Old 11-14-2019, 10:39 AM   #57
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Originally Posted by timurrrr View Post
Now that you've mentioned -- yes, SX2s spec weight in that size is 26.2 lbs [1].
Still not clear where the extra 1.8 lbs come from; I don't think TPMS + center caps + balancing weights + dust and dirt would account for that.
Perhaps just an imprecision of my kitchen scales when used on an uneven pavement of my garage (I did try multiple locations though)...
Here's a quick table of weight SX2s vs Primacy HP in different sizes:
Code:
Size      | SX2      | PHP      | Difference
215/45R17 | 23.0 lbs | 20.8 lbs | 2.2 lbs
245/40R17 | 26.2 lbs | 22.5 lbs | 3.7 lbs
So yeah, apparently SX2s are so heavy that inertia-wise they outweigh the benefit of lightweight wheels. Still much faster laptimes though.
Perhaps when I'm ready for RE71Rs I can get well below 40 lbs for the wheel+tire combo :P
I couldn't easily find the weight of the OEM PP wheels without tires, but it used to be known to be ~22 lbs.
Yeah they might be slightly lighter than that, but either way, saving weight on the wheels isn't much of a problem. As for saving weight on tires, you just have to pick out a list of top choice tires and then look them up by weight. Tire Rack has weight specs on all of their tires, but they don't necessarily have every tire out there. My wheel and tire combo came out to 39.6 lbs (obviously for a different setup as well, but the tires are big) - https://www.ft86club.com/forums/show...=135328&page=7
Dzmitry is offline   Reply With Quote
Old 11-14-2019, 12:27 PM   #58
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
Almost every tire manufacturer list the weights of all of their tires on their web page.
why? is offline   Reply With Quote
Old 11-14-2019, 02:34 PM   #59
Dzmitry
Dzmitry's Avatar
Indeed. I just find it easier to browse on a wide variety of tire brands and types with their specs listed all on one site.
Old 03-05-2020, 01:47 AM   #60
guruwu
guruwu's Avatar
Drives:
Does anyone know if the TS-5s will ever be available in bronze?
guruwu is offline   Reply With Quote
Old 03-05-2020, 08:10 AM   #61
Fred E
Drives: WRB BRZ
The TS-5s are available in bronze, just not for any 5x100 sizes, unfortunately, with no plans either. I planned on just powdercoating mine eventually.
Fred E is offline   Reply With Quote
Old 07-19-2022, 10:47 PM   #62
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Titan 7 came up with a bunch of new fitments for 2022+ cars.
I got 17x9 +47 for my 2022 GR86, here's a side-by-side with a gen1 17x9 +37 wheel:
(left and dirty is +37, right and clean is +47)
Using "finger measurements", I couldn't easily find where the concavity/depth differs, so the absolute difference is pretty minimal.
I'll post more photos when I put both on the car.
+37 will go in the front, +47 in the rear.
Follow the build thread for my GR86!
The Following 2 Users Say Thank You to timurrrr For This Useful Post:
Racecomp Engineering (07-20-2022), soundman98 (07-20-2022)
Old 07-28-2022, 12:11 PM   #63
yyffe
yyffe's Avatar
Drives: 2022 GR86
Hi, I'm looking to buy Titan-7 17x9 wheels as well for my 2022 model.
How is your experience with these wheels?
Do they work with stock suspension? Do they need spacers?
What tire sizes are you running? 245/40r17? 255/40r17?
Thanks in advance!
yyffe is offline   Reply With Quote
Old 07-31-2022, 11:09 PM   #64
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Pricey, but they look amazing and are among the lightest wheels on the market.
The 17x9 size is in the realm of "you might want to have suspension mods".
For starters, the car will look like a monster truck with the stock fender gaps.
Then the question is what you do in the front.
17x9 +47 with reasonably sized tires will likely rub HARD against the chassis at full lock. I don't even know if the wheel or the tire on it is going to clear the strut. You definitely won't be able to use camber bolts to add camber.
If you add a 10mm spacer to get the effective +37 offset (or just get 17x9 +37 like I did) to minimize/avoid those issues, you'll need at least -2º of camber to tuck under the fender. A friend of mine who tried my 17x9 +37 with PP struts on his gen1 car wasn't happy with the gap between the tire and the strut. I believe gen2 struts have an even larger spring perch.
If you want to keep the stock suspension, look into narrower options.
17x8 +45ish might be a better choice for now.
245/40R17. Even in that size the tire models I run (SX2, RT660) are challenging to squeeze under rear fenders.
Old 07-31-2022, 11:10 PM   #65
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Photos from my build thread
Finally received the Titan 7 T-S5 in 17x9 +47 (2022 spec) that I'll be running in the rear, and mounted a fresh set of GT Radial SX2 in 245/40R17.
Kept the 17x9 +37 (gen1 fitment) in the front as I already had a set.
-3.somethingº camber in the front, -2.5º in the rear with RLCA, ~1" drop all around.
Went for a mountain drive and didn't hear much/any rubbing, will inspect the fenders next time the car is on a lift.
Old 07-31-2022, 11:12 PM   #66
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Good news for you:
Old 08-01-2022, 03:10 PM   #67
yyffe
yyffe's Avatar
Drives: 2022 GR86
Thank you sooooooooo much for sharing your experience!
Have fun with your car!
The Following User Says Thank You to yyffe For This Useful Post:
timurrrr (08-01-2022)
Old 10-03-2022, 11:16 AM   #68
guruwu
guruwu's Avatar
Drives:
Good news for you:
Hah - I saw this and was super hyped! Plan on getting a set at some point next year for my 22 BRZ.
Old 10-07-2022, 11:58 PM   #69
OkieSnuffBox
Drives: '23 BRZ Limited
I'm having trouble deciding between the TS-5 and R10 in 18s.
Or one of a couple of pairs of Advans, or a set of Wedsports.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
New wheels - Rota Titan 17x9 justinco Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 04-18-2017 01:30 PM
TWS Forged Wheels T66-F - Ultra lightweight Race Wheels with Style // DSG Performance Jason@DSG Wheels and Tires 37 12-17-2014 02:50 PM
TWS T66-F Forged wheels on a Black FR-S Touge Factory Wheels and Tires 17 08-21-2014 12:53 PM
Forged Wheels for 86 Astra^EC AFRICA 5 09-24-2013 07:32 AM
AG.Function Forged Wheels Eric@GetYourWheels Wheels and Tires 22 08-01-2012 12:16 PM
