Old 07-21-2022, 02:04 PM   #43
Originally Posted by Stonehorsw View Post
Would blackstone oil check be able to verify that before a bigger failure?
I doubt an oil analysis would have any meaningful indication. A new engine is going to show high on silicon whether it is where it belongs or in the filter. Not like it is getting chopped up into small particles so there really wouldn’t be anything unexpected to catch.
Ultramaroon (07-21-2022)
Old 07-21-2022, 02:25 PM   #44
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Originally Posted by Sasquachulator View Post
IS this considered a design flaw?
Seems like they designed the sealant area with a very tight tolerance...which is usually ideal is it not?
I guess its just the nature of the sealant, just like in CPU's where you only need to place a dab of thermal past on the center of the CPU before placing the heatsink/fan, and not a whole goop covering the entire CPU....which actually performs worse for heat transfer.
It's an assembly issue, IMO. Design seems fine.
The Following 5 Users Say Thank You to DocWalt For This Useful Post:
Blighty (07-21-2022), DylanJZA (07-22-2022), OkieSnuffBox (07-26-2022), Tcoat (07-21-2022), Ultramaroon (07-21-2022)
Old 07-21-2022, 02:29 PM   #45
Devil's in the deets
Old 07-21-2022, 02:38 PM   #46
Assembly and QC. Though not sure how they could actually inspect it.
soundman98 (07-21-2022)
Old 07-21-2022, 02:42 PM   #47
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Sure, still not a design issue though. Whoever calibrated the sealant gun and checked off on it failed at their jobs.
No good way to inspect it, just use an appropriate quantity of sealant.
The Following User Says Thank You to DocWalt For This Useful Post:
Tcoat (07-21-2022)
Old 07-21-2022, 03:16 PM   #48
And in the right place.
DocWalt (07-21-2022)
Old 07-21-2022, 03:22 PM   #49
Petah78
Drives: 2022 BRZ sport-tech
Actually, would an oil pressure gauge give you early warnings signs?
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ
Current: 22 BRZ, 00 S2K - #0220
Petah78 is offline   Reply With Quote
The Following User Says Thank You to Petah78 For This Useful Post:
mswbrz (07-28-2022)
Old 07-21-2022, 03:35 PM   #50
Spektyr
Drives: GR86
Depends on how it fails. If pieces break off, or the "rope" is gradually ingested you may see oil pressure drift over time.
But if it's one big chunk that wasn't a problem and then is, you'll see the needle bottom out and then, rapidly, the engine puke.
Borescope up the drain plug could do it. I have one so I'm thinking about doing that next oil change.
Spektyr is offline   Reply With Quote
Old 07-21-2022, 04:05 PM   #51
Rustyoid
Drives: 2022 GR86
anyone who has this happen should share their build date and engine serial number
Rustyoid is offline   Reply With Quote
The Following 4 Users Say Thank You to Rustyoid For This Useful Post:
diga (07-29-2022), LRNAD90 (07-21-2022), Petah78 (07-21-2022), timurrrr (07-22-2022)
Old 07-21-2022, 04:34 PM   #52
Those are the deets I meant. Please excuse my lazily expressed agreement.
Old 07-21-2022, 05:08 PM   #53
FrickingReallySlow
Drives: 2015 FR-S
Are you able to borescope up the Pickup neck? or can it not make a twist at a sharp enough angle?
we all know that RTV degrades with thermal cycling and gets harder with age + thermal cycling (-25C to 70C) so it would make sense that cars that went through the first winter in Japan or US and were driven everyday might see more of this excess RTV fall off in the pan. NVH of a sportscar will help shake it off.
I was due for an oil change so I poked my crappy old borescope in the pan. Plenty of excess RTV. Not as bad as that above example from the Toyota tech, but still.
FrickingReallySlow is offline   Reply With Quote
Old 07-21-2022, 07:21 PM   #54
Oh easy to do individual cars. I meant at the plant as part of the QC checks. It would be way to costly to do every engine but they probably do one in ca set number. Doesn’t mean many could slip through though.
Old 07-21-2022, 08:22 PM   #55
toeout
They have not told me the actual reason yet.
The day that I dropped it off, they did some kind of ECU check and said that the car had been ridden hard, many rev limit instances and also an overrev event at 7900 rpm 2000 miles before the engine failure.
The dealer told me that Toyota will fix it this time under warranty, but will not the second time under similar circumstances. Basically telling me that I caused the failure with the overrev.
This was all before they even removed the engine from the car. The fact that they ordered a short block and will re-use the heads is pretty telling that the overrev had nothing to do with it.
Do you have confirmation for the demise of your engine? Blocked oil pick up? Or its still being investigated by the dealer?
toeout is offline   Reply With Quote
The Following 9 Users Say Thank You to toeout For This Useful Post:
Ash_89 (07-22-2022), Blighty (07-21-2022), gcmak (07-21-2022), Petah78 (07-21-2022), RedReplicant (07-26-2022), Samba86 (07-23-2022), Stephen W. (07-22-2022), Tcoat (07-21-2022), timurrrr (07-22-2022)
Old 07-21-2022, 08:37 PM   #56
In fairness to the dealer they do need to look at ALL the possibilities including over revs. Money shifts do kill engines! Usually right away and not at a couple of hundred RPM like you did but still.
So at this point it is not confirmed yours is sealant related even though it is high (lily top) on the list of probabilities. Just hope that if they find any they are honest about it.
Ordering a short block and reusing heads in not a great indicator it wasn't over rev. Could easily do bottom end damage and not touch the heads.
oh no not again
New stock GR86 '22 Dyno Runs: Twins packing more power than advertised!! steel86gt GR86 General Topics (2nd Gen 2022+ Toyota 86) 14 03-09-2022 01:15 AM
Driver's side window seal/door seal KAB-FRS Issues | Warranty | Recalls / TSB 255 01-01-2021 06:09 PM
Is my engine blown? dallenj Engine, Exhaust, Transmission 39 01-30-2017 04:18 PM
Blown engine due to 0W-20? Benschneider06 Engine, Exhaust, Transmission 45 07-23-2015 02:33 AM
Subaru BRZ complete engine gasket & seal kit 2.0L JPxM0Dz Engine, Exhaust, Transmission 0 12-18-2012 11:11 AM
