Old 07-30-2021, 12:45 PM   #57
Originally Posted by RebornS14 View Post
correct. NTN is the manufacturer/supplier for the release bearing.
https://bcabearings.com/catalog/sear...26model%3D9563
As we also saw throughout all the threads on the subject there were at least 2 and possibly three slightly different bearings used right at the factory. There seemed to be no real pattern to what was used when so there could have been another supplier involved at random.
It would be odd to do that but not unheard of. also would explain why some people never had an issue while others had exactly the same failures.
Old 04-23-2022, 11:20 PM   #58
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
If anyone needs the revised TOB I will sell it cheap. My TOB noise went away so I never had it installed.
B-R-Z is offline   Reply With Quote
Old 07-13-2022, 01:11 AM   #59
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Old thread, but the images in the OP are useful context if you have bought an aftermarket Exedy clutch kit in the past, recently, or will receive one soon.
I believe that the TOBs they ship in their clutch kit these days include the updated TOB, as the Exedy-provided TOB in my kit matches the pictures of the revised TOB in terms of shape and also have a white paint dot.
EndlessAzure is online now   Reply With Quote
Old 07-13-2022, 10:50 PM   #60
e_lunatic
Drives: 2015 Scion FR-S
Confirmed. Had my TOB and clutch replaced and the Exedy kit comes with the updated TOB
e_lunatic is offline   Reply With Quote
Old 07-14-2022, 01:48 AM   #61
Brz-123
My TOB has started creaking. So without the engine on, I push the clutch pedal down and can hear creaking.
Does the GR86 use this new TOB or a updated version of it? Similar for the Clutch itself, is it revised over the 86 and worth replacing
I am thinking of replacing the clutch kit with the GR version, if I can get one.
Sent from my SM-G781B using Tapatalk
Brz-123 is offline   Reply With Quote
Old 07-21-2022, 11:36 PM   #62
Turdinator
Señor Member
Turdinator's Avatar
Creaking pedal is more likely just the bush at the top of the pedal running dry.
1974 TA22 Celica
2013 86 GT
Throw out bearing Hyp Northern California 26 03-13-2017 11:42 PM
Post If You Have Had Your Throw-Out Bearing Go Bad! Bushhy Issues | Warranty | Recalls / TSB 8 10-24-2016 05:34 PM
Throw-out bearing mhigham Issues | Warranty | Recalls / TSB 71 08-18-2016 10:21 AM
Noisy throw out bearing jp_r6 Issues | Warranty | Recalls / TSB 23 08-18-2016 04:45 AM
throw out bearing clips... Shit Luck Engine, Exhaust, Transmission 0 04-12-2014 06:34 PM
