Old 07-11-2017, 12:05 AM   #1
StraightOuttaCanadaEh
Wes
Air blowing out of vents with AC/fan off???
Any of you have this problem? I don't know if this is simply a refinement issue (or lack thereof) that comes with owning a Toyota, but what the hell? My fan speed is set to zero, yet at highway speeds (and any speeds actually, but the rate of air blowing out is definitely proportional to speed) the vents will blow at pretty much a "1" fan level. Whatever I have the temperature set to, is what will come out. It's really annoying cause if I direct it at the windshield, it'll start fogging up. If it's at me, then I'm getting unwelcome exhaust gases from the outside. Seemingly the only way to prevent it from happening is to push the "circulate air inside the cabin" button, but does that use any power with the other two knobs off? I'm not sure if this is normal or experienced in any other cars, but I've never seen it before, and it's a stupid ass problem to have.
Old 07-11-2017, 12:08 AM   #2
Silver Supra
Hombre
Silver Supra's Avatar
Drives: 1994 Supra Turbo
Yes - they use outside air if not on recirculate. Fan should not be on. Windows closed should reduce it some or put it on recirc or close the vents. I have never had a car that did not do this.
Silver Supra is offline   Reply With Quote
Old 07-11-2017, 12:11 AM   #3
Wes
Weird. My Mini cooper didn't do this
Old 07-11-2017, 12:57 AM   #4
Brayden_23
Drives: Asphalt 2015 FRS
Change the setting to blow at your feet and you won't notice it anymore
Brayden_23 is offline   Reply With Quote
Old 07-11-2017, 07:42 AM   #5
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Push the recirc button and it won't blow air.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 07-11-2017, 10:03 AM   #6
ikuGANO
ikuGANO's Avatar
Drives: 2016
Greetings my fellow Torontonian, refer to the picture, the red circled area.
(picture stolen off of google)
ikuGANO is offline   Reply With Quote
Old 07-11-2017, 10:08 AM   #7
SLVRSRFR
Drives: 2013 BRZ 6MT, 2007 WRX Wagon 5MT
Every car I've ever had still allowed some air to pass through the vents, even with the system completely off. This is totally normal.
Switch to the foot vents, or simply shut the top vents manually if it is bothering you that bad.
@bpennerz
SLVRSRFR is offline   Reply With Quote
Old 07-11-2017, 10:15 AM   #8
RFB
RFB's Avatar
Drives: FRS
Perfectly normal.
The air conditioner is activated always (AS IN WINTER) when the defog is selected.
Also normal. Or should I say abnormal ?
RFB is offline   Reply With Quote
Old 07-11-2017, 10:56 AM   #9
nico_rsx
Drives: BRZ 2017 Pure Red, MT
Yes it's normal. The outside air intake is in a high pressure zone when your driving, so air is beeing forced inside, even with the fan not running.
On my previous car (acura RSX), it was like twice as much air as the BRZ. I would basically drive half the time with the fan off, because the air getting inside was sufficient.
Putting it in recirc would solve this, but it's not a bad thing to have a bit of fresh air getting inside. Without fresh air, on long drive, the CO2 level will rise, and can cause headhache and get you tired.
nico_rsx is offline   Reply With Quote
Old 07-11-2017, 12:05 PM   #10
Wes
Alright thanks everyone
Old 07-11-2017, 01:03 PM   #11
humfrz
.......and let all that good pot smoke out .......
humfrz
Old 07-11-2017, 02:39 PM   #12
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Set the HVAC control to dash vents-only, and simply shut the vents.
venturaII is offline   Reply With Quote
Old 07-11-2017, 03:57 PM   #13
nico_rsx
humfrz
Haha! I'm imagining the old black cadillac with tinted windows with the smoke coming out when the door open
Old 07-11-2017, 04:33 PM   #14
SLVRSRFR
humfrz
YOU BROKE THE 'BOX!!!
@bpennerz
TRADE: Indianapolis area, BRZ DGM fender vents for FR-S asphalt vents Evil Minion Exterior Parts (Aero, Lighting, Etc.) 1 05-10-2015 06:52 PM
Vis Racing CF fender vents & Oem vents albertnamo Exterior Parts (Aero, Lighting, Etc.) 11 08-15-2014 10:00 AM
Is this normal - Hot air blowing in through vents? Lebby83 BRZ First-Gen (2012+) — General Topics 23 05-19-2014 07:58 PM
Want to trade my BRZ fender vents for you FRS fender vents, or buy FRS vents outright ill roller Exterior Parts (Aero, Lighting, Etc.) 6 09-22-2013 10:49 PM
Did the issue with the air vents blowing hot ever get resolved? fiveoneoh Scion FR-S / Toyota 86 GT86 General Forum 25 09-05-2012 01:21 AM
