Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 06-29-2022, 06:14 PM   #1
zhanym0981
Drives: 2016 Scion FR-S
Safe to drive with exhaust leak?
My sti shifter went loose and the Subaru dealer snapped one of the bolts of the front pipe when they were trying to access the shifter. Both the front pipe and the bolt are on backorder and there's no dates yet.
They said they can put the original pipe back on while we wait but there would be leaks from the header and resonator. They said it's okay to drive like this except the cars gonna be a bit louder.
Some quick googling said it's not good for the engine and might have bad gases leaking if the car is driven in this condition.
Anyone knows is it actually okay to drive with some leaks? I guess definitely no track days/auto crosses until it's fixed.
I
zhanym0981 is offline   Reply With Quote
Old 06-29-2022, 06:44 PM   #2
Jdmjunkie
Drives: Scion FR-S 10 Series
From a mechanical stand point as long as the leak is after both OČ sensors the engine should run with the problem. You need to drive and see if the noise/fumes are to much for you.
Jdmjunkie is offline   Reply With Quote
Old 06-29-2022, 07:12 PM   #3
otter
Drives: 22 BRZ
It'll be fine just don't spend a lot of time idling and sitting still.
otter is offline   Reply With Quote
Old 06-29-2022, 07:50 PM   #4
zhanym0981
Thanks! I guess if the noise/fumes are okay then nothing I should worry too much about.
Do you think I can attend hpde before it's fixed?
Old 06-29-2022, 07:51 PM   #5
zhanym0981
Thanks! Do you think I should avoid doing hpde until it's fixed or it's fine?
Old 06-29-2022, 08:40 PM   #6
otter
Drives: 22 BRZ
Tough to say. If it's a tiny leak it'll probably be fine but keep in mind an exhaust leak is blowing full temp exhaust out in an unintended direction. HPDE is going to get things really hot and a lot of heat in the wrong direction melts things. It's a personal judgement call but for me I'm not big on tracking a car where things are not setup/working correctly.
The Following 2 Users Say Thank You to otter For This Useful Post:
timurrrr (07-01-2022), Wally86 (06-30-2022)
Old 06-30-2022, 09:57 AM   #7
racingfool
racingfool's Avatar
Drives: Miata
That covers everything I was thinking.
racingfool is offline   Reply With Quote
Old 06-30-2022, 11:43 AM   #8
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
I would get that busted bolt out and stick a smaller non threaded bolt in with some washers and nuts to secure it as a temp solution until the correct hardware arrives.
Old 06-30-2022, 08:39 PM   #9
zhanym0981
Unfortunately according to subaru that bolt is stuck and they tried. Not sure if some local muffler shops can pull some magic...
Old 06-30-2022, 10:17 PM   #10
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Apparently they didn't try very hard...
BirdTRD is offline   Reply With Quote
Old 07-01-2022, 12:07 AM   #11
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
Maybe they should have tried a drill.
The Following User Says Thank You to gen3v8 For This Useful Post:
RToyo86 (07-01-2022)
Old 07-01-2022, 01:01 AM   #12
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
15 minutes of cussing and few new drill bits and a drill. Drill the stud out and then replace it with a bolt, nut and washers. Your not trying to save or extract the remains of the broken stud but simply just drill through it to the other side (which would also remove the broken stud)
They just didn't want the headache and hassle mate.
The Following 2 Users Say Thank You to Kiske For This Useful Post:
RToyo86 (07-01-2022), timurrrr (07-01-2022)
Exhaust Leak help? ray7792 Engine, Exhaust, Transmission 4 07-04-2014 02:08 PM
Lets learn to drive manual! Save my clutch Season 1 calidus BRZ First-Gen (2012+) — General Topics 365 05-28-2014 02:13 PM
Exhaust leak. J8boston8j Engine, Exhaust, Transmission 17 10-15-2013 09:09 PM
State Farm's Drive Safe and Save: Anyone have experience with this plan? b.e Electronics | Audio | NAV | Infotainment 21 03-20-2013 10:54 PM
Exhaust Leak? k33n3r Engine, Exhaust, Transmission 6 08-09-2012 01:59 PM
