Old 06-30-2022, 09:39 AM   #1
MrPanda781
MrPanda781's Avatar
Drives: 2013 Scion FR-S, Raven Black
So I go to turn on the car and this happened….
(https://youtube.com/shorts/UCf5J63M4Do?feature=share)
I’m not too good with electronics. As a matter of fact I’m terrified. Got shocked once as a kid really bad. So anyways, what do you guys think it might be? Thanks for any input.
MrPanda781 is offline   Reply With Quote
Old 06-30-2022, 09:57 AM   #2
Your battery is dead.
That is all.
DarkPira7e (06-30-2022), humfrz (07-02-2022), Ohio Enthusiast (06-30-2022)
Old 06-30-2022, 10:19 AM   #3
MrPanda781
MrPanda781's Avatar
Thank you so much Tcoat. I’ll take the battery to autozone for the swap later today. Thanks again for the quick reply.
The Following User Says Thank You to MrPanda781 For This Useful Post:
Tcoat (06-30-2022)
Old 06-30-2022, 12:52 PM   #4
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Before you buy a new one, investigate why the battery is dead. How old is the battery? Terminals corroded? Was an interior/trunk light on? Did you have an argument with your girlfriend?
Old 06-30-2022, 04:12 PM   #5
MrPanda781
MrPanda781's Avatar
I recently looked into it some more and turned out the starter also went bad. Trying to start the car I guess drained the battery. Good news is a had a starter from when I thought I had bad starter. Now I just need to change the starter for sure. I know it is because I use to wack it with a hammer to start it this past week. Check the terminal and they’re good. Nah. I keep all my interior lights of until I need them. What girlfriend?
“Buy the ticket, take the ride”
humfrz (07-02-2022)
Old 07-01-2022, 09:33 AM   #6
blsfrs
blsfrs's Avatar
Girl friends can be draining. Especially when they argue. Glad you got it (the car) fixed.
Old 07-02-2022, 02:33 AM   #7
Before you bury that starter you might want to have it bench tested.
But like ol @Tcoat said, it sure do sound like a weak battery. Have you had it load tested?
Getting shocked as a kid reminds me of the time my father asked me to hold onto the spark plug wire to the gasoline engine of the grain elevator, as he pulled the rope ..... to see if it was getting spark - yep, that happened .... ONCE!
jcw99 (07-02-2022), soundman98 (07-02-2022)
Turn signal cancelling/turn off issue Koi Issues | Warranty | Recalls / TSB 5 10-18-2020 10:19 PM
Turn as tail timing not matching with the front turn signals NahumCC Cosmetic Modification (Interior/Exterior/Lighting) 1 01-03-2016 10:40 PM
Steering wheel issue---left turn lighter than right turn!!! xingxingtjf Issues | Warranty | Recalls / TSB 12 10-14-2015 06:47 PM
Voice Commands with new turn by turn in IOS6? jadewbj Electronics | Audio | NAV | Infotainment 0 09-21-2012 10:11 AM
