Old 07-31-2022, 08:22 PM   #4607
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
Quick shoutout for people looking for the Remote MAP sensor adapters, shipment just made it's way to CSG. I won't have any to offer on forum anymore.
B T is offline   Reply With Quote
The Following 3 Users Say Thank You to B T For This Useful Post:
ABQautoxer (08-03-2022), aKaGorganZola (07-31-2022), BAT_BRZ (08-06-2022)
Old 08-03-2022, 11:57 AM   #4608
Aztec
Lost in the twisties
Aztec's Avatar
Drives: 2014 BRZ Dark Gray Metallic
Originally Posted by apatel471 View Post
Which oil cooler works the best with this kit? Not looking at the JR DROC. Thanks!
I know you explicitly said not looking at the JR Dual kit, but.....It's great ;0
Originally Posted by Colin86 View Post
Why not look at the JR dual radiator/oil cooler? It works great both on street and track, highly recommend. I have a gen1, so I swapped the oil lines so they didn't kink -but I've heard the gen2's don't have that issue.
2nded! Works great on street and track!
Been running it for the past year with zero issues. (better use of the space combining the two)
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft
Aztec's Build Thread
Aztec is offline   Reply With Quote
The Following User Says Thank You to Aztec For This Useful Post:
Jerr (08-05-2022)
Old 08-03-2022, 01:58 PM   #4609
B T
I went with a Mishimoto, it ran it too cold, so got a smaller Setrab unit and it heatsoaked easily. Finally went back to the Mishimoto unit and got a higher temp thermostat on the oil bypass. Everything has been great since.
Old 08-04-2022, 11:05 AM   #4610
Jerr
Drives: 2016 Scion FR-S / Edelbrock SC
I've been having a heck of a time diagnosing some weird idle characteristics on this kit. As Zach suggested, I cleaned my MAF sensor which would help for a bit, so I ended up deep cleaning the Edelbrock filter and entire airbox assembly. Got a new MAF o-ring and screws while I was at it.
I've now got a really weird issue where the car runs and drives great in most conditions, except at hot idle. When the radiator fans kick on, the idle dips to 500rpm and the car almost stalls, then idle jumps to 1500, and back and forth until the fans turn back off.
No CELs, no other issues that I'm aware of. Anyone have any ideas? Throttle body is new (under 5k miles). The logs don't show anything that looks like vacuum leaking either, trims are good.
Jerr is offline   Reply With Quote
Old 08-04-2022, 01:03 PM   #4611
FrickingReallySlow
Drives: 2015 FR-S
Was this a 25 row or 19 row you used?
FrickingReallySlow is offline   Reply With Quote
Old 08-04-2022, 01:49 PM   #4612
dpfarr
Drives: BRZ ts
I had similar issue about idle. Turned out my MAF harness had a loose pin connection. I had an electrical code though.
dpfarr is offline   Reply With Quote
The Following User Says Thank You to dpfarr For This Useful Post:
Jerr (08-05-2022)
Old 08-04-2022, 03:53 PM   #4613
B T
Pretty sure it's the 19 row
Old 08-05-2022, 07:36 PM   #4614
Jerr
@dpfarr It turns out Zach thinks it was a tune bug. I've triple-checked every harness and connection around the airbox, replaced nearly everything.
He flashed my tune from his version 6.5x to 7.5, and now everything is a lot more smooth. Still learning in the throttle but I believe he set the fan behavior for much tighter tolerances. It now fluctuates about 200rpm +/- which is totally acceptable. I had to force the AC on to get the fans to kick since my JR-DROC keeps the car pretty cool but so far so good.
If anyone else has this issue only when fans kick on it might be a bug.
Old 08-05-2022, 07:41 PM   #4615
Jerr
Thirded. I see oil temps between 180F (Winter) and 205F (Summer) daily driving, and 220F when my foot gets heavy in the canyons. Probably a bit lower than ideal but this thing can easily handle a track heat load.
The Following User Says Thank You to Jerr For This Useful Post:
Aztec (08-06-2022)
Old 08-05-2022, 09:26 PM   #4616
B T
that seems a bit high for normal cruising. I'm at about 172-180 on the interstate in dead summer on the gulf coast after heatsoaking. My track days get me up to about 235-240 in spring, summer and fall.
The Following User Says Thank You to B T For This Useful Post:
Aztec (08-06-2022)
Old 08-08-2022, 11:43 AM   #4617
ponggo
Drives: 2012, toyota 86
can anyone point me to the link to the map relocation kit?
ponggo is offline   Reply With Quote
Old 08-08-2022, 11:46 AM   #4618
ABQautoxer
ABQautoxer's Avatar
Drives: 2021 Supra / 2022 Tundra
Just call and ask CSG or email them. I don't see them on the site.
TomR
ABQautoxer is offline   Reply With Quote
Old 08-08-2022, 06:32 PM   #4619
B T
They just got them in for the first time recently. Give them a call.
Old 08-21-2022, 12:49 PM   #4620
Jerr
Hey friends,
I've been having really strange idle issues specifically on radiator fan kick that I can't seem to diagnose. I tried a new tune which sort of band-aided the problem, but I didn't have this issue before on my tune which leads me to believe it's a mechanical or electrical issue.
The behavior: when the car is hot and idling and the thermostat calls for fans to kick on, the idle dips from the normal ~900 to 450 (almost stalling) and back to 1300, then back down to 450, over and over until the fans turn off. When the fans are off, everything goes back to normal. While this is occuring, I can see STFT jump around from -2 to +20 and AFR going all over the place. Interestingly, if I manually turn on the radiator fans by turning on the AC, the car compensates properly and idle sits at around 1000 stable. This problem is able to be replicated.
Things I have replaced/done:
-Checked for vacuum leaks (tune logs also show none)
-New battery optima yellowtop
-Checked that alternator is working (battery is charging properly)
-New OEM MAF sensor
-New OEM front O2
-New OEM PCV Valve
-Throttle body is still fairly new since ~1 year ago
-Air intake/filter parts completely cleaned
-Fresh flash of stable tune from when car was originally "dialed in"
I noticed in the logs that right as the fans kick on and before the idle actually dips, the MAF reading in g/s jumps up from 2.5 to about the 4.8 range, and the MAP reading goes from .3bar (stable idle) to .46 which is counterintuitive as the RPM is dropping, therefore the boost should be lower...?
Does anyone have any ideas of what might physically be wrong? I figured maybe fans drawing too much amperage but the same issue would also persist when AC was turned on, right?
Thanks all!
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
