Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 07-22-2022, 03:04 PM   #141
Originally Posted by ROFL it's Waffle View Post
What does the owners manual say about the charcoal filter? Is this considered a forever item, or "change regularly"?
It's a permanent part of the airbox on my daughter's '08 ES350.
Old 07-22-2022, 03:34 PM   #142
Chrisz5z
Drives: 2022 Steel GR86
No mention of it in the GR86's Owners Manual or Maintenance Interval booklet(Pages 37-40).
I guess they have 100% confidence that the regular air filter will do its job & that every single owner will be diligent with their maintenance
Chrisz5z is offline   Reply With Quote
Old 07-22-2022, 03:47 PM   #143
KillerBMotorsport
KillerBMotorsport's Avatar
Has anyone compared the USDM and JDM tunes to make sure this isn't just skewing AFR?
I know with AMGs this is a common mod, but the US tunes is different than the (what they call ROW; Rest Of the World). Doing this mod, and keeping the fuel trims where they should be requires a tune.
I would assume if these same parts when removed from the BRZ have an impact on airflow, they are also having an impact on the tune, or at least the trims. Would also be interesting to see a back-to-back test done (on the BRZ) after Short AND Long Term Fuel trims have finished learning. With the AMGs, they would often loose a bit after some time, without an accompanying tune.
Food for thought.
KillerBMotorsport is offline   Reply With Quote
Old 07-22-2022, 04:41 PM   #144
DarkSunrise
DarkSunrise's Avatar
Food for thought.
I’ve always wondered this about b2b dyno testing with new parts.. You test the new part before fuel trims have had a chance to adjust, which means the engine runs slightly lean on the dyno and inflates the actual gains. Would love to see how the AFR looks in these dyno comparisons.
2022 BRZ Build
2013 FR-S Build
Old 07-22-2022, 07:15 PM   #145
Tokay444
Anti stance.
Tokay444's Avatar
Not one person has said or even implied that.
Lies.
Old 07-23-2022, 07:23 AM   #146
Tokay444
Anti stance.
Tokay444's Avatar
Originally Posted by Ogt View Post
I still have mine…. I believe… forgot to toss it so if @Tcoat allows it<3….
I will post pictures of contents.
If it’s not required then perhaps it’s some Subaru green-earth-virtue move? Just speculating based off of the emails I get now.
Just send to him so he can double up.
Old 07-23-2022, 05:48 PM   #147
LancePower
Drives: 2020 BRZ tS
FTW
LancePower is offline   Reply With Quote
Old 07-26-2022, 09:14 AM   #148
ROFL it's Waffle
The guy w/o an FRS or BRZ
ROFL it's Waffle's Avatar
Drives: '23 GR86 Premium 6MT Halo White
Lies.
In this thread.
ROFL it's Waffle is offline   Reply With Quote
Old 07-26-2022, 09:36 AM   #149
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Hey guys, I just took out my cabin filter and dyno'd my car. It made roughly 6hp more without the filter! If you want a free and easy mod, take out your cabin filter. Hashtag 1Gen Master Race.
MS, CSCS, TSAC-F, CPT
Old 07-26-2022, 09:46 AM   #150
Oh I should just put the whole new intake in my 2020. Should be good for at least a 20HP increase even with the charcoal one there!
Old 07-26-2022, 10:46 AM   #151
Tokay444
Anti stance.
Tokay444's Avatar
Show your work.
Old 07-26-2022, 11:35 AM   #152
Show your work.
Saw it in the internet.
Old 07-29-2022, 12:49 PM   #153
CincyJohn
Drives: 2022 MT Neptune GR86 Prem.
Originally Posted by RandyBui View Post
Really interesting food for thought.
Indeed, which is the reason I didn't run out to immediately do this mod. I will eventually, probably at the same time I put on my catless JDM UELs and tune the car.
CincyJohn is offline   Reply With Quote
Old 07-29-2022, 12:54 PM   #154
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
You got the low quality bait.
My First Run Impressions and Testing Results with (knockoff) Billet Power Blocks Tatsu333 Engine, Exhaust, Transmission 9 09-16-2022 06:43 PM
ACE Header Independent Testing Results and Review - 199.6WHP on CA 91 Octane CounterSpace Garage Engine, Exhaust, Transmission 847 08-26-2020 04:44 AM
Objective CLD (sound deadening) Testing Results TOOSTUBBORN2FAIL Electronics | Audio | NAV | Infotainment 9 03-23-2016 06:41 PM
Motor Oil Testing Results Rocket.BRZ Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 0 06-30-2014 10:48 PM
Air filter Testing Fast_Freddy Engine, Exhaust, Transmission 0 06-06-2013 01:21 AM
