Old 07-21-2022, 12:05 PM   #1
Abaier
Drives: 2015 Subaru BRZ Limited
Subaru BRZ high pitched squeal/whine/buzz
Hello all,
I’m having an issue with my 2015 Subaru BRZ 79k miles and was wondering if anyone had a similar problem they resolved or could shed any light on what I should try next.
About 3 months ago I washed the car and when I started it I heard a very slight whine coming from the engine. It became louder with increased rpm. In the following three weeks it increased in intensity to what it is now. I looked everywhere and thought the sound was similar to an alternator bearing going bad. I replaced the alternator but the whine was exactly the same. I then thought it could be the accessory belt, but after replacing the sound was exactly the same. Does anyone have any ideas of what I should try next to diagnose and resolve the issue? Thank you!
Heres a link to a video I took this morning demonstrating the issue:
https://youtube.com/shorts/m1WtIs_RSPs?feature=share
Abaier is offline   Reply With Quote
Old 07-21-2022, 12:24 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The inner part of the AC compressor pulley is not spinning. These are clutched somehow. Wonder if it is smoked.
Old 07-21-2022, 01:44 PM   #3
Remove the belt and spin stuff by hand. If any of the parts make the slightest noise, replace.
Also, try running it with the input connector of the alternator disconnected. ...the little one.
Old 07-21-2022, 08:09 PM   #4
aKaGorganZola
aKaGorganZola's Avatar
Drives: 2017 BRZ Series. Yellow
Take a long screwdriver and put it on the center bolt of every pulley. Listen for the one that sounds rough. I just upgraded to a set of raceseng pulleys because when i washed my engine bay I'm assuming the cleaner got into the bearing of my idler pulley and within a day or two the bearing started making noise.
aKaGorganZola is offline   Reply With Quote
Old 07-21-2022, 09:17 PM   #5
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Yup, ghetto stethoscope, I do it all the time. Just don't forget which side is pointy
Old 07-21-2022, 09:52 PM   #6
...or touch the moving parts
Old 07-21-2022, 09:59 PM   #7
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
One of my buddies keeps sending me lathe video's like that and now I am tempted to get naked everytime I run the thing.
Old 07-21-2022, 10:50 PM   #8
soundman98
ProCrastinationConsultant
soundman98's Avatar
it doesn't normally spin unless the a/c is enabled, or hvac is set to 'auto', or 'defrost'.
still a potential spot though.
it almost sounds more like a rubbing noise. i know i've heard dozens of 90's GM's that sound exactly like that in the rougher neighborhoods, but never really learned what caused it!
Old 07-21-2022, 11:15 PM   #9
It sounds like a power steering pump when the fluid is low.
Old 07-21-2022, 11:46 PM   #10
soundman98
soundman98's Avatar
modded '15 with a hydraulic steering assist? lol
Old 07-22-2022, 11:46 AM   #11
Abaier
Thanks for all the suggestions everyone! Going ti be working on the car tomorrow so will update then
Old 07-22-2022, 10:04 PM   #12
Abaier
Checked and the fluid is just below the max line
Old 07-22-2022, 10:06 PM   #13
Abaier
Funny enough this all started right after washing my car, I didn’t clean the engine bay though. I went ahead and did this after work today and all of the pulleys with center bolts that don't move didn’t sound/feel rough at all except for the tensioner pulley. Is this expected? Heres a closer video of it:
https://youtube.com/shorts/bGSG7JSbUJY?feature=share
Old 07-23-2022, 12:13 AM   #14
Haha
That tensioner swing is perfectly normal. Healthy.
brz, sound, squeal, subaru, whine
High pitched whine/squeal. JavieBruh Engine, Exhaust, Transmission 16 01-12-2022 10:08 AM
High pitched turbo like whine following rpms Nfsundrgrnd Issues | Warranty | Recalls / TSB 8 02-15-2021 11:02 PM
High pitched squeal only when braking only with a winter wheel PatMegron Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 12-16-2020 03:57 PM
Squeal/whine when steering wheel is turning motomike Issues | Warranty | Recalls / TSB 4 10-08-2019 06:31 AM
High pitched whine from sound tube and idle jumping Nourdmrolnmt1 Issues | Warranty | Recalls / TSB 0 04-17-2013 11:00 PM
