Old 05-21-2020, 02:03 PM   #1
TurboLag23
TurboLag23's Avatar
Drives: 2018 BRZ w/Performance Package
2018 BRZ - Window Overrun While Rolling Up
Hey all!
I have been having this issue for over a year now - finally going to try to address it.
When I roll up my driver’s side window completely, or when the window closes after the door is shut, the window appears to overrun by maybe 1-2mm. Once the motor stops actuating, the window then descends 1-2mm and makes a creaking noise. I took a video that I hope illustrates the issue, link here:
Observe the text in the lower rear corner of the window descending when the window creaks in the interior shot. Exterior shot also shows the window descending.
Additional info 1: I can feel a slight vibration coinciding to the creaking noise in the outside door skin, towards the top and back of the door. Additionally, the rear appears to be overrunning more than the front
Additional info 2: the window appears to have some play in it - I can move the glass maybe 3-4mm within its plane when the door is open. Is this normal, or could this be a root-cause?
Additional info 3: I attempted to reset the window regulators by holding the window switches per instruction in other threads, to no avail.
Thanks all in advance!
TurboLag23 is offline   Reply With Quote
Old 05-21-2020, 02:21 PM   #2
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
If you pop the panel off, there are some window adjustment bolts that you can play with. It seems like one side of the window is adjusted too far up and is pushing up into the weatherstripping.
BigTuna is offline   Reply With Quote
Old 05-21-2020, 04:09 PM   #3
humfrz
Originally Posted by TurboLag23 View Post
Hey all!
Ya know, TurboLag23, my window does that same sort of thing. What did I do about it? Nothing. Water doesn't leak in and it doesn't whistle when I'm driving, so why fret over it -
If the sound bothers you, you might consider putting a bit of silicone on the weather stripping so you don't hear it squeak.
Old 05-21-2020, 05:58 PM   #4
TurboLag23
TurboLag23's Avatar
Oh it’s about 85% OCD, 15% fear of components breaking in the long-term. The thing is clearly not working exactly right, but I am most of the problem
But yes - no water intrusion for me either which is good.
Old 05-21-2020, 08:12 PM   #5
humfrz
OK, try this on your OCD (maybe OCPD?).
I figure that little reversing sound is the window mechanism telling me that it has rolled the window all the way up and it backed off just a smidgen to relieve any pressure or stress on the glass, so it's less likely to crack.
Works for me -
Old 05-21-2020, 09:55 PM   #6
p1l0t
p1l0t's Avatar
Better than COPD!
Old 05-22-2020, 08:55 AM   #7
ZDan
ZDan's Avatar
Drives: '23 BRZ
Mine does this too, which didn't bother me, but now I have a slight whistling sound at speed. I wonder if over-closing has prematurely worn out the weatherstripping...
Old 05-22-2020, 11:14 AM   #8
TurboLag23
TurboLag23's Avatar
Thanks all for the replies! I have ordered black interior door latches online that should arrive soon. Once they get here, I'll remove the door card, assess, & correct as necessary. I've been wanting those black latches for awhile, and the door card already being off is as good of an excuse as I need. I will try to document root-cause and any fixes as well as I can, then update this thread with my findings!
Old 05-22-2020, 08:35 PM   #9
randomthoughts
Drives: 2014 White BRZ
Hey all!
Have you tired the window reset procedure?
randomthoughts is offline   Reply With Quote
E85 Overrun Pops & Fire on NA erebuswarrior Software Tuning 33 02-25-2023 07:32 PM
Ecutek Overrun, Retard ign, flames. Phoenix_gts86 Software Tuning 3 04-05-2020 04:17 PM
Window Shatter / Fracture - passenger small triangular window btune Issues | Warranty | Recalls / TSB 5 12-25-2016 02:14 PM
Drivers window grabbing window seal and pushing it up. stockysnail Issues | Warranty | Recalls / TSB 22 12-22-2015 01:08 PM
Window rolling up/down in rain nickmerronesucks Issues | Warranty | Recalls / TSB 27 05-07-2014 02:51 AM
