Old 08-01-2012, 08:28 PM   #15
CircuitJerk
Pull my finger...
CircuitJerk's Avatar
Drives: Silver Scion Slushbox
Don't beat yourself up. You don't know for sure until you know.
Wish you the best in any case...
CircuitJerk is offline   Reply With Quote
Old 08-01-2012, 08:34 PM   #16
wbradley
Sarcastic SOB
wbradley's Avatar
Goo Gone is citrus oil based (oily mild acid) and I am 100% sure it is ok for urethane based clearcoat. Used it many times.
You likely have some adhesive residue you didn't remove or the orange colour of the product somehow got into the clearcoat.
Alternately if there is absolutely no residue, you need a detailer or paint shop to either wet sand at an ultra fine grit and polish or apply a mild cutting compound and buff off a thin layer of clearcoat. Don't try this yourself!!! Trust me on this one.
A trick to remove gummy adhesive after Goo Gone application is put a bit of flour on the gum and roll it off with your fingers. It MUST be dry to do this.
I thought the caption read "Goo Gone f**ked my wife"!
The Following User Says Thank You to wbradley For This Useful Post:
RRnold (08-01-2012)
Old 08-01-2012, 08:38 PM   #17
fatoni
vinegar and concentrated dish soap...problem solved. although there might be other problems down the road but, you know, not my car
Old 08-01-2012, 08:47 PM   #18
CircuitJerk
Pull my finger...
^^^Certainly worth a try!
Old 08-01-2012, 08:52 PM   #19
fatoni
its the best multi purpose cleaner in the world
Old 08-01-2012, 08:56 PM   #20
Stealth
Stealth's Avatar
Drives: FR-S M/T Argento, 96 Mustang Cobra
On my Argento, I have a pink stain below the headlight, I think it happened while on the barge. I also has some bug crap on the front last week and after I wiped it there was still a yellow stain, right near the front emblem. The car has a fresh coat of wax on it so I'm not really sure but it seems the front bumper cover can easily be stained. Buffing it did nothing but the yellow stain is going away from sitting in the sun, the pink hasn't changed.
Stealth is offline   Reply With Quote
Old 08-01-2012, 09:04 PM   #21
RRnold
2 wheel member
RRnold's Avatar
Drives: JZA80, 997.1, Taco
Originally Posted by frs View Post
So today my toy badge came and i went debadge the scion one, i took of the front badge and the goo is so hard to come off, i used alot of goo gone but the paint turned a bit yellowish now! i tried to wash it off but the paint is still ruined...
im really sad now.. maybe someone know how to fix it?
I think I kind of see it on the left area of the Toyota halo. Man, is the Subaru paint that shitty that even Goo Gone messes it up?! I've used Goo Gone on my Tacoma which is Super White and never had any discoloring.
Old 08-01-2012, 09:06 PM   #22
Khyron686
Drives: 2011 Outlander XLS, 2013 FR-S Blue
I used a bit of windex for any of my debadging - no issues yet on 4+ cars.
Khyron686 is offline   Reply With Quote
Old 08-01-2012, 09:07 PM   #23
Lonewolf
Lonewolf's Avatar
Drives: Moped
Now that's the kinda stuff that scares me...even after waxing and buffing no luck, eh?
Old 08-01-2012, 09:08 PM   #24
track_warrior
Track Junkie
track_warrior's Avatar
Drives: Faster than the Stig!
Try dish washing soap, if that does not do the trick use wd40 yes wd40 it works!!
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
track_warrior is offline   Reply With Quote
The Following User Says Thank You to track_warrior For This Useful Post:
frs (08-01-2012)
Old 08-01-2012, 09:09 PM   #25
JW89225
Drives: E92
I made the same mistake on my M3, and it was neon stain on the trunk size of my thigh lol. Fortunately in the end after a lot of polishing, all the stain came off.
You'd need some level of cut polishing, the stain on mine was from the towel i used to rub, the goo gone took the color off and left it in the clear coat
good luck OP!
2013 Scion FR-S 6AT
JW89225 is offline   Reply With Quote
The Following User Says Thank You to JW89225 For This Useful Post:
frs (08-01-2012)
Old 08-01-2012, 09:16 PM   #26
frs
Drives: frs
Alright! Ill try that
frs is offline   Reply With Quote
Old 08-01-2012, 09:25 PM   #27
CircuitJerk
Pull my finger...
In the past, and even with a re-paint, the clear is still soft, and can take a few weeks or more to fully out-gas and harden.
I'm not sure how well cured the factory finish is. And they may still use a flex agent which is even softer and in some cases were done and cured under lower temps in a separate paint line.
In this state it is more prone to stains and finish defects if exposed to certain chemicals.
Old 08-01-2012, 09:26 PM   #28
track_warrior
Track Junkie
let me know how it works out, a friend removed graffiti from his car with wd 40 successfully!
BTW make sure if you use wd40 to not use it in the sun.
frs (08-02-2012)
NYC BRZ: Life in the Big Apple with a BRZ NYC BRZ Member's Car Journals 36 08-14-2012 12:25 AM
The life of my FR-S thus far! srt4_night_rider FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 65 08-13-2012 03:23 PM
I will probably only have this sort of luck once in my life... joshua BRZ First-Gen (2012+) — General Topics 9 07-11-2012 08:08 AM
Life is good! RKC Scion FR-S / Toyota 86 GT86 General Forum 17 06-23-2012 07:54 AM
86/FR-S Real Life Spottings CSSM Scion FR-S / Toyota 86 GT86 General Forum 22 04-03-2012 12:40 AM
