| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#57 | |
Drives: 2018 Subaru BRZ Limited with PP
#58 |
Only happy when it rains.
Drives: series.blue
Almost every tire manufacturer list the weights of all of their tires on their web page.
#59 |
#60 |
Drives:
Does anyone know if the TS-5s will ever be available in bronze?
#61 |
Drives: WRB BRZ
#62 |
Drives: 2022 GR86
Titan 7 came up with a bunch of new fitments for 2022+ cars.
I got 17x9 +47 for my 2022 GR86, here's a side-by-side with a gen1 17x9 +37 wheel: (left and dirty is +37, right and clean is +47) ![]() Using "finger measurements", I couldn't easily find where the concavity/depth differs, so the absolute difference is pretty minimal. I'll post more photos when I put both on the car. +37 will go in the front, +47 in the rear.
Follow the build thread for my GR86!
| The Following 2 Users Say Thank You to timurrrr For This Useful Post: | Racecomp Engineering (07-20-2022), soundman98 (07-20-2022) |
#63 | |
Drives: 2022 GR86
How is your experience with these wheels? Do they work with stock suspension? Do they need spacers? What tire sizes are you running? 245/40r17? 255/40r17? Thanks in advance! |
#64 |
Drives: 2022 GR86
Pricey, but they look amazing and are among the lightest wheels on the market.
The 17x9 size is in the realm of "you might want to have suspension mods". For starters, the car will look like a monster truck with the stock fender gaps. Then the question is what you do in the front. 17x9 +47 with reasonably sized tires will likely rub HARD against the chassis at full lock. I don't even know if the wheel or the tire on it is going to clear the strut. You definitely won't be able to use camber bolts to add camber. If you add a 10mm spacer to get the effective +37 offset (or just get 17x9 +37 like I did) to minimize/avoid those issues, you'll need at least -2º of camber to tuck under the fender. A friend of mine who tried my 17x9 +37 with PP struts on his gen1 car wasn't happy with the gap between the tire and the strut. I believe gen2 struts have an even larger spring perch. If you want to keep the stock suspension, look into narrower options. 17x8 +45ish might be a better choice for now. 245/40R17. Even in that size the tire models I run (SX2, RT660) are challenging to squeeze under rear fenders.
#65 | |
Drives: 2022 GR86
Photos from my build thread
#66 |
Drives: 2022 GR86
Good news for you:
#67 |
Drives: 2022 GR86
Thank you sooooooooo much for sharing your experience!
Have fun with your car! |
| The Following User Says Thank You to yyffe For This Useful Post: | timurrrr (08-01-2022) |
#68 |
Drives:
#69 |
Drives: '23 BRZ Limited
I'm having trouble deciding between the TS-5 and R10 in 18s.
Or one of a couple of pairs of Advans, or a set of Wedsports.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
| New wheels - Rota Titan 17x9 | justinco | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 04-18-2017 01:30 PM |
| TWS Forged Wheels T66-F - Ultra lightweight Race Wheels with Style // DSG Performance | Jason@DSG | Wheels and Tires | 37 | 12-17-2014 02:50 PM |
| TWS T66-F Forged wheels on a Black FR-S | Touge Factory | Wheels and Tires | 17 | 08-21-2014 12:53 PM |
| Forged Wheels for 86 | Astra^EC | AFRICA | 5 | 09-24-2013 07:32 AM |
| AG.Function Forged Wheels | Eric@GetYourWheels | Wheels and Tires | 22 | 08-01-2012 12:16 PM |
