Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 07-13-2022, 04:32 PM   #15
Grosbard
Drives: 2022 BRZ coming
Thanks for all the feedback! Based on this feedback, I think maybe mine is underperforming.
Grosbard is offline   Reply With Quote
The Following User Says Thank You to Grosbard For This Useful Post:
Pete (07-13-2022)
Old 07-13-2022, 04:52 PM   #16
SlowTime
Drives: 2009 MX-5
Mine works great. In fact it gets so cold I have to turn it down and direct the vents away from me. We have had weeks where the weather is above 90 and heat indexes over 100.
SlowTime is offline   Reply With Quote
Old 07-13-2022, 08:04 PM   #17
Pete
Pete's Avatar
Drives: 22 BRZ
You are not the only one, mine has been a bit on the weak side too. It has been much hotter than normal this year so I figured that was the problem, but now based on this thread I am wondering if I need some coolant to get it up to speed. Thanks for asking the question.
2013 FRS -> 2011 CTS-V -> 2006 Cayman S -> 2015 GTI -> 2022 BRZ
Pete is offline   Reply With Quote
Old 07-14-2022, 09:23 AM   #18
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
I remember reading a similar thread a few years ago. My '13 is a bit on the weak side. That thread got me to thinking that the factory may have skimped on the refrigerant to save some money. It hasn't bothered me enough to go through the trouble of tweaking the charge. Without a sight glass, we need to follow a detailed procedure to get it just right.
I don't have "real" AC gauges, so I borrowed one like this from a friend. When it was blowing warm on the drivers side only, (weird), the needle was right between green and blue zones (24psi). After 1/2 can (small size), it was at 46psi (kept it in the blue zone) and blowing cold as balls.
BirdTRD is offline   Reply With Quote
The Following 3 Users Say Thank You to BirdTRD For This Useful Post:
DocWalt (07-14-2022), Pete (07-14-2022), Ultramaroon (07-14-2022)
Old 07-14-2022, 09:32 AM   #19
It is likely an automated fill system so all cars "should" have the same initial fill. That said automated systems are known to screw up now and then.
The bigger variations would be with leakage and driving type.
Those that mess with their engine bays may be creating small leaks and lose a bit of pressure. AC system fittings can be temperamental.
Driving around the city at lower RPMs may give a false impression that the AC is ineffective. Hit the highway and bring the revs up and you may find it is bloody cold all of a sudden.
Even the second gen is still a small displacement engine that never plays well with AC even under the best of conditions so there can be quite a difference from car to car.
Old 07-14-2022, 09:46 AM   #20
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
It also seems that the second gen disables the compressor at throttle openings other than WOT. At least this is what I think I feel.
The Following User Says Thank You to dragoontwo For This Useful Post:
Tcoat (07-14-2022)
Old 07-14-2022, 09:51 AM   #21
Good point. They could very well be wringing every bit of power they can out of it by shutting the AC down more often. Even a couple of seconds off can increase temps in the car quickly.
Old 07-14-2022, 11:30 AM   #22
Same as first gen.
DocWalt (07-14-2022), Tcoat (07-14-2022)
Old 07-15-2022, 05:25 AM   #23
Lelandjt
Drives: '04 STi, '12 Mazda 3 Hatch
EDIT: After reading your post for a 20th time I think you're saying that it disconnects at WOT and at smaller throttle openings. That sounds like a great feature to me. I always turn it off in my other vehicles when going up a hill or anticipating acceleration.
Can you clarify this? Did you mean the opposite? What would make sense is the compressor disconnecting* during WOT, or even above some throttle percentage like 75%.
*A/C compressors usually have an electric clutch to engage or disengage from a pulley that is always being spun by a belt.
Lelandjt is offline   Reply With Quote
Old 07-15-2022, 06:59 AM   #24
dragoontwo
dragoontwo's Avatar
You would be correct. Sometimes it feels like any tiny movement disables the A/C compressor.
Old 07-15-2022, 12:19 PM   #25
[s]My AC only works when I'm mashing the gas pedal[/s]
Old 07-16-2022, 10:11 AM   #26
g e
I have a Gen 1 BRZ
Pressing the RECIRCULATE switch maximizes the cooling. The aircon struggles when pulling in 99 degree air from outside
Works fine until someone farts.
g e is offline   Reply With Quote
The Following User Says Thank You to g e For This Useful Post:
Tcoat (07-16-2022)
Old 07-16-2022, 02:26 PM   #27
Unless one is alone in the cabin. Then it's glorious.
Old 07-16-2022, 04:31 PM   #28
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Mine only works when I turn it on.
Aircon blowing cold on one side Kris86 Issues | Warranty | Recalls / TSB 9 05-12-2020 12:36 PM
Cost Effectiveness of Modifying Your Car Tristor BRZ First-Gen (2012+) — General Topics 12 09-22-2018 11:22 PM
Dual Zone AirCon Operation Esseff Scion FR-S / Toyota 86 GT86 General Forum 34 05-01-2017 06:05 PM
Effectiveness of a Lightweight pulley DrifterX Engine, Exhaust, Transmission 94 12-11-2016 01:10 AM
Swap Aircon HVAC controls from BRZ/GTS to FRS/GT MudithJ Cosmetic Modification (Interior/Exterior/Lighting) 3 08-04-2016 10:13 AM
