Old 04-23-2020, 09:01 AM   #1
alex87f
Meow
alex87f's Avatar
Drives: GT86 (now sold)
Car stalling after extended rest & battery swap
Hello guys,
It's pretty much all in the title. My car's been stopped since the beginning of the French lockdown about 6 weeks ago, and at the same time, its battery finally died (like dead dead, it's seven years old).
It took me a while to source a new battery with the current conditions, but I finally received one (Varta D47 60Ah) today. The car was without power long enough for certain setting (AC, avg fuel economy) to reset themselves.
I started it up and drove it for about half a mile, and it stalled on me a couple of time, both times with the clutch out, as I was getting to a stop or slowing around a low-speed turn. It also takes a second to find an idle once I lift off the throttle, and the revs dip down to 350-400.
My first thought is to put that down to the ECU having to re-learn a few parameters after having finally started back up, so nothing to worry about.
What are your thoughts?
Best regards,
Alex
alex87f is offline   Reply With Quote
Old 04-23-2020, 09:03 AM   #2
Gloonge
Drives: 2013 frs raven
6 weeks is a long time there's likely bad fuel in it too. But it's likely a combination of both the fuel and ecu.
I would let it idle for a while (10 mins?) and then try to burn out that fuel.
Gloonge is offline   Reply With Quote
Old 04-23-2020, 09:33 AM   #3
Ashikabi
Ashikabi's Avatar
Yeah between the computer learning again and fuel it could cause some hiccups. Can you get a fuel treatment or stabilizer? Seafoam, heet, something along those lines would probably help
Old 04-23-2020, 09:34 AM   #4
Gloonge
That's a great idea.
Old 04-23-2020, 10:22 AM   #5
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Sounds a lot like what my car does with the flex fuel kit when I go from e85 back to gas. Just relearning. Drive for a bit and I bet it goes away.
I doubt your gas is bad enough to do anything. If gas was bad, fuel stabilizers will not fix it. Those have to go in when the gas is good.
alex87f (04-27-2020), sharpsicle (04-23-2020)
Old 04-23-2020, 07:40 PM   #6
soundman98
ProCrastinationConsultant
soundman98's Avatar
fuel does not go bad in 6 weeks... if that was the case, the tank i had in my car since last december would have turned back into a dinosaur!
it's just the car re-learning how to take it's first steps again.
The Following 3 Users Say Thank You to soundman98 For This Useful Post:
alex87f (04-27-2020), DarkPira7e (04-23-2020), Tcoat (04-27-2020)
Old 04-27-2020, 11:04 AM   #7
alex87f
Meow
alex87f's Avatar
I drove it a bit more the next day and it was already better. Still stalled once when braking to a stop (probably the brakes pulling vacuum just when the engine was at its lowest), but I think it'll be just fine.
The Following User Says Thank You to alex87f For This Useful Post:
Tcoat (04-27-2020)
Battery Brace touched Positive Battery terminal, car won't start!! 7m28 Issues | Warranty | Recalls / TSB 21 09-24-2017 01:55 PM
FS: KC Machine lightweight battery mount with Shorai battery and charger toeout Engine, Exhaust, Bolt-Ons 4 04-23-2017 01:07 AM
DIY: how to replace battery for push start keys, and scion to toyota swap 1GiantTurtle DIY (Do-It-Yourself) Guides 2 12-27-2014 01:24 AM
Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package KCMachine Brakes, Suspension, Chassis 111 10-08-2014 09:26 AM
Window switches not working right after battery swap jonbonazza Issues | Warranty | Recalls / TSB 9 01-10-2014 03:50 PM
