Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 07-14-2022, 03:59 PM   #43
mycrors7
mycrors7's Avatar
Drives: zd8 brz
And everybody may as well get used to the fact that the rest of the world (including the other States) are all headed down the same road. California is just leading the charge.
finally someone who understands that conforming to California standards now is gonna save everyone else a huge headache down the road
Manufacturers have already gone from making two different versions of the car for the USA down to just making the California version because it complies with every other state and simplifies selling cars between states
Plus, for those living in california, a car that is all CARB legal and is making good power is just that much nicer. it holds A LOT more value and a much higher level of respect because the owner went through the trouble of keeping things legal.
for anyone worried about the California legality of this mod.. you dont have to. ive never once seen a smog tech open up a stock airbox during any smog check. California smog really isnt as bad as people make it seem.
hell even the tech at the state referee didn't open up the airbox in my golf when i was state ref'd
ill check the smog compliance sticker under the hood when i get a chance later today. if there is any mention of a charcoal filter in the intake system, then the tech should technically open up the airbox and peek at it. If there isnt anything mentioned, then the chances of your car failing because you removed that charcoal filter has gone out the door and you can remove it freely.
mycrors7 is offline   Reply With Quote
The Following User Says Thank You to mycrors7 For This Useful Post:
Tcoat (07-14-2022)
Old 07-14-2022, 04:08 PM   #44
Originally Posted by Lantanafrs2 View Post
Some states don't have as much industrial pollution so vehicle emissions aren't as critical.
We all breathe the same air. A lower population density doesn't absolve each individual of the contribution. While I feel that industrial pollution should be equally regulated, I disagree with the argument.
Old 07-14-2022, 04:52 PM   #45
Industrial pollution is rapidly being more controlled than car emissions and has been for a while. It just isn't as obvious as car regulations because it doesn't impact individuals. It is behind the scenes so people ignore it.
Ultramaroon (07-14-2022)
Old 07-14-2022, 04:59 PM   #46
https://www.epa.gov/regulations-emis...-ghg-emissions
Old 07-14-2022, 05:18 PM   #47
Lantanafrs2
Drives: 2013 frs red
There's no argument to disagree with. States which are able to meet air quality standards without overly restricting vehicle emissions don't need to over focus on vehicle emissions. Air quality is defined as a whole.
Lantanafrs2 is offline   Reply With Quote
The Following User Says Thank You to Lantanafrs2 For This Useful Post:
Old 07-14-2022, 05:19 PM   #48
mycrors7
mycrors7's Avatar
Drives: zd8 brz
Originally Posted by mycrors7 View Post
finally someone who understands that confirming to California standards now is gonna save everyone else a huge headache down the road
as a follow up, the MY2022 emissions label for a California BRZ checks the following:
(2)TWC : three way Catalyst ; basically the cat on the headers and the cat on the front pipe. both must meet EPA requirements. California cars must use CARB legal cats and have a visible EO number stamped on the cat itself.
WR-HO2S : wide-range heated oxygen sensor (pre-cat)
HO2S : heated oxygen sensor (post-cat)
SFI : Sequential Fuel Injection
DFI: Direct Fuel Injection
there is no mention of any charcoal filter required. you can pull the charcoal filter out of a California car and it will pass smog legally in California
Tcoat (07-14-2022)
Old 07-14-2022, 07:58 PM   #49
PulsarBeeerz
Drives: JRSC BRZ SOLD
Only on this forum can someone go through the effort of getting and providing numbers for people to argue the numbers without contributing data themselves.
PulsarBeeerz is offline   Reply With Quote
The Following 2 Users Say Thank You to PulsarBeeerz For This Useful Post:
CaptainFenderbaum (08-08-2022), Tokay444 (07-20-2022)
Old 07-15-2022, 09:27 AM   #50
quikag
Drives: '22 BRZ Limited 6MT - Ignition Red
I removed the charcoal filter in less than one minute last night. Popped those two clips, rotated the airbox, jammed a knife through the charcoal mesh, stuck my fingers through the hole from the knife and ripped out the filter out. A few pellets of charcoal fell out and I just rotated the box, so they fell to the ground before aligning the airbox and flipping the two clips again.
So, results? I felt AT LEAST a 2hp difference and engine seems to rev more eagerly. I definitely got much more than my money's worth on this mod.
quikag is offline   Reply With Quote
The Following User Says Thank You to quikag For This Useful Post:
Tcoat (07-15-2022)
Old 07-15-2022, 09:37 AM   #51
Only on any car forum will people fall for clickbait video titles and think they are getting far more than they really do.
BUT I SAW IT ON THE INTERNET
OkieSnuffBox (07-15-2022)
Old 07-15-2022, 09:48 AM   #52
PulsarBeeerz
Or thinking that 5-10whp is within the noise of error on a 200ish hp dyno. Its used to be 1-3hp, then it was 4-6hp now we are up to 10hp of noise error. Need to keep on moving that goal post to be right and all.
The Following User Says Thank You to PulsarBeeerz For This Useful Post:
Old 07-15-2022, 09:56 AM   #53
Can be even more depending on the unit. This is not breaking news.
You keep in believing what you want to believe though.
https://www.roadandtrack.com/car-cul...-dyno-numbers/
https://www.enginelabs.com/engine-te...meter-designs/
Old 07-15-2022, 10:06 AM   #54
Ogt
Ogt's Avatar
Drives: ‘13 AT FRS
Just for fun, I understand Tcoat wants to die on this hill about it not being real for whatever reason. It’s repeatable results and was 3x times very consistent. So each run that decreased with heatsoak did so while still maintaining the 4-5peak gain? Clickbaity sure but still on the curve is there UP TO a 10whp gain. And to say that’s worthless and false because it’s not absolute peak seems as similar as saying “well the famed torque dip doesnt matter cuz peak”
Ogt is offline   Reply With Quote
The Following 3 Users Say Thank You to Ogt For This Useful Post:
CincyJohn (07-15-2022), DylanJZA (07-22-2022), Tokay444 (07-20-2022)
Old 07-15-2022, 10:09 AM   #55
Ogt
Ogt's Avatar
Drives: ‘13 AT FRS
Yeah is 5-10 going to be noticeable? Off paper no lol.. but still the fact remains it’s available right here&now, free, and in combination of tuning and whatever other bolt ons you want.. could add up to 30? That you could notice.
If all else you’re still ignoring the concept showing how well the stock system does flow without it and how that could effectively make aftermarket intakes a terrible *value*
Old 07-15-2022, 10:16 AM   #56
And saying "up to" as a qualifier is just a cop out. Could be .0001HP and that means it is "up to" 10.
Removing a thin carbon filter does NOT give you 10HP as the video states end of story.
I have already said several times that the stock set up is excellent and aftermarket is not required but that is all ignored because everybody is so focused on the fact I simply stated there was no 10HP gain to be had.
But everybody is welcome to pretend that it does magically make 10 if it makes them feel better.
My First Run Impressions and Testing Results with (knockoff) Billet Power Blocks Tatsu333 Engine, Exhaust, Transmission 9 09-16-2022 06:43 PM
ACE Header Independent Testing Results and Review - 199.6WHP on CA 91 Octane CounterSpace Garage Engine, Exhaust, Transmission 847 08-26-2020 04:44 AM
Objective CLD (sound deadening) Testing Results TOOSTUBBORN2FAIL Electronics | Audio | NAV | Infotainment 9 03-23-2016 06:41 PM
Motor Oil Testing Results Rocket.BRZ Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 0 06-30-2014 10:48 PM
Air filter Testing Fast_Freddy Engine, Exhaust, Transmission 0 06-06-2013 01:21 AM
