Old 07-24-2022, 01:43 PM   #1
brandonblt2
The Stig's African Cousin
brandonblt2's Avatar
Drives: 2014 wrb brz
Direct Injectors stuck replacement tool?
Hey everyone like the title says I'm currently replacing my direct injectors on my brz that has 185k miles on it. I've watched a few videos on removing them and everyone's seem to just pop right off but mine are really stuck. Did a little research and saw bmw's, vw's, and audi's all have a special tool basically a slide hammer to help remove stuck direct injectors. So do we have a tool similar to help with removal? Or does anyone have any tips to get them out? I just really stuck and wasn't expecting them to be this hard to remove.
Instagram: brandonblt2
Build Thread: http://www.ft86club.com/forums/showt...86#post2219386
Flickr: brandonblt567
brandonblt2 is offline   Reply With Quote
Old 07-25-2022, 05:21 PM   #2
Tell me you have hit them with some penetrating oil?
Old 07-25-2022, 05:33 PM   #3
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
They go in real hard. They come out real hard
NoHaveMSG (07-25-2022)
Old 07-26-2022, 01:02 PM   #4
brandonblt2
I haven't because I don't know what it would do the inside of the engine. Would it cause any harm to the engine if some got in it?
The Following User Says Thank You to brandonblt2 For This Useful Post:
humfrz (07-26-2022)
Old 07-26-2022, 01:03 PM   #5
brandonblt2
How'd you get yours out? Just brute force by hand or any tools?
Old 07-26-2022, 01:05 PM   #6
Nope. All good, but I've never done this specific job so I don't know if it'll help.
brandonblt2 (07-26-2022)
Old 07-26-2022, 01:15 PM   #7
brandonblt2
Did a quick google search seems to be ok since guys spray spark plugs with WD-40 to remove them and the direct injectors sit right over top of them. I'll give this a shot.
humfrz (07-26-2022)
Old 07-26-2022, 03:00 PM   #8
DarkPira7e
DarkPira7e's Avatar
I just pulled hard. Getting them back in is scarier
The Following 4 Users Say Thank You to DarkPira7e For This Useful Post:
brandonblt2 (07-27-2022), jrhudson (07-26-2022), strat61caster (07-28-2022), Ultramaroon (07-26-2022)
Old 07-26-2022, 03:57 PM   #9
Not to worry. Any small amount that would get inside the engine would just burn away.
As far as the outside of the engine, stuff like penetrating won't hurt anything. Bubba says it will just help keep the engine from rusting -
The Following 3 Users Say Thank You to humfrz For This Useful Post:
brandonblt2 (07-27-2022), strat61caster (07-28-2022), Ultramaroon (07-26-2022)
Old 07-26-2022, 11:51 PM   #10
jrhudson
Drives: 2016 scion frs
this. as someone that has done this a few times already. yea its harder putting them back in.
jrhudson is offline   Reply With Quote
Old 07-27-2022, 10:27 AM   #11
brandonblt2
So I was able to remove 2 of them last night using some WD-40, PB-blaster, and a pair of vice grips. Bent one of the injectors pretty good but I'm replacing them all anyway. Surprisingly the seals were fine but the injectors themselves were covered in grime and dirt. My car was running rich so this might explain that. I'm thinking the injector had to work extra hard to push through the grime so it added more fuel to overcome it.
20220727_075649 by Brandon Taylor, on Flickr
20220727_075725 by Brandon Taylor, on Flickr
Old 07-27-2022, 10:42 AM   #12
brandonblt2
Did you replace any of the fuel lines? Or did you just reuse them? If you did reuse them how many miles do you have on your car?
Old 07-28-2022, 09:26 AM   #13
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
When i replaced mine i just grabbed them with plyers and twisted and yanked and they popped out.
Old 07-28-2022, 12:31 PM   #14
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
I reused my hp lines. (100k miles). I put a dab of pipe dope on the threads for reassembly. Maybe not completely necessary but, what the hey. No problems after 2000 miles.
The Following 2 Users Say Thank You to blsfrs For This Useful Post:
brandonblt2 (07-28-2022), strat61caster (07-28-2022)
Cleaning direct injectors after E85 use SPCorBUST Engine, Exhaust, Transmission 14 01-15-2022 11:36 AM
SOLD Direct injectors bhmax Engine, Exhaust, Bolt-Ons 3 12-21-2020 03:02 PM
OTC Direct Fuel Injector Seal Installation Tool EWY Engine, Exhaust, Bolt-Ons 6 08-26-2017 09:05 PM
Direct Fuel Injectors Silverspeed Engine, Exhaust, Bolt-Ons 0 10-20-2016 07:04 PM
Additional sealing for direct injectors? Dmitri Engine, Exhaust, Transmission 6 05-16-2014 02:40 PM
