle tuning is different. They are feeling something. |
#6 | |
Drives: 2022 GR86
Data log or it didn't happen. In this case, a GPS log of a WOT 3rd gear pull from ~30 mph to redline is all that's needed. Not that hard to do, I even did it in a U-Haul van once for fun.
#7 |
Pavement Grey
would the so-called power difference (since no reviewer or rag has ever mentioned it...only suspension differences)
Just be a case of they happened to luck out on a car that happened to perform better than the rest of the batch? because out of how many thousands of cars out there, there could be several cases that perform better for no reason at all. Like for example they could have gotten the so-called Japanese tune where the car is rated at 232hp instead of the N/A tune rated at 228? Or they had their GR86 for awhile and the BRZ was more broken in or was a brand new loaner press car or something that just so happens to be performing at peak peak..... |
#8 |
Drives: GR86 RC
At least the throttle mapping does have a discernable difference (unless its their confirmation bias since they bought a gr86) and not Morizo marketing.
They also mentioned BRZ has a slightly better road feel (vibrations maybe?) i assume from the alu knuckles? Thats the only push i need to buy them knucles to replace my anvils on my GR86. Woohoo! |
#9 |
Drives: 2022 GR86
I'd expect the spring rates and damper tuning to have more effect on the overall NVH than just the knuckles.
#10 |
Drives: 22 WRB BRZ M6
I am usually a fan of these guys but they kept talking about power delivery differences without any data to back it up outside of the stupid graph.
#11 |
Drives: 84 CJ7, 08 Duramax, 2014 FRS
Same as before, Scion/86 more twitchy than the BRZ. And only 23 more horsepower, Weak. Still, these models and a boost package, those extra cc's come in handy for sure.
Also, wonder how much the ECU tuning is controlling the torque dip, is that entirely addressable at the tune level to make them all linear and upward like normal torque/hp profiles. I do like the reports of a stiffer chassis too. |
#12 | |
Drives: Crapcan
#13 | |
I like the lighter aspect of the knuckle, but still lean to the twitchy/sporty. Saw another video where a guy just showed the suspension differences by pulling the wheels. Knuckles in front, rear sway mounting in back are two major design differences. And quite a different spec on the sway bars too. One hollow, other solid in same location. Different diameters. Minor, but not the same. Not much talk on the springs and dampers, but different spec for sure on both. He said the BRZ was more comfy tame driving than the GR. But when pushed, both so similar he liked the BRZ because of it's softer ride. |
#14 | |
Drives: …
| [Everyday Driver] GR86 vs MX5 RF (ND2) | rawpoly | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 13 | 02-14-2022 10:45 AM |
| Everyday Driver tests OFT | Shiv@Openflash | Software Tuning | 12 | 02-02-2017 01:29 PM |
| Everyday Driver tests OFT | Shiv@Openflash | Engine, Exhaust, Transmission | 32 | 01-23-2017 05:47 PM |
| Everyday Driver: BRZ vs WRX | l0aded | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 11 | 07-04-2014 05:03 AM |
| FRS VS BRZ - EVERYDAY DRIVER | Motopythons | BRZ Photos, Videos, Wallpapers, Gallery Forum | 19 | 07-03-2012 04:59 PM |
