Drives: 86
Car/relevant mods
Edelbrock supercharged FRS Delicious tuning flex fuel and dbox DW fuel pump/injectors 2017 stability control module swapped Symptoms: Right as I pulled into a parking lot from a casual drive the car died -all electronics cut out entirely as if the battery was disconnected and engine stalled. From there the car struggled to start, although when started would run normally until the electronics cut again seemingly randomly at which point it would stall. After the first stall the power steering was gone and the power steering light was on the dash. Didn't matter how many times I started the car after the electronics died and the car stalled, nor how long it was running between stalls -power steering remained dead (aka steering was quite heavy). What I found: Limped the car home just a few miles and found the positive battery terminal cover had melted. There are two sets of cables connected to the positive terminal harness, and the cables on the right began to melt the insultation around them. One of those was the wiring for the water pump for the s/c heat exchanger. I checked both the fuse and the relay for the edelbrock water pump and neither looked distressed. I checked the fuse boxes in the engine bay and also under the dash and no fuses looked dark or burnt (although I didn't pull any fuses). Pictures in the folder below, let me know if you want others: https://drive.google.com/drive/folde...2A3fa1LHzdQDwZ I'm an electrical noob and don't know what to look for next. Help. Thanks in advance! |
#2 |
Simply Forgotus
Drives: 2014 Supercharged SSM BRZ Limited
Is the melted wire the one that goes to the Edlebrock pump? Is this a new install or has it been installed and working for a while?
Wires will melt if the current being drawn thru them exceeds their capacity, fuses usually prevent this but they have to be in between the problem load (pump or short somewhere) and the source (battery). This excess load is killing your battery. I wouldn't drive this until you figure it out, there's a real danger of an electrical fire from the looks of that melted wire. Last edited by BirdTRD; 06-30-2022 at 09:37 PM. Reason: sp. |
#3 |
Simply Forgotus
A poor electrical connection (at that crimp or the lug) will also generate that kind of heat and would not blow the fuse down line.
| The Following User Says Thank You to BirdTRD For This Useful Post: | soundman98 (07-01-2022) |
#4 | |
Drives: 86
The wire that goes to the edelbrock pump is on that same nut, but I can't determine if it or the OEM wire underneath of it was the source of the heat as they both show fairly equal signs of heat fatigue. There is a fuse directly on the edelbrock wire slightly upstream (maybe 6-8 inches). I checked that fuse and it's good. Would that nut slowly getting loose cause this type of heat? Unsure if it was loose, but I suppose it's possible. After limping the car home I disconnected the negative battery terminal and haven't driven it since. Not sure what to diagnose next. If anyone needs me to post more pics let me know what you want to see and I'll post them. Thanks again for the help! |
#5 |
Drives: 2016 Scion FRS Release Series 2#439
Perhaps a long shot but I once had an intermittent power issue (88 Mustang GT).
Car cold started and worked fine but later would not hot start. Battery completely dead it seemed. Eventually I discovered that a battery post had come loose inside the battery. I could ever so slightly wiggle it about. Replacing the damaged battery solved my issue. Good Luck!
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS-V/EvoX Brembos Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms 235F/245R Conti ECS on TRD/Enkei wheels (street), 245/40 sq. ECF on 17x8 720Form GTF2 wheels (track) |
| The Following User Says Thank You to Muskoka800 For This Useful Post: | jcw99 (07-02-2022) |
#6 | |
Drives: 86
Keep suggestions coming, I'm stumped. |
#7 |
Simply Forgotus
Check the fuse in the Edlebrock pump harness to make sure someone didn't stick the wrong fuse in there, should be 7.5A.
Are the wires melted anywhere else besides the end? Check the crimp on both lugs going to that post (Edlebrock and OEM) make sure they are solid, a loose connection would generate the heat in that spot. When current is opposed (resistance), the result is heat. Loose connection = high(er) resistance = heat. If you have the tools, I would even go as far as to re-crimp a new lug on the Edlebrock harness to ensure it's good. Visually inspect the wiring harness going from that terminal to the Edlebrock fuse and the OEM wire feeding the fuse box. If something rubbed thru prior to the fuses/fuse box and was intermittently grounding out, that could do it. If you have a multi meter, with the battery disconnected, meter set to measure resistance, connect one lead to a good chassis ground and the other lead to the nut on the fuse block that connects to the + side battery post and start wiggling and poking the wire harness(s) (Edlebrock and OEM to fuse box) and see if the resistance jumps around. Should be 0 ohms and stay there, or very close to 0. If it jumps around, you have a short somewhere in that harness. Electrical problems are challenging, even when you're hands on, nearly impossible over the internet. You might end up having to take it somewhere. |
| The Following User Says Thank You to BirdTRD For This Useful Post: | jcw99 (07-02-2022) |
#8 |
Drives: car
Could definitely be from a poor connection to the terminal, you get a voltage drop as load increases, requires more amps increase to make up for it, heat increases, and then your wires start to melt and the power steering fuse pops.
The way you have the wire connected, it might not be perfectly flush. Make sure you don't have any washers on the connector. Though surprising that it would melt like that , if its only a 7.5A fuse, then might be something else like a short. |
#9 | ||
Drives: 86
The contact points for the OEM/edelbrock eye bolts are toasty and have plastic left over from where they melted the harness piece that connects to the positive terminal. I'll definitely need to replace the harness thing on the positive terminal -but I'm hoping to identify a root cause before swapping stuff and attempting to run the car again. I don't have a multi-meter nor experience with them but I can get one and work on wiggling things to see what happens. I'd happily take my car somewhere I could trust, but I'm not aware of anyone local.... Dealerships would no doubt balk at the amount of mods (nor do I trust them), and I'm not familiar with any mod friendly shops in the area. Anyone know any good shops in NE ohio? I've always been quite savvy and done all of my own work, going as far as building motors in other platforms etc.... but I'm not versed in troubleshooting electric gremlins. FYI I added more photos to the folder specific to the question you asked. Quote:
Unrelated but does anyone know where the power steering fuse is? Thanks again for the suggestions, appreciate everyone's help |
#10 |
Simply Forgotus
Yeah, that all looks like it is localized to that post and nut. Maybe it was slightly loose, generating enough heat to start melting the block which made it even more loose and more heat.
Replace that block, the Edlebrock terminal, (OEM one may be OK but that's your call) Clean all of the contact surfaces and tighten everything back down. Start the car and monitor the temp of that connector with your finger or a temp gun if you have one, it should not get hot at all. |
#11 |
ProCrastinationConsultant
looks to me like a loose connection. it didn't blow the fuse, which rules out a failed device. 7.5A is much lower than the wire should be rated for, so a loose ground issue would result in a blown fuse, not a melted wire.
the fuse is near the battery, and protected by the plastic loom-- the only thing that could result in a melted terminal is if the wire was physically pierced/damaged in the section between the battery and the fuse. the fuse proximity also rules out the wire accidently powering something else that lost power--if something else shorted the wire, it would blow the fuse. as i said first, all indications to me appear to be that the connection loosened over time. i don't see a reason to dig into the issue any further than the connection on the battery. i would replace that oem fuse block that everything bolts to that started melting, scotchbrite/sandpaper the ring terminals until they don't show any of the signs of thermal discoloration, or pieces of plastic, and make sure everything is properly tightened down.
#12 |
Once you get your multimeter, I suggest you check the voltage at the battery with the engine running. It should be around 13 volts. If it is much higher, maybe your alternator has gone crazy and pumping too much current to the battery.
![]() PS - The PS fuse is a 10 amp fuse in position # under the dash (at least on my 2013 FRS). I hope you get it figured out. (maybe it's just me, but I can't see your pictures - Google has a very old e-mail (g-mail) for me and no way can I remember the password - yes, I tried 1234, but it ain't THAT old) |
| The Following 2 Users Say Thank You to humfrz For This Useful Post: | jcw99 (07-02-2022), Ultramaroon (07-04-2022) |
#13 |
13-14.5v, depending on electrical load
| The Following User Says Thank You to soundman98 For This Useful Post: | humfrz (07-02-2022) |
#14 |
Drives: 86
Thank you so much for everyone's help. Ordered a new positive terminal fuse block from Toyota and it's scheduled to arrive on Wednesday (although this dealership is notorious for delays on parts). Fingers crossed this is a simple fix!
Either way I'll keep this thread updated. Thank you again! |
| Electric power steering and steering column part info | raspec | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 10-12-2021 05:27 PM |
| Dead battery - OBD-II power and cigarette lighter power? | lapsio | BRZ First-Gen (2012+) — General Topics | 10 | 04-08-2021 08:22 AM |
| Car stalling after extended rest & battery swap | alex87f | Engine, Exhaust, Transmission | 6 | 04-27-2020 10:04 AM |
| Steering Rack Dust Boots Melted. Replacement? | mistople | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 2 | 08-20-2019 12:34 PM |
| WTB Toyota emblem and the red cover for battery | Lverasky | Want-To-Buy Requests | 0 | 07-30-2013 07:52 PM |
