| Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) Wash, Wax, Details, Repairs |
Because compromise ®
Drives: Red Herring
How to remove Rain-X?
How does one remove the Rain-X film from a windscreen? I've tried glass cleaner, metho, white spirit, nail polish remover, laundry detergent, cloudy ammonia. Each time I get the cloudy streaks of Rain-X that I can dry wipe so the windscreen is clear but the film is still there.
#2 |
Drives: '20 BRZ tS (15/300) / '09 Scion tC
rubbing alcohol, dishwasher soap, or straight vinegar.
It does wear off over time.
| The Following 2 Users Say Thank You to 2020BRZtS For This Useful Post: | soundman98 (07-19-2022), spcmafia (07-19-2022) |
#3 |
Famous Potatoes
Drives: '15 ultramarine
Every time I've ever used it it is gone in about 10 minutes of rain. Guess I need some Aussie rain-x.
Cleaning vinegar? |
| The Following 2 Users Say Thank You to Sapphireho For This Useful Post: | Dadhawk (07-19-2022), soundman98 (07-19-2022) |
#4 |
Drives: 2018 Subaru BRZ
Dawn soap, clay bar, and then follow up with Griots Glass Polish. You gotta replace the wiper blades because they carry residue.
Also, make sure that your windshield fluid is not the Rain-X one by some reason because then you're back to step 1.
| The Following User Says Thank You to spcmafia For This Useful Post: | soundman98 (07-19-2022) |
#5 | |
Drives: Red Herring
I forgot to mention in my first post that I tried a clay bar. Griots Glass Polish doesn't seem to be available locally. I will look for an alternative. F*ck this has turned into a waste of money.
#6 | |
Kind of odd that it is still there. Dawn should do the trick. Mix it in a spray bottle, 1 part of dawn, rubbing alcohol, and some water. See if that works. Yours must be really caked in.
#7 |
Drives: Red Herring
Metho seems to be almost identical to rubbing alcohol. As mentioned metho didn't seem to work. I shall try some vinegar.
#8 |
Any dish-soap that has a heavy de-greaser property would do. Hell, if you want me to send you some, let me know. Im about to go to Costco tomorrow so I'll hook you up with the biggest bottle I can find.
#9 |
Famous Potatoes
Cleaning vinegar is more acidic than regular vinegar.
Edit: this is what came up on Google.. Rain-X is a commercial formula used to repel water, rain, and snow from glass. To remove Rain-X, first mix equal parts water and white vinegar in a spray bottle. Then, spray the solution onto your glass and rub it in with a cloth. Once you've gotten rid of the Rain-X, use a new dry cloth to wipe away any residue. Last edited by Sapphireho; 07-19-2022 at 09:35 AM. |
#10 |
I have attempted to remove RainX off a couple of cars.
Alcohol helps (if you drink it since it doesn't do a bloody thing the that film) Clay barring just gives it a nice slick surface. Glasscleaners run off just like the water. Changing wiper blades is fine once you get rid of the stuff. There was only one thing that I found that completely got rid of that devils brew of chemicals and waxes...
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | jcw99 (07-27-2022), soundman98 (07-19-2022) |
#11 | |
| The Following User Says Thank You to Tcoat For This Useful Post: | soundman98 (07-19-2022) |
#12 |
OK, gotta ask, what's the issue with RainX that you would go to all this trouble to get rid of it? I used it for decades off and on with no issue.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#13 |
Drives: 1999 Miata
I had an old bottle of RainX that would last forever. I got a replacement from Walmart and that crap would barely make it through one rain storm before it was gone. This is when I found out that Walmart has their own "special" products that are not always the same as the higher priced versions carried at other stores.
I bought my last bottle of RainX at an autoparts store and it seems to last at least a month here in rainy S. FL.
DJ
1999 Miata VVT swap "Maggie" 2013 BRZ "Nancy-Drew BRZ" |
#14 |
I had it on two cars. All it ever did was smear and distort the vision. Hated it!
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | Desertnate (07-25-2022), sato (07-23-2022) |
| Rain rain rain! | Phantobe | Southern California | 9 | 12-15-2015 01:28 AM |
| FI Hood insulation: To remove or not to remove | bryan767 | Forced Induction | 8 | 08-15-2015 04:51 AM |
| Rain! | cycleboy | Southern California | 34 | 03-04-2014 03:31 AM |
| will polishing your car to remove swirls remove opti-coat? | bacon_cheese_beer | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 11 | 10-25-2012 10:41 PM |
| Rain, rain go away! | Partial Stall | New England | 26 | 06-05-2012 06:55 PM |
