2022+ BRZ/GR86 specific oil cooler options
As of now, there's 3 solid options for oil coolers. I'll update the post as appropriate, when other track worthy coolers hit the market.
Minimum: Color fittings $679.99 ![]() Pros: - Lowest cost - Setrab 915 core - Good mounting solution - Minimum amount of oil cooling I'd recommend for any GR86/BRZ that sees hard driving or track use - Safety wire for banjo bolts (they took my feedback seriously!) - Mocal sandwich plate Cons: - Dumps heat in front of radiator - more complex installation with factory heat exchanger removal - Banjo bolts (but includes safety wire now per my recommendation!) Middle option: Jackson Racing $895 w/ optional shroud (Preorder, eta end of July 2022) ![]() Pros: - Has an optional shroud (that everyone should order) for superior cooling efficiency compared to the Color Fittings option - Setrab 915 core - Lines are wrapped in key locations to prevent abrasion - Mounts onto the stock impact beam - Proven history with 1st gen cooling - Best middle ground value (with shroud) Cons: - pushlock Aeroquip lines; gets the job done, but is bare minimum - Dumps heat in front of radiator - Performance no better than Color Fittings without the shroud Top option: GReddy $1520 (Preorder, ETA Sept 2022) MSRP: $1600 ![]() Pros: - Shrouded for maximum efficiency - Koyo core - Proven history of BEST cooling with 1st gen - Mounts off to the side, but directs air to the cooler from the main bumper opening - Dumps the heat around to the side, away from the radiator - EARLS braided lines and fittings - Lines are wrapped in key locations to prevent abrasion Cons: - Highest price - Uses non-OEM filter (but commonly available 3/4x16UNF ) Last edited by CSG Mike; 08-01-2022 at 09:22 PM. |
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | Kelse92 (07-28-2022), lonborghini (08-05-2022) |
| TC105X GR86/BRZ 17x9 specific track wheels! | RylisPro | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 44 | 09-30-2023 01:27 PM |
| 2022+ specific oil coolers | CSG Mike | BRZ Second-Gen (2022+) — General Topics | 42 | 01-23-2023 02:09 PM |
| 2022+ Subaru BRZ & Toyota GR86 Arctic Series Oil Cooler Kit | ColorFittings | Engine, Exhaust, Bolt-Ons | 0 | 03-02-2022 02:26 AM |
| 2022 GR86 Premium Results @ Car and Driver Lightning Lap 2022 Competition | Hachiroku | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 13 | 02-12-2022 11:44 PM |
| 2022 GR86 MSRP 2k over the BRZ? | mangler | CANADA | 5 | 12-06-2021 10:51 AM |
