Old 06-29-2022, 09:48 AM   #1
nerve86
Drives: ZA1JA03N
Overrun fuel cut - ecutek How to disable it?
How to disable Overrun fuel cut using ecutek custom map?
nerve86 is offline   Reply With Quote
Old 07-02-2022, 07:40 PM   #2
steve99
Drives: FT86
you dont need custom map
the stock table can effectivly disable overun fuel cut
go to ecutek maps
select folder Fueling then Overun
open the Overun cutoff table
This table shows the rpm at different coolant temps where the ecu re-enables fueling
so if its got 1300 rpm means the ecu on overun stops fueling till rpm goes below 1300
so if you make those numbers big like 4000 it will fuel on overun to 4000.
note you will increase fuel consumption
as overun fueling is not an input to custom map it not easy to do in custom map
Old 07-04-2022, 11:10 AM   #3
nerve86
Drives: ZA1JA03N
go to ecutek maps
Thanks, am I doing this right? Can I customize the overrun fuel cutoff like this?
Old 07-05-2022, 05:52 AM   #4
steve99
Drives: FT86
Attachment 213266
you dont need the custom map it will likely cause weird issues with idle when the ecu transitions from overun to idle mode you ill likely over fuel it if you use the custom map.
all you need to do is change the standard overun fuel resume table, maybe dont male it 7000, 4000 is likey enough, assume your just trying to create some pops and bangs ?
you can do that with just ignition retard in base timing at low loads
E85 Overrun Pops & Fire on NA erebuswarrior Software Tuning 33 02-25-2023 07:32 PM
2018 BRZ - Window Overrun While Rolling Up TurboLag23 Issues | Warranty | Recalls / TSB 8 05-22-2020 08:35 PM
Ecutek Overrun, Retard ign, flames. Phoenix_gts86 Software Tuning 3 04-05-2020 04:17 PM
Can Ecutek disable diagnostic codes? Kiske Software Tuning 3 05-16-2015 04:05 AM
ECUtek Flex Fuel REVOLUTION: World's First Flex Fuel Factory ECU GTR - BRZ soon! Visconti Engine, Exhaust, Transmission 356 05-20-2013 09:36 AM
