Old 06-02-2020, 01:45 PM   #57
Yitzb
Yitzb's Avatar
Drives: Brz with wudebody. Hopefully boost
Remove the door cards and check for power going to the door lock controls using a multimeter. Work your way back to the battery.
Get a Techstream to check the chassis codes.
All the connectors seem to be fine. I check the with a multimeter
Yitzb is offline   Reply With Quote
Old 06-02-2020, 03:29 PM   #58
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
So you said earlier that all the other components are working like you can lock and unlock the door with a key, and you can lock and unlock the door with the manual lock; ie, all the mechanical locks are working, correct?
When you say all the connectors seem to be fine, are you talking about the power going to the door switches and to the actuator or just the door switches? My guess is that you just checked the door switches/buttons. You might be receiving power to the power door locks, but are you receiving power to the actual door lock actuator?
There should be a harness going from your door buttons to the actuator. When you push a button to lock or unlock the door from the door card or on your fob, your multimeter should detect voltage. If you have voltage going to the actuator from the door lock, which I suspect you do then your door lock buttons and control module for the fob works, and it is your actuator.
If you look at the picture or video below there seems to be just two contact points on the connector harness for the actuator. You could bench test the connection points to a battery. Attach wires to a battery and tap the two terminals. Switch to reverse polarity. If nothing happens then the actuator is dead. Replace with a new or used unit.
https://www.ebay.com/itm/2013-2019-S...7CMake%3AScion
https://www.subarupartsdeal.com/part...1032ca080.html
Old 06-02-2020, 06:54 PM   #59
ls1ac
ls1ac's Avatar
Would it not be unusual for both doors to have a mechanical failure at the same time?
Old 06-02-2020, 09:00 PM   #60
Yitzb
Yitzb's Avatar
I only checked the connectors I’ll try that out
Old 06-02-2020, 09:25 PM   #61
soundman98
ProCrastinationConsultant
soundman98's Avatar
it would be a little unusual considering the age of the compnents. but considering that the majority of systems tend to activate both doors most times, it's still feasible.
Old 06-02-2020, 10:28 PM   #62
Irace86.2.0
I think it is unusual. If it turns out to be the problem then my theory is that the doors slightly compressed during the collision. The door latch hook/bar jammed into the actuators, transferring forces that caused them to fail. There is enough slop in the doors that they sell a TRD door stabilizer kit, so maybe it is possible. I don't know.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
soundman98 (06-02-2020)
Old 06-02-2020, 11:44 PM   #63
Yitzb
Yitzb's Avatar
It’s a 2018 so doesn’t make sense that the actuator went out unless like u said it was damaged in the accident. But there was no visible damage to the doors
Old 06-03-2020, 12:24 AM   #64
Irace86.2.0
I have no idea if the actuators got damaged from the door flexing into the door jam hook. They could have taken the force transfer. Maybe they shorted out somehow. You won’t know until you bench test them, but obviously check for power going into the actuators first.
Old 06-03-2020, 12:25 AM   #65
Yitzb
Yitzb's Avatar
I’m gonna assume there is no power Bc I changed the fuse 3 times and it doesn’t appear to be working. I even checked the fuses and they seem fine. So I’m lost. lol
Old 06-03-2020, 12:45 AM   #66
Irace86.2.0
You have power going to the buttons you said. You need to check that there is power going to the actuator. If you push the fob or door buttons to open the doors then your multimeter should get a 12v signal then reverse polarity in the opposite to close the doors. If you get power then the actuator has to be bad. I wouldn’t assume unless you want to buy a part and return it if it doesn’t work.
p1l0t (06-03-2020)
Old 07-27-2022, 11:14 AM   #67
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Originally Posted by Sean Webber View Post
All the issues come from the actuator, aren't they?
dragoontwo is online now   Reply With Quote
The Following 2 Users Say Thank You to dragoontwo For This Useful Post:
bcj (07-27-2022), soundman98 (07-28-2022)
Old 07-29-2022, 11:55 PM   #68
colinshark
Drives: Some RX-7s
Hey... Is there another key floating around inside somewhere?
colinshark is offline   Reply With Quote
Old 08-11-2022, 05:01 AM   #69
Boomerang
86
Boomerang's Avatar
I had to replace one of my door actuators recently. Not too hard.
About the only issue I have had in 7 years, these cars are lemons (sarcasm)
soundman98 (08-11-2022), Ultramaroon (08-11-2022)
Old 08-15-2022, 05:53 PM   #70
Decep
Drives: 2013 FR-S Series 10
Yeah, looking at its other post, i reported
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
Adding doors auto-lock and oil t° display to your FRS / BRZ / 86 T0rt0r0 DIY (Do-It-Yourself) Guides 82 05-14-2019 01:46 AM
Doors won't lock. mynameis940 Issues | Warranty | Recalls / TSB 9 03-15-2018 03:05 PM
Trunk won't open and doors won't lock/unlock Mazikowski Electronics | Audio | NAV | Infotainment 13 03-05-2018 11:50 AM
Auto Lock (Doors) pinoyplaya BRZ First-Gen (2012+) — General Topics 67 11-13-2017 11:47 AM
Doors won't automatically lock adan Issues | Warranty | Recalls / TSB 18 03-01-2014 11:02 AM
