Old 07-25-2022, 07:48 PM   #1
SeddyBRZ
Drives: Pearl White 2014 BRZ
Tubes by rear passenger wheel?
What on god's green earth is the tube for? I can't really tell where it goes and it's 100% in the way of me adjusting my coilover without having to take off the wheel. I'm about to just yank it but I wanna know if it's important.
Idk how to upload a picture but is towards the rear behind some plastic and is by the lca going up to what looks like the trunk.
SeddyBRZ is offline   Reply With Quote
Old 07-25-2022, 08:13 PM   #2
Ohio Enthusiast
Drives: 2018 BRZ
I'd hazard a guess that's the parking brake cable? Does it go into the back of the parking brake drum? Thick black cable?
Old 07-25-2022, 08:26 PM   #3
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Picture would help since I have no idea what you are talking about.
https://www.ft86club.com/forums/showthread.php?t=780
Old 07-25-2022, 09:14 PM   #4
Code Monkey
Drives: Subaru BRZ
When in doubt, just yank it, what can possibly go wrong.
Code Monkey is offline   Reply With Quote
The Following 5 Users Say Thank You to Code Monkey For This Useful Post:
alphasaur (07-25-2022), dpfarr (07-25-2022), JD001 (07-26-2022), NoHaveMSG (07-25-2022), SeddyBRZ (07-25-2022)
Old 07-25-2022, 10:25 PM   #5
Now that I've read some of your other gems, it all makes sense.
jcw99 (07-27-2022)
Old 07-25-2022, 11:00 PM   #6
SeddyBRZ
Lol other gems?
Old 07-25-2022, 11:02 PM   #7
SeddyBRZ
Instead I yanked the fender liner out as i only had 3 clips holding it in. It's some sort of breather tube I'd assume is for the gas tank. Either way it was in the way of me adjusting the coilover without removing the wheel so I took it off. Can't imagine it would cause any issues.
Old 07-25-2022, 11:41 PM   #8
soundman98
ProCrastinationConsultant
soundman98's Avatar
i can't see it, and you're in nebraska, so it really doesn't matter to me. i mean, you must know something subaru doesn't about fuel vapors!
Old 07-26-2022, 02:28 PM   #9
Ebush
Drives: 2017 Hot Lava 86
So just to be clear. Instead of just removing the wheel to make life easier, which would have taken 1 minute. You posted a question online, then proceeded to remove fuel hoses in order to adjust your coilover.
Ebush is offline   Reply With Quote
Old 07-26-2022, 02:58 PM   #10
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Inb4 gUyS wHY doES mY cAr nOt LIEk iT wHeN I GeT gaS?!?
The Following 4 Users Say Thank You to Yoshoobaroo For This Useful Post:
NoHaveMSG (07-26-2022), norcalpb (07-26-2022), soundman98 (07-26-2022), Ultramaroon (07-27-2022)
Old 07-26-2022, 03:10 PM   #11
norcalpb
norcalpb's Avatar
Yeah sounds like you just pulled one of the fuel tank evap lines
Old 07-26-2022, 04:26 PM   #12
...or our legs
jcw99 (07-27-2022), soundman98 (07-26-2022), Yoshoobaroo (07-26-2022)
Old 07-27-2022, 01:54 AM   #13
2020BRZtS
2020BRZtS's Avatar
Drives: '20 BRZ tS (15/300) / '09 Scion tC
No worries. That's the drain hose for when your trunk fills up with water. You should be fine. [/s]
2020BRZtS is offline   Reply With Quote
The Following 3 Users Say Thank You to 2020BRZtS For This Useful Post:
jcw99 (07-27-2022), soundman98 (07-28-2022), Ultramaroon (07-27-2022)
Old 07-27-2022, 11:15 AM   #14
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
You mean I didn't have to drill all those holes in the trunk?
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
Passenger Rear Wheel Liner scion fr-s BRZ First-Gen (2012+) — General Topics 1 06-24-2022 09:39 AM
Passenger Rear Wheel Liner scion fr-s Cosmetic Modification (Interior/Exterior/Lighting) 0 06-23-2022 07:48 PM
Rear passenger wheel leaking? airrick Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 08-02-2020 03:39 PM
Rear Passenger wheel bounce during cornering Takumidesh Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 04-29-2019 02:34 PM
Buzzing from rear passenger wheel Mattybro410 Issues | Warranty | Recalls / TSB 1 11-04-2014 09:25 AM
