Old 07-07-2022, 09:47 AM   #1
ajaxburger
ajaxburger's Avatar
Drives: 2017 BRZ Limited Perf. Pack
Aftermarket HU, Factory USB Position - 3D Printed
Hi everyone, just wanted to share a link and some dimensions for use by others.
I have an aftermarket, Pioneer, headunit with a USB cable that comes off for use with CarPlay. Previously, this was just hanging out of my dash as it did not connect properly with the factory USB port.
I've measured for and printed a plug that fits snuggly in the remaining hole from removing the factory USB/Aux setup and holds the Pioneer's USB cable nicely. I've included the dimensions for others' reference as I wasn't able to find them myself when digging through the forum.
Keep in mind, these are kind of ballpark measurements since my calipers would not properly fit and I guessed on the radius of the edges.
Measurements
Outer Dimension: 33mm x 23mm, 4mm radius on corners.
Front Lip Depth: 6mm (this could be thickened up to 7-8mm)
Port-Hole Dimension: 18mm x 11mm x 9mm (depth).
Port Walls (3mm thick): Inner Edge ^^, Outer Edge - 24mm x 17mm
USB Cable: 17.5mm x 10.5mm
You can find the files to print or re-work here: https://www.thingiverse.com/thing:5427119
Imgur Album
Hope this is the right area for a post like this!
zoom zoom... wait wrong company
ajaxburger is offline   Reply With Quote
Old 07-07-2022, 10:26 AM   #2
Trollhart
Trollhart's Avatar
Drives: 2013 Subaru BRZ Sport
Looks good!
FYI, yoou can also re-use the factory piece if you mutilate a USB Cable by removing the metal shroud of the female side.
It will then properly connect to the backside if the factory piece.
That‘s how I have done it with my Pioneer unit. I also soldered some wires and an AUX-Plug to retain that functionality, but that may be a bit over the top
Trollhart is offline   Reply With Quote
Old 07-07-2022, 01:17 PM   #3
ajaxburger
ajaxburger's Avatar
Originally Posted by Trollhart View Post
Looks good!
Thanks! Needs some sanding and maybe some paint / bondo in the gap to help it blend but that's a future-me problem.
I was considering doing the same but I had botched another electrical project at the time and just didn't feel like cutting anything else up . Definitely the right way to do it however.
Old 07-11-2022, 01:22 PM   #4
MX-5RACER
Drives: 1999 Miata
I used a cable like this:
https://www.amazon.com/Metra-AX-TOYU.../dp/B00EAYYQDO
This cable allowed me to retain my factory USB port for CarPlay use with my new headunit (Atoto A6).
DJ
1999 Miata VVT swap "Maggie"
2013 BRZ "Nancy-Drew BRZ"
MX-5RACER is offline   Reply With Quote
Old 07-11-2022, 04:44 PM   #5
Tatsu333
Drives: 2020 BRZ Sport Tech RS
Looks like the correct one for FR-S/86/BRZ is this one:
https://www.amazon.com/PAC-USB-TY1-T...s%2C102&sr=1-1
Tatsu333 is offline   Reply With Quote
3d printing, diy, headunit, pioneer, usb
Factory Sub Wiring to Aftermarket HU Unholypanda Electronics | Audio | NAV | Infotainment 3 10-11-2019 08:15 PM
Want to buy factory intake or aftermarket Gvegaz Want-To-Buy Requests 2 09-30-2016 02:11 PM
Using Factory USB port with Aftermarket HU ruskymx Electronics | Audio | NAV | Infotainment 93 06-10-2015 06:53 PM
Turbo from factory or aftermarket chiefshayan Forced Induction 27 03-06-2015 07:14 PM
Factory PCM updates and aftermarket tunes brillo Engine, Exhaust, Transmission 5 05-26-2013 11:52 AM
