Old 07-11-2022, 04:20 PM   #911
Sasquachulator
Pavement Grey
I guess, but this just feels to me like sitting in the still car and making engine and shifting noises as you pretend to drive.
I doubt this will happen, and if it does, it will likely be more or less a placebo. Even the Toyota patent you reference seems to just be "faking" gear changes.
I understand some people are MT or die, and I get that and if that's what is wanted, and there is enough market for it I hope it happens for those that want it.
I would think though that ones that want it, would want it to actually do something and not simulate something.
I think it'll be just like those old arcade racer setups (daytona USA or Ridge RAcer) or like those gamer setups at home.
Pedals + shifter attachment to the chair, steering wheel attached to the desk and you can play gran turismo or Forza like a real racecar driver including real shifting and pedal modulation action!
It'll feel exactly like playing a video game rather than driving an actual car.
Old 07-11-2022, 05:20 PM   #912
ZDan
ZDan's Avatar
Drives: '23 BRZ
OooooOOOoo
Pics ?
Well, you asked! This was a while back, 2010? Damn...
Here it is with some body panels expertly painted satin black by me:
If you like yo pixels BIG:
Yeah, detail mount machining docs and parts list & etc.
I was working at a now long since defunct electric vehicle company called Vectrix. Basically I removed the cylinder heads, hacked off 2/3 of the crankshaft and made a coupler and bolted a Vectrix motor up. ~28hp at ~5500rpm. Similar torque to SV650, but you gotta shift WAY sooner! Battery pack is NiMH, so *heavy*. I might be about to rebuild it with Li batteries and cut about 100 lb. out. Yeah....
The Following 6 Users Say Thank You to ZDan For This Useful Post:
bcj (07-11-2022), Dadhawk (07-11-2022), Kiske (07-12-2022), NoHaveMSG (07-11-2022), soundman98 (07-11-2022), TurboLag23 (07-12-2022)
Old 07-11-2022, 05:30 PM   #913
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
That's super cool
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
soundman98 (07-11-2022), WolfpackS2k (07-14-2022), ZDan (07-11-2022)
Old 07-12-2022, 09:28 PM   #914
TurboLag23
TurboLag23's Avatar
Drives: 2018 BRZ w/Performance Package
While not "exactly" a wagon, the Lyriq is closer to a modern station wagon than it is an SUV in my opinion.
With Tesla signing an agreement to open it's charging stations in the US I think the improvements we need in the infrastructure are coming. Still surprised that that fueling stations along the main routes haven't jumped on the bandwagon more
I don't really see the point of adding a mechanical clutch and shifter. For the most part it only helps in the top end, maybe increasing your top speed a bit. Just adding it for the sake of "engagement" doesn't really advance the tech at all.
1. Great point on the Tesla charging stations - I think it's a huge step in the right direction since they are 150/250 kW depending on the generation, so they're pretty speedy.
2. Adding a mechanical manual trans & clutch to an EV does not make any engineering sense - it's purely an emotional decision. Any increases in efficiency from being able to optimize gear ratios would likely be offset by the additional weight, but whatever - it's more fun! It is not "simulating" shifts - you are very much still driving a manual car, just without the idle! I've ridden in an EV-swapped Karmann Ghia, and it is truly sublime. You don't need to clutch out from a stop, but you should definitely still use clutch between gears. If the electric motor's redline mimics that of the ICE it replaces, your shift points don't even need to change that much; you just need to optimize for the electric motor's powerband. But you will definitely want a more robust clutch - aforementioned Karmann Ghia blew its first (stock) clutch into a million pieces a few miles into its maiden voyage because of all the torque! It now has a competition-spec clutch and has been going without a problem. Here - watch this for more details:
One last point: a super-easy way into auditory feedback in a manual EV is to just switch the motor/trans mounts to polyurethane or solid metal, to transmit more whine into the cabin.
TurboLag23 is offline   Reply With Quote
Old 07-13-2022, 03:40 PM   #915
Arthur-A
Arthur-A's Avatar
Drives: 2020 BRZ/86, 2020 BMW 330i
Arthur-A is offline   Reply With Quote
Old 07-13-2022, 03:49 PM   #916
Arthur-A
Arthur-A's Avatar
Old 07-14-2022, 01:28 PM   #917
More good charging news thanks to Federal funds. Not only is Tesla getting ready to open up charging in the US to all vehicles, but GM/evGo and Pilot/Flying J are installing 2,000 charging units at the 500 outlets along the Interstate Highways.
Irace86.2.0 (07-15-2022), ZDan (07-14-2022)
Old 07-16-2022, 12:01 AM   #918
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Originally Posted by Arthur-A View Post
Lots wrong here. For instance, lithium ion holds a charge extremely well. Cars have battery drain in Sentry mode or for other reasons, but they can be charging when parked, or a service can charge the car for you remotely, if someone was worried. They already have these services. But a car really only loses 2-3% per month sitting, so I don’t know where he is getting his numbers. My motorcycle sat for over a year with a Shorai lithium iron battery without a trickle charger and active immobilizer and started right up.
Dude assumes a lot. 18 wheelers could do battery swapping and have the batteries charge slower and at night and not need fast charging. Lithium sulfur and sodium sulfur batteries could dramatically change EV potential, including cost, longevity, performance, material ecology and sustainability, cut weight by a third or triple range, etc. To think things will stay at the current standard is silly.
Oil isn’t renewable, so it isn’t sustainable. It is also better to drive an EV with today’s batteries on coal electricity than a similar ICE, and all that only improves with renewables and lithium/sodium sulfur batteries or whatever they come up with. Oil is also more volatile than electricity. Lithium, sodium and sulfur will need to ramp up, as demand will likely spike and so will costs, but the long term is a more stable product. Recycling will definitely ramp as well. The best recycling is reuse for things like grid storage or to those who require less range, but recycling will be huge, as it is already progressing.
The best thing he said was recognizing that housing is a big part of the solution. We need more multifamily homes and less urban sprawl for sure.
Old 07-16-2022, 12:23 AM   #919
Irace86.2.0
So much wrong and outdated thinking with redundancies already mentioned. And no, old cars aren’t better than new cars or EVs.
Old 07-16-2022, 01:22 AM   #920
Arthur-A
Arthur-A's Avatar
Lol, "engineering explained", ev shill disguised as car enthusiast.
The Following User Says Thank You to Arthur-A For This Useful Post:
soundman98 (07-16-2022)
Old 07-16-2022, 02:36 AM   #921
NARFALICIOUS
NARFALICIOUS's Avatar
Drives: 88 Supra 1JZ, 16 FRS, 25 GR Corolla
He's had a supercharged S2000 and majority of his videos, starting with 11 yrs ago, are centered around gasoline engines. Not even close to an "ev shill" lmao.
NARFALICIOUS
Noob Poster
1988 | 2016
NARFALICIOUS is offline   Reply With Quote
The Following 3 Users Say Thank You to NARFALICIOUS For This Useful Post:
Irace86.2.0 (07-17-2022), weederr33 (07-20-2022), WolfpackS2k (07-19-2022)
Old 07-16-2022, 09:36 AM   #922
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Considering a small percentage of his videos are on EV’s that’s a pretty baseless claim. Though we are used to those from you. I am just going to post this again.
The Following 4 Users Say Thank You to NoHaveMSG For This Useful Post:
Arthur-A (07-16-2022), Irace86.2.0 (07-17-2022), Wally86 (07-25-2022), weederr33 (07-20-2022)
Old 07-16-2022, 04:12 PM   #923
Arthur-A
Arthur-A's Avatar
What's a lithium mine?
Old 07-17-2022, 04:39 PM   #924
Irace86.2.0
Don’t you have Google?
https://letmegooglethat.com/?q=what%...ithium+mine%3F
Once you are done there, you should look up what are sodium and sulfur mines.
https://www.autoevolution.com/news/s...gh-190333.html
https://en.m.wikipedia.org/wiki/Sodium
Sodium is the sixth most abundant element in the Earth's crust and exists in numerous minerals such as feldspars, sodalite, and halite (NaCl). Many salts of sodium are highly water-soluble: sodium ions have been leached by the action of water from the Earth's minerals over eons, and thus sodium and chlorine are the most common dissolved elements by weight in the oceans.
https://en.m.wikipedia.org/wiki/Sulfur
Sulfur is the tenth most abundant element by mass in the universe and the fifth most on Earth.
Tcoat banned? Hotrodheart Off-Topic Lounge [WARNING: NO POLITICS] 95 07-06-2019 01:46 AM
Does anyone know why pansontw got banned? Soloside Off-Topic Lounge [WARNING: NO POLITICS] 17 10-26-2018 04:20 AM
Got banned from gf's complex jdmblood Other Vehicles & General Automotive Discussions 11 07-12-2015 12:46 PM
Why have so many users been banned? xuimod Site Announcements / Questions / Issues 9 03-08-2015 02:23 PM
Banned Toyota GT 86 Advert Banned Nevermore FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 9 11-16-2012 07:27 PM
