Old 05-26-2013, 09:58 AM   #1
brillo
Drives: 2013 Firestorm FR-S
Factory PCM updates and aftermarket tunes
the recent announcement of a PCM update dealing with the injectors had me wondering how factory updates are handled by ECUtek and the tuners that use their software. Does ecutek get a copy of the updated stock reflash and then push a version that can be modified out to its customers who will layer on their custome tune?
Want to make sure that these kinda fixes will always trickle down to us that run custom tunes.
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
Old 05-26-2013, 10:03 AM   #2
xjohnx
Grip>Slip
xjohnx's Avatar
It seems most tuners have already (or have plans to) incorporated this fix in their latest tunes.
Old 05-26-2013, 10:48 AM   #3
Mikem53
Drives: FR-S 6MT
What recent announcement?
Mikem53 is offline   Reply With Quote
Old 05-26-2013, 11:14 AM   #4
xjohnx
Grip>Slip
xjohnx's Avatar
http://www.ft86club.com/forums/showp...2&postcount=65
Old 05-26-2013, 11:37 AM   #5
Mikem53
Drives: FR-S 6MT
Originally Posted by xjohnx View Post
Thanks.. So their answer is to pull some timing at 5200 rpm and above?
I don't think I want this fix..
Old 05-26-2013, 11:52 AM   #6
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
That's the A01 revision, the suffix is the region.
Note that this applies to the transient timing retard, so in between shifts. You will NOT notice any performance difference. I should also mention that EcuTek saw this vulnerability before it was public here, and as we happen read the documentation, we've been altering this for a couple of months to play it safe
If you have a tune from an EcuTek tuner, just get an update with the A01x or request your A00x to be updated. It is a 3 minute process if no features are changed.
Xero-Limit is offline   Reply With Quote
Using Factory USB port with Aftermarket HU ruskymx Electronics | Audio | NAV | Infotainment 93 06-10-2015 06:53 PM
Retaining Factory BT Mic w/ Aftermarket Radio ecko04 Electronics | Audio | NAV | Infotainment 4 04-08-2014 06:22 PM
Auto Factory Aftermarket exhaust ESBjiujitsu Engine, Exhaust, Transmission 113 01-17-2014 05:45 PM
Aftermarket intakes & tunes... zooki Engine, Exhaust, Transmission 5 12-19-2012 02:18 PM
Factory wheels with aftermarket lug nuts. BigJyoungblood Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 08-21-2012 08:40 PM
