Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 07-12-2022, 02:45 PM   #15
Ogt
Ogt's Avatar
Drives: ‘13 AT FRS
Oh NOW a tldr is acceptable to Snuff. Assuming that is meant as irony so I won’t answer.
Ogt is offline   Reply With Quote
Old 07-12-2022, 03:09 PM   #16
LRNAD90
Drives: X5 35d, D90, CX-5 Turbo
Originally Posted by OkieSnuffBox View Post
I'm not watching a 14 minute video.
Was there a tune added? Or is the claim removing this part adds this amount of HP. It seems a little hard to believe.
No tune, just 'theoretically' the stock ECU adjusting to (marginally) increased airflow..
LRNAD90 is offline   Reply With Quote
Old 07-12-2022, 03:35 PM   #17
Ogt (07-12-2022), OkieSnuffBox (07-12-2022)
Old 07-12-2022, 04:17 PM   #18
OkieSnuffBox
Drives: '23 BRZ Limited
Wouldn't it be TL;DW? You ignored my question in an attempt to have a "gotcha."
It doesn't take nearly 15 minutes to show two dyno pulls.
I don't understand why wanting objective evidence is so offensive to some.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
The Following User Says Thank You to OkieSnuffBox For This Useful Post:
Tcoat (07-12-2022)
Old 07-12-2022, 04:52 PM   #19
Ogt
Ogt's Avatar
Drives: ‘13 AT FRS
The evidence is there if you want it, not my job to convince you.
Old 07-12-2022, 05:13 PM   #20
ROFL it's Waffle
The guy w/o an FRS or BRZ
ROFL it's Waffle's Avatar
Drives: '23 GR86 Premium 6MT Halo White
Everywhere I've read so far, nobody's found a way to tune the ECU (maybe I'm wrong, hopefully I'm wrong). I've also heard about YouTubers' cars not running very well off camera. Will I remove the tissue from the car's nostrils? ehh... I need a larger sample size before I do it to my own car.
ROFL it's Waffle is offline   Reply With Quote
Old 07-12-2022, 05:30 PM   #21
Ogt
Ogt's Avatar
Drives: ‘13 AT FRS
There’s probably a chance if you had engine issues, Subaru could deny fault over it. Personal decision to be made there.
I would assume the YouTubers issues are associated more with running full catless exhausts without a tune over a slight increase in airflow. Edit: do consider according to previous post, the JDM version does not include the pad at all from factory.
Another thing to consider is if you go buy whatever aftermarket intake at $300+ that may claim 7hp increase; 5 of that could be coming from the effective removal of this. Maybe making it not worth time or money to some.
The Following User Says Thank You to Ogt For This Useful Post:
mike2100 (07-13-2022)
Old 07-12-2022, 08:13 PM   #22
patsimca
Drives: 2022 BRZ
Ecutek is close apparently.
They've posted on the other forum that shall not be named.
Sent from my Pixel 6 using Tapatalk
patsimca is offline   Reply With Quote
The Following User Says Thank You to patsimca For This Useful Post:
Old 07-13-2022, 11:06 AM   #23
ROFL it's Waffle
Exclamation
If anyone wanted to see some actual data of what that extra EPA pad does or rather restricts. I know Engineering Explained did a video on his Crosstrek years ago but neat to see what it does specifically with the new FA24. I anticipated a larger % gain with the BRZ compared to the Crosstrek but it comes out pretty much the same, around a 4% gain peak from stock to removed.
I found this on another 86 forum. Seems like for you guys that NEED EPA devices for your annual inspections, you probably shouldn't remove it. I know California definitely requires it, and I think NY is on its way too (if not already)
The Following User Says Thank You to ROFL it's Waffle For This Useful Post:
Ogt (07-13-2022)
Old 07-13-2022, 05:50 PM   #24
mycrors7
mycrors7's Avatar
Drives: zd8 brz
Although California does require it, smog isnt required for 8 years from the date of purchase of a brand new vehicle in California.
unless you get caught with a state referee ticket, youre safe for 8 years.
even if you do get caught with a state referee ticket, you can purchase the half airbox piece for like $65 last i checked. shove it in the corner of your garage until the day you need to smog it, and toss it on at that point.
as far as performance and the car running poorly. I ripped mine out and it's been driving perfectly fine.
Youre gonna get issues from people who are running UEL headers.. something the car/ECM was absolutely not designed to run with by any means. Hell some people are even running small amounts of e85 for god knows what reason.
mycrors7 is offline   Reply With Quote
The Following User Says Thank You to mycrors7 For This Useful Post:
Ogt (07-13-2022)
Old 07-13-2022, 11:54 PM   #25
Liquidsnake
Drives: "I drives like a Porsche"
If I remove this will void my warranty and while I still pass emission in California?
Liquidsnake is offline   Reply With Quote
Old 07-14-2022, 12:53 AM   #26
mycrors7
mycrors7's Avatar
Drives: zd8 brz
it will likely void warranty if the warranty reason can be linked to removing this filter. for ex: if a suspension components fails under warranty period, it cant be linked to removing this filter, therefore nothing is void
it wont pass california visual inspection during smog(assuming the smog tech actually checks)
Tcoat (07-14-2022)
Old 07-14-2022, 04:58 AM   #27
mike2100
mike2100's Avatar
Drives: 23 BRZ
Anybody find a part number for the box without the charcoal filter?
mike2100 is offline   Reply With Quote
Old 07-14-2022, 08:19 AM   #28
Just cut the charcoal filter out and use the frame as a spacer. No need to change the whole box.
Doubt there is really 10hp to be had but may get a couple out of it.
Not going to "void" any warranty unless they can prove that having it there caused the issue. Be pretty tough sell on their part.
Won't need a tune and it won't cause the engine to run poorly. It just isn't a big enough change to have that much affect. Same as using any aftermarket drop in. Of course a tune will make things "better" but you could likely get the same results from tuning with it in place. Stock tunes are never the best since they need to compromise for fuel economy and emissions.
This whole thing is much ado about nothing really.
OkieSnuffBox (07-15-2022)
My First Run Impressions and Testing Results with (knockoff) Billet Power Blocks Tatsu333 Engine, Exhaust, Transmission 9 09-16-2022 07:43 PM
ACE Header Independent Testing Results and Review - 199.6WHP on CA 91 Octane CounterSpace Garage Engine, Exhaust, Transmission 849 08-26-2020 05:44 AM
Objective CLD (sound deadening) Testing Results TOOSTUBBORN2FAIL Electronics | Audio | NAV | Infotainment 9 03-23-2016 07:41 PM
Motor Oil Testing Results Rocket.BRZ Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 0 06-30-2014 11:48 PM
Air filter Testing Fast_Freddy Engine, Exhaust, Transmission 0 06-06-2013 02:21 AM
