Old 07-07-2022, 07:57 AM   #1
Raven_frs303
Raven_frs303's Avatar
Drives: 2014 scion fr-s
Brz Blowing Smoke
Hey guys, so a buddy of mine has a 2019 brz with approximately 20k miles on it it has a full cat-less exhaust and is tuned using oft stage 2 (93 octane). He’s the first owner bought it off the lot. and right at about 17k i had noticed his car was blowing a little bit of white smoke (sometimes blue tint to it) and we had blown it off just as condensation but now at around 20k it has gotten a lot worse, Clouds of white smoke on startups both cold and hot and blue smoke sometimes while driving. We had preformed a head gasket test and it seemed fine and he’s been checking up on all his fluids and it doesn’t even seem like it’s burning anything… i’ll include a link to a video of the startup here vvvv
https://youtube.com/shorts/aVd1lEe0q5w?feature=share
I’m pretty lost as to what it is, you would assume head gasket issues but the oil and coolant aren’t mixing and no fluids are being lost but it’s pretty smokey?
Raven_frs303 is offline   Reply With Quote
Old 07-07-2022, 08:18 AM   #2
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
https://www.ft86club.com/forums/showthread.php?t=105851
Blue Smoke = burning oil
Thick White Smoke = burning coolant
Some white smoke = vapor
Black smoke = too much fuel
spcmafia is online now   Reply With Quote
Old 07-07-2022, 09:28 AM   #3
Raven_frs303
yea i know the typical white cloudy is coolant and blue is oil but his fluid levels have stayed the same for the past few months and it’s still pouring out smoke
Old 07-07-2022, 09:42 AM   #4
spcmafia
spcmafia's Avatar
Check the replies on the posted thread link. Steve99 has some good answers when it comes to tuning and problems related to it.
Old 07-07-2022, 11:16 AM   #5
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Quick and easy thing to do is log the car with OFT and upload it to datazap.me and post the link here. Follow the logging steps in the link in the signature line of user steve99 in the link spcmafia posted. No guarantees' but we may see something there. Log the following:
Engine Speed (rpm)
Throttle (percent)
MAF Voltage (volts)
Engine Load (g/rev)
Ignition Advance / Total Timing (degrees)
AFR
Commanded AFR
LTFT (percent)
Oil Temp (F)
CL/OL / Fuel Sys Status (2 = CL, 4 = OL)
IAM / Ignition Advance Multiplier
Knock Correction (degrees)
Old 07-07-2022, 08:30 PM   #6
norcalpb
norcalpb's Avatar
Is he measuring coolant through the fill neck or only using the reservoir?
Old 07-08-2022, 08:57 AM   #7
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Maybe pull the pvc hose off the intake. See if there is excessive oil in the hose. Same for the valve cover vents.
headgasket
AC Blowing Hot Air on everything but LO pooyab Issues | Warranty | Recalls / TSB 13 12-31-2024 08:06 PM
AC not blowing any cold air highway7 Issues | Warranty | Recalls / TSB 33 12-10-2021 09:58 PM
Air blowing out of vents with AC/fan off??? StraightOuttaCanadaEh Issues | Warranty | Recalls / TSB 16 07-11-2017 09:57 PM
How cold is your a/c blowing? jermyzy Issues | Warranty | Recalls / TSB 68 08-18-2013 03:29 PM
Supra Blowing Up radroach Off-Topic Lounge [WARNING: NO POLITICS] 2 07-21-2013 09:14 PM
