Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 04-21-2022, 07:48 AM   #29
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Originally Posted by KillerBMotorsport View Post
Max temp was 205° in the sump and it kept getting cooler after each pull. The opposite of what is typical, but it was a cooler day and we do have 30hp worth of wind tunnel blowers.
I'll likely plug in the oil temp/pressure during another test this summer when it's hot and humid. That that doesn't bring higher temps, I'd cut out a few of the blowers.
This is to the benefit of the cooler that comes from factory, which is a great piece honestly. For the 99% DD'ers out there, this should be plenty sufficient for keeping temps in check. And based on your data, these temps provide a good oil pressure.
Dzmitry is offline   Reply With Quote
Old 04-21-2022, 09:29 AM   #30
KillerBMotorsport
KillerBMotorsport's Avatar
Originally Posted by Tokay444 View Post
Ok, but why? Or is it a matter of, "This is how it's always been done" dogma?
It's not dogma if the standard is knowing the temperature of the oil going into the engine.
As soon as you measure temps after the oil pump, filter, bearings, etc... it has been influenced. You might say, 'but I want to know if component X, Y, or Z, is too hot or, going you fail? Which when done correctly has pressure and temp sensors on every bearing where it's possible, and that is done on engine dynos with engine development phases, but is hugely impractical on a vehicle that gets drive. The other side of that, is you'd have data and nothing to compare it to for understanding if it's normal or out of range.
If you want THAT kind of data for engine health feedback, be familiar with the materials that are in your engine and have an oil analysis done (at intervals that are appropriate for your application) to see when something starts to prematurely wear, or has worn excessively.
KillerBMotorsport is offline   Reply With Quote
Old 04-21-2022, 09:56 AM   #31
Tokay444
I'm not saying there's no merit to knowing the temp going in, but having another data point can give you a vector, which is to your advantage.
Old 04-21-2022, 03:50 PM   #32
KillerBMotorsport
But you can't have a vector without a starting point, which you don't have, no one else has, and it's one data point out of dozens.
You'd still be better off sending out oil samples where there's LOTS of data points and history to compare to.
Old 04-25-2022, 10:43 AM   #33
KillerBMotorsport
Here's another point of reference. These have been on for an auto-X event as well as some aggressive mtn road driving in 90° temps. While these are stickers and not a lab rated sensor, they do work quite well. Hottest indicated dash temp was ~230°. I put one on the sump too and will monitor.
The Following User Says Thank You to KillerBMotorsport For This Useful Post:
Dzmitry (04-26-2022)
Old 05-06-2022, 12:08 PM   #34
SockMonkey
Drives: '13 BRZ Limited
Dang, that IS a heartbreaker dyno! I got you added to the list, officially #30. You are the first one I've found under 200whp! Dropped the average just below 215, haha.
I'm going through the list now trying to add dyno manufacturers, I'll make a post once I have as many as I can find.
https://docs.google.com/spreadsheets...JJI/edit#gid=0
SockMonkey is offline   Reply With Quote
Old 05-10-2022, 10:31 AM   #35
KillerBMotorsport
Yes, it is. Knowing that, I was expecting ~185, but was pleasantly surprised
Old 07-07-2022, 05:21 PM   #36
KillerBMotorsport
Here's another filter pic after a 1,200 mile road trip to Wicked Big Meet in CT. A lot of stop-n-go traffic, where you might expect underhood temps to influence oil temps...
The Following 2 Users Say Thank You to KillerBMotorsport For This Useful Post:
ballsdeep (07-08-2022), Petah78 (07-07-2022)
Old 07-08-2022, 12:50 AM   #37
mike2100
mike2100's Avatar
Drives: 23 BRZ
What's your conclusion?
I can't see the picture to formulate my own, unfortunately.
mike2100 is offline   Reply With Quote
Old 07-08-2022, 07:57 AM   #38
Petah78
Drives: 2022 BRZ sport-tech
Do you have any data on track oil temps/pressures data yet?
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ
Current: 22 BRZ, 00 S2K - #0220
Petah78 is offline   Reply With Quote
Old 07-08-2022, 07:59 AM   #39
Petah78
During his road trip, oil temps never exceeded 210F even in a lot of stop and go traffic. As per the temp sensitive stickers that was applied onto the oil filter.
Old 07-08-2022, 10:08 AM   #40
KillerBMotorsport
Don't waste money on an oil cooler if you never, or occasionally, track your car.
Old 07-08-2022, 10:16 AM   #41
KillerBMotorsport
Just from Auto-X, which can sometimes be worse than a road coarse as you're in staging a lot and the speeds are so low the cooling system never really catches a break.
Old 07-08-2022, 11:50 AM   #42
Petah78
So do you have any conclusion if the FA24 have the same low pressure issues as the FA20 at high oil temps?
Thanks.
High Flow Oil Pickup by Killer B Motorsport KillerBMotorsport Engine, Exhaust, Bolt-Ons 4 04-26-2022 09:51 AM
If you post a dyno plot, please, include what the fuel was used. Calum Forced Induction 1 10-12-2015 06:59 PM
Plot your oil pressure vs temperature Gords_zenith Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 04-22-2014 06:09 PM
