| Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) Wash, Wax, Details, Repairs |
#29 | |
Drives: 2015 Scion FR-S
Rain-X also makes an anti fog treatment that goes on the inside of your windshield. Used it for year on the race cars without issue and i actually use it on the inside lens of my safety glasses to keep them from fogging up. |
| The Following User Says Thank You to e_lunatic For This Useful Post: | Dadhawk (07-20-2022) |
#30 |
Drives: 1999 Miata
I think the mistake people make applying RainX is that they apply too much and then don't let it haze up enough before removing.
I have found it best to apply like a wax, in the shade, using small circles applied directly to a cloth. Let it haze up for at least 5 minutes, buff it off with a clean cloth. I then reapply using the same method as before, letting it haze up at least 5 minutes before buffing it off. Now the trick is to spray the windshield down with water, preferably a spritz, not a spray, and then dry it off with a clean cloth. If you skip the water part at the end, you can end up with streaks. You also end up with streaks if you use too much on either of the applications described above. Living in S. FL, RainX is a MUST for all my cars.
DJ
1999 Miata VVT swap "Maggie" 2013 BRZ "Nancy-Drew BRZ" |
| The Following User Says Thank You to MX-5RACER For This Useful Post: | Dadhawk (07-20-2022) |
#31 |
What you describe is pretty much how I apply it as well.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#32 | |
Maybe I should try it again on a new(ish) windshield and see if I have better luck.
| The Following User Says Thank You to Tcoat For This Useful Post: | villainous_frx (07-21-2022) |
#33 |
Drives: 17 Asphalt 86
Carpro ceriglass with a glass pad and stoner invisible glass is what I use to prep windshields for coatings. Any polish should be able to deep clean the glass and remove embedded junk. Stiffer pad the better to generate some heat onto the glass.
I second aquapel. Leaps and bounds a better product, and cheap when you consider how long it lasts. MUCH easier to remove with next to no flash time. Typically around $15 CAD for one application. I've got 10-11 months since I last installed, and that I includes dealing with our crap winters. I've also tried Gtechniq G1 and wasn't overly impressed. Difficult to buff off/remove and lasted as long as aquapel at double the cost. Last edited by RToyo86; 07-20-2022 at 10:06 PM. |
#34 | |
Rain-x is what.. 40 year old technology? Nothing wrong with it, but after discovering aquapel it's entirely obsolete. Actually that's lie, I use my 5+ year old bottle to coat windshield wiper blades. |
| The Following 2 Users Say Thank You to RToyo86 For This Useful Post: | Dadhawk (07-21-2022), soundman98 (07-21-2022) |
#35 |
Drives: GR Corolla
I'm probably the oddball here, but I just use the same Collinite wax I use on the paint on all the windows. No hazing, no glare, and rarely ever have to use my wipers. Really the only time I have to use my wipers is when the car has been sitting in fog.
#36 | |
No doubt we get a pile more rain here though so wipers are used a pile. LOL Looked up California's rainfall for June and it was a whopping .1 inches. We had 2 inches in about 20 minutes yesterday alone!
| The Following 3 Users Say Thank You to Tcoat For This Useful Post: |
#37 | |
Drives: GR Corolla
#38 |
Drives: '20 BRZ tS (15/300) / '09 Scion tC
That's good to know. I only ever saw the cloth and wondered why it was a thing since any cloth would clear fog off the window. I always thought I was too stupid to regulate the defroster properly.
#39 |
Drives: e92 M3
We replaced the windshield.
#40 |
Drives: GR86
Never had issues with rain x causing hazing. Sounds like something going on with the application process. Gotta buff it off for sure. Tried out car pro ceramic coating and it last longer, few months. But more of a pain that just spraying rain x. Maybe I’ll try aquapel next.
#41 |
Just the tip
Drives: 2017 DGM BRZ
The only thing I use rain-x for these days is applying it to my wiper blades (also rain-x brand). My first set lasted almost 3 years by doing this, and only needed replacement because the rubber inserts started to tear.
I've been using Carpro Flyby Forte coating every 2 years and it's pretty awesome if you do all the prep and application correctly. 80+km/h and light rain you don't even need the use the wipers it just all beads off. |
| The Following User Says Thank You to wolffbite For This Useful Post: | Dadhawk (07-27-2022) |
#42 |
I have to stop using AutoZone as my source for cleaning products. That stuff looks pretty good. My main detractor is bug guts. This car seems to be a magnet.
| Rain rain rain! | Phantobe | Southern California | 9 | 12-15-2015 01:28 AM |
| FI Hood insulation: To remove or not to remove | bryan767 | Forced Induction | 8 | 08-15-2015 04:51 AM |
| Rain! | cycleboy | Southern California | 34 | 03-04-2014 03:31 AM |
| will polishing your car to remove swirls remove opti-coat? | bacon_cheese_beer | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 11 | 10-25-2012 10:41 PM |
| Rain, rain go away! | Partial Stall | New England | 26 | 06-05-2012 06:55 PM |
