Old 07-02-2022, 05:17 PM   #1
Yellow17BRZ
Drives: Series Yellow 2017 Subaru BRZ
Intermittent rattle
There is a intermittent rattle that is coming from my BRZ. At first I thought it was the alternator pulley, so I replaced the that, along with 1 tensioner pulley, 3 idler pulleys. Name:  A630DEFC-77D7-4EDE-A28C-63A0EC4808BA.png
Size:  107.8 KB , everything that’s circled blue and red I’ve replaced. There’s also i video i attached, the thing is I can hear it more clear underneath the car.
Yellow17BRZ is offline   Reply With Quote
Old 07-02-2022, 05:19 PM   #2
Yellow17BRZ
https://youtube.com/shorts/nWXu-scsHAg?feature=share
Old 07-03-2022, 12:58 PM   #3
Jdmjunkie
Drives: Scion FR-S 10 Series
Mine sounds similar, does it come and go with turning the a/c on and off?
Jdmjunkie is offline   Reply With Quote
Old 07-03-2022, 01:12 PM   #4
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Probably the alternator itself, that grinding is muted enough that I'd assume it's internal to something (not a pulley bearing) but who knows
Old 07-03-2022, 04:17 PM   #5
Interesting one. More rattle than grind. Have you listened from underneath? Auto, or manual?
Old 07-03-2022, 10:35 PM   #6
Maybe the water pump is going bad.
I suggest you use the old long screwdriver to the ear to see if you can isolate where the sound is coming from.
Old 07-03-2022, 10:41 PM   #7
I thought about that but, man, if that sound was the water pump, I imagine it would be pissing coolant.
Old 07-08-2022, 01:29 PM   #8
pvpman22
Drives: 2017 Series.Yellow BRZ
One of my family members made the original post about the issue I'm having.
Few Clarifications:
-Replaced the alternator with another used alternator from Ebay
-Replaced Belt
-Replaced 2 Smooth Idler Pulleys
-Replaced 1 Grooved Idler Pulley
-Replaced Tensioner
-Manual Transmission for the 2017 Series Yellow BRZ
I find that the rattle comes one after the car warms up after a cold start. Also, it's more obvious when the AC compressor clutch engages, but I found any large electrical load brings the rattle back (Ex: I turned off AC but then turned on seat heaters and defrosters and rattle came back).
I usually can only hear the rattle that comes and goes while idle sitting at a light.
I was going to try to track down where the noise is the loudest using a Mechanic's Stethoscope and possibly going underneath and removing the shield and seeing if I can find anything rattling around...
Last edited by pvpman22; 07-08-2022 at 01:29 PM. Reason: forgot to add manual transmission
pvpman22 is offline   Reply With Quote
Old 07-08-2022, 02:24 PM   #9
Does it go away when pushing the clutch?
Old 07-19-2022, 05:50 PM   #10
JohnH
Professional wrench
Drives: 2020 BRZ ST RS
pull the belt and run it for a few seconds like that. Then you will know if its from something belt driven, or something in the clutch, timing chain, valve train or other stuff
2020 BRZ Sport Tech RS World Rally Blue
'18 TS Suspension, camber bolts, align.
Gruppe-S UEL header/overpipe
Wayne Rom Stg 2+ tune
225/45VR17 RT660s
JohnH is offline   Reply With Quote
Old 08-03-2022, 09:41 PM   #11
jeepmor
Drives: 84 CJ7, 08 Duramax, 2014 FRS
Sounds like the alternator. You turn on AC, noise. AC off, no noise. Seat heaters and defrost, noise. Only way a seat heater and defrost would cause issues is a change of load in the alternator. AC would use more juice as well running the magnetic latch for the compressor, and your fan.
Especially since you've changed so much already. Could be bearing in the alternator starting to go and making noise when it's experiencing higher loads. Subi alternators are known to be one of their more frequently replaced parts over the life of the car.
My 01 Outback broke alternator bolts three times, but never made any noises.
jeepmor is offline   Reply With Quote
Old 10-03-2022, 01:34 PM   #12
pvpman22
So to give an update:
I was hoping it would get worse but somehow after a few weeks of my post the noise went away and has remained mysteriously gone. Maybe those components I replaced made a difference eventually? I don't know seems weird maybe it'll come back in a few months.
This experience did make me an expert at getting the accessory belt/pulleys on and off so guess I got something out of it.
Intermittent engine 'rattle' when accelerating mjfulk Issues | Warranty | Recalls / TSB 27 07-13-2023 12:52 AM
Intermittent will not start 333Matt Issues | Warranty | Recalls / TSB 11 10-24-2019 08:03 PM
Flashing and Intermittent CEL - HELP MugsBRZ Issues | Warranty | Recalls / TSB 7 10-19-2016 11:56 AM
Intermittent Over Heating Deep Six Issues | Warranty | Recalls / TSB 6 12-16-2014 09:22 AM
Acceleration Lag - Intermittent donnyk CANADA 6 07-17-2013 11:53 PM
