07-25-2022, 03:29 PM | #337 | |
Drives: 2022 BRZ sport-tech
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ Current: 22 BRZ, 00 S2K - #0220 |
07-29-2022, 01:24 PM | #338 |
Drives: 2023 BRZ, LTD, MT
Ha, this has been happening to me too. I thought I was losing my mind. I wish these seats would go lower.
07-29-2022, 02:00 PM | #339 |
Drives: 2022 MT Neptune GR86 Prem.
07-29-2022, 04:39 PM | #340 |
Drives: 22 BRZ
It seriously feels like somebody is fucking with me. Just after a bit I think "why are my knees closer to the steering column?" then realize the seat has raised itself up a bit. Nobody else drives the car, does it all on its own.
07-29-2022, 07:28 PM | #341 |
Large Member
Drives: 2022 Subaru BRZ
Gremlins
Baby, you can drive my car
08-03-2022, 04:11 AM | #342 |
Drives: 2022 Subaru BRZ Limited 6MT
I sometimes have a metal clang sound coming from rear when going over a sharp bump, I'm guessing it's rear brake dust shields? I'm relatively new to these cars, is this a common issue?
08-03-2022, 07:50 AM | #343 |
CASC-OR T.A. Director
Drives: '13 Prius, '22 BRZ
I mean, how fast were you going? How high was the bump? As far as I can tell from mine, no, it should not clang. Are you sure it wasn't the car bottoming and the "bump" bouncing off your exhaust?
Want the best quality track times for new personal bests? Come on out to Ontario Time Attack!!!
OTA LIVE TIMING LINK |
08-03-2022, 09:31 AM | #344 | |
Drives: '22 BRZ
I think the jack in the trunk also could be making a bit of noise because its pretty loose in its location |
The Following User Says Thank You to mr.whiskers For This Useful Post: | diga (08-03-2022) |
08-03-2022, 12:43 PM | #345 | |
this isn't a one time issue, I've heard it occasionally since early on, around 25 mph on uneven/bumpy road sections. The car is stock except for HKS Spec L2 catback, it's not lowered.
08-03-2022, 08:23 PM | #346 |
Has the noise coincided with the installation of the L2? There's a good indicator and clue to investigate.
08-03-2022, 10:51 PM | #347 | |
Drives: zd8 brz
Or better yet, get under the rear and push the exhaust upward as hard as you can near the rear subframe/diff Exhaust might be making contact |
08-04-2022, 03:12 AM | #348 | |
nope it was happening before the new exhaust but I'll double check clearances again
08-05-2022, 05:59 PM | #349 |
Drives: "I drives like a Porsche"
How worried are you all about RTV and silicone in the oil pick up?
08-05-2022, 08:13 PM | #350 |
Drives: Mini
10 being extreme worry, like a 4. I just ordered an endoscope so I'm going to check when I do my oil change next weekend. If no excess, then in my head, likely everywhere else has correct amount and no longer need to worry. And I can continue adding my STI pieces, short throw, etc and finally ceramic coat the car.
Similar Threads | ||||
Anyone not buying to avoid early issues like 1st gen FRS? | stocktc1 | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 203 | 09-23-2021 09:11 PM |
Buying an early build in the fall, but some issues with these cars are worrying me... | RyMi | BRZ First-Gen (2012+) -- General Topics | 34 | 02-27-2019 08:56 PM |
New 2014s still have early issues? Prospective buyer | Lord09 | Issues | Warranty | Recalls / TSB | 25 | 06-14-2014 04:42 AM |
Early problems - speaker rasp and long turnover | Hawaiian | Issues | Warranty | Recalls / TSB | 44 | 08-30-2013 04:39 PM |
Initial Issues / Problems | JDMSushi | AUSTRALIA | 56 | 09-30-2012 10:21 PM |
