| BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ |
#43 |
Drives: Crapcan
From the first charts in this thread it looks pretty stable at 200F. I'd like to see what it is doing at 240F or a little higher. That is where I notice more weird high RPM pressure fluctuations on the FA20.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Dzmitry (07-14-2022) |
#44 | ||
Would be interesting to see the ECU's AVCS tables. There's likely a temp table (coolant or oil) that changes values once a certain temp is exceeded. |
| The Following User Says Thank You to KillerBMotorsport For This Useful Post: | Petah78 (07-08-2022) |
#45 | |
Drives: Crapcan
https://www.ft86club.com/forums/showthread.php?t=134863 Mine starts at about the same spot every time, 5800rpm, and I have had multiple drastically different AVCS timing tables in my car. I haven't 100% ruled it as the issue but I have no other explanation.
#46 | |
#47 |
Drives: 2013 frs base
Whoa! Are you implying that 20-25 minutes of staging (at idle) then 1-1.5 minutes of auto-X is worse than the same amount of time doing hot laps at VIR?
#48 | |
Drives: Crapcan
No logs. I bought an Innovate motor sports pocket logger and ssi-4 just for that purpose to log of the oil pressure gauge and correlate it to rpm but never got it working right then got too busy to mess with it. Stock block, no oiling mods but a cooler, can’t replicate the issue on the street. Clearances won’t be known till I tear this engine down this winter.
#49 |
1 year later and this is the hottest I can get this thing to. The sticker is not super accurate, but +/-10° is reasonable.
The car has seen all kinds of activities: commuting, long hauls, city traffic jam in peak summer temps, auto-x, drag racing, hill climbs, dyno pulls, etc. Not everything, but a good bit of stuff. Highest temperature read in-car: ~240°. My previous statements of the OEM sensor reading artificially high by ~20° still seem to be holding true. |
| The Following 6 Users Say Thank You to KillerBMotorsport For This Useful Post: | Dzmitry (10-12-2022), Petah78 (10-11-2022), Stonehorsw (10-30-2022), timurrrr (10-11-2022), Ultramaroon (10-28-2022), x808drifter (10-12-2022) |
#50 |
Pulled the pan on our under 200 mile engine...
Nothing too exciting here. Typical break in 'glitter' and definitely a presence of some kind of break-in additive. One big chunk of RTV hanging in the wind. I'm fairly certain this piece has been like this for a while. The seam was razor thin and where it separated was oil soaked, not a clean cut like other places where the RTV and block separated. Pretty good indication of how soon the RTV starts to get caught in the oil pickup screen. Also, a smaller size red piece. Solution for this coming soon! |
| The Following 5 Users Say Thank You to KillerBMotorsport For This Useful Post: | Lonewolf (10-29-2022), OkieSnuffBox (10-28-2022), Petah78 (10-29-2022), PNW Shaggy (10-27-2022), Wally86 (10-28-2022) |
#51 |
Drives: 2022 BRZ sport-tech
Thanks again for the info. Very excited about the "solution" when it's made available.
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ Current: 22 BRZ, 00 S2K - #0220 |
| High Flow Oil Pickup by Killer B Motorsport | KillerBMotorsport | Engine, Exhaust, Bolt-Ons | 4 | 04-26-2022 09:51 AM |
| If you post a dyno plot, please, include what the fuel was used. | Calum | Forced Induction | 1 | 10-12-2015 06:59 PM |
| Plot your oil pressure vs temperature | Gords_zenith | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 1 | 04-22-2014 06:09 PM |
