Old 08-01-2022, 11:05 PM   #15
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Originally Posted by Jackson Racing View Post
Small example: We ran our radiator/oil cooler on our T4 SCCA race car only because the internet said it wouldn't work. We designed it as the ultimate street solution, but knew it had overhead for naturally aspirated track use. The internet didn't believe us. Two national championships later with perfect oil temps, I'd say it worked.
I was only ever able to exceed the JR DROC cooling capacity with my stock power gen1 car when doing no-cooldown 30-minute sessions at Thunderhill West in 106ºF.
I'd say that was pretty damn good
I also wouldn't recommend doing 30-minute no-cooldown sessions in 100ºF+ weather for reasons other than engine cooling.
There are transmission, brakes, and tires — they will all not enjoy such abuse.
Follow the build thread for my GR86!
The Following User Says Thank You to timurrrr For This Useful Post:
villainous_frx (08-01-2022)
Old 05-14-2023, 04:07 PM   #16
OfficeLinebacker
Drives: 2019 Toyota 86 Base AT
Originally Posted by KillerBMotorsport View Post
I've never understood why anyone would want to retain the OEM cooler when using a remote setup, aside from cutting cost.
For anyone who NEEDS to use an oil cooler, removing that heat load from the cooling system is going to bump the cooling system's capacity. Which anyone who would be driving at that performance level would want to take advantage of.
If you run the return line from the oil to air cooler through the coolant sandwich plate, it can reduce thermal shock of reintroducing cold oil to the system. Also I believe the cooler is before the oil filter, and you want the oil to be as thin as possible when going through the filter to avoid pressure drop.
OfficeLinebacker is offline   Reply With Quote
Old 05-15-2023, 03:21 PM   #17
Sneakers
Drives: 2022 brz
I remember Greddy instruction mentioned cut passenger fender liner to get air flow.
Sneakers is offline   Reply With Quote
Old 05-15-2023, 03:29 PM   #18
Sneakers
Drives: 2022 brz
Any one has experience with the oil pressure change before and after?
2022 GR86 Premium Results @ Car and Driver Lightning Lap 2022 Competition Hachiroku GR86 General Topics (2nd Gen 2022+ Toyota 86) 13 02-12-2022 11:44 PM
2022 BRZ Limited Results @ Car and Driver Lightning Lap 2022 Competition Hachiroku BRZ Second-Gen (2022+) — General Topics 20 02-10-2022 11:44 AM
Charge coolers Zee7 Forced Induction 3 07-10-2020 11:12 AM
Oil Coolers AldoRaine Forced Induction 4 05-31-2020 01:10 PM
Oil coolers Matey Forced Induction 37 03-13-2015 08:21 AM
