Old 10-12-2015, 03:36 PM   #1
Calum
That Guy
Drives: 2013 asphalt FRS MT
If you post a dyno plot, please, include what the fuel was used.
I'm tired of asking every time a dyno is posted. The results are absolutely useless without knowing what kind of fuel was used. A baseline helps a lot as well, but of course that's not always possible.
The Following User Says Thank You to Calum For This Useful Post:
Freeman (10-18-2015)
Old 10-12-2015, 06:59 PM   #2
FRS Johnny
FRS Johnny's Avatar
Drives: 2013 FR-S Whiteout MT
It should be common practice to include as much detail about the setup as possible too. Theres so many variables and every car is a bit different!
When in doubt, throttle out!
FRS Johnny is offline   Reply With Quote
MXP Equal Length Header and Dyno (updated fitment with skid plate, second post) Fofofawcett Engine, Exhaust, Transmission 28 09-08-2016 02:35 AM
- 86FLY - Australian Custom Turbo Jetkit 4.0 Build + Custom Flex Fuel Dyno Tune aaronsadventures Member's Car Journals 6 12-04-2014 02:01 AM
Plot your oil pressure vs temperature Gords_zenith Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 04-22-2014 06:09 PM
Nitrous set up? Though I seen a post with dyno results. 20valvewynn83 Forced Induction 19 02-04-2014 12:06 PM
POST UP YOUR DYNO FIGS!![Nat. Asp]DYNO Figures (BEFORE and AFTER) stevo_12v Engine, Exhaust, Transmission 10 12-19-2013 02:02 PM
