| BRZ Second-Gen (2022+) General Topics General topics for the second-gen BRZ |
Drives: 2016 Scion FR-S
Safe to drive with exhaust leak?
My sti shifter went loose and the Subaru dealer snapped one of the bolts of the front pipe when they were trying to access the shifter. Both the front pipe and the bolt are on backorder and there's no dates yet.
They said they can put the original pipe back on while we wait but there would be leaks from the header and resonator. They said it's okay to drive like this except the cars gonna be a bit louder. Some quick googling said it's not good for the engine and might have bad gases leaking if the car is driven in this condition. Anyone knows is it actually okay to drive with some leaks? I guess definitely no track days/auto crosses until it's fixed. ![]() I ![]() Sent from my iPhone using Tapatalk |
#2 |
Drives: Scion FR-S 10 Series
From a mechanical stand point as long as the leak is after both OČ sensors the engine should run with the problem. You need to drive and see if the noise/fumes are to much for you.
#3 |
Drives: 22 BRZ
It'll be fine just don't spend a lot of time idling and sitting still.
#4 | |
Thanks! I guess if the noise/fumes are okay then nothing I should worry too much about. Do you think I can attend hpde before it's fixed? Sent from my iPhone using Tapatalk |
#5 |
#6 |
Drives: 22 BRZ
Tough to say. If it's a tiny leak it'll probably be fine but keep in mind an exhaust leak is blowing full temp exhaust out in an unintended direction. HPDE is going to get things really hot and a lot of heat in the wrong direction melts things. It's a personal judgement call but for me I'm not big on tracking a car where things are not setup/working correctly.
#7 |
Drives: Miata
#8 |
Drives: 17 Asphalt 86
I would get that busted bolt out and stick a smaller non threaded bolt in with some washers and nuts to secure it as a temp solution until the correct hardware arrives.
#9 | |
Unfortunately according to subaru that bolt is stuck and they tried. Not sure if some local muffler shops can pull some magic... Sent from my iPhone using Tapatalk |
#11 |
30 minute maintenance
Drives: My18 wrxsti
Maybe they should have tried a drill.
| The Following User Says Thank You to gen3v8 For This Useful Post: | RToyo86 (07-01-2022) |
#12 | |
Drives: RX-7 / BRZ
They just didn't want the headache and hassle mate.
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
| Exhaust Leak help? | ray7792 | Engine, Exhaust, Transmission | 4 | 07-04-2014 01:08 PM |
| Lets learn to drive manual! Save my clutch Season 1 | calidus | BRZ First-Gen (2012+) General Topics | 365 | 05-28-2014 01:13 PM |
| Exhaust leak. | J8boston8j | Engine, Exhaust, Transmission | 17 | 10-15-2013 08:09 PM |
| State Farm's Drive Safe and Save: Anyone have experience with this plan? | b.e | Electronics | Audio | NAV | Infotainment | 21 | 03-20-2013 09:54 PM |
| Exhaust Leak? | k33n3r | Engine, Exhaust, Transmission | 6 | 08-09-2012 12:59 PM |
