Old 06-29-2022, 07:51 PM   #1
86dood
86dood's Avatar
Drives: Stock, hotlava ,FRS 6mt
Oil cooler kit VS building my own kit
Hey guys! Don't get mad, I know this has been posted but my
Phone is wonky with this site so I can't search threads..
Anyway would it be more cost effective to piece together my own oil cooler kit or buy a premade kit? Would a universal kit work? Thanks ~~~kev
86dood is offline   Reply With Quote
The Following User Says Thank You to 86dood For This Useful Post:
humfrz (06-30-2022)
Old 06-29-2022, 08:33 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Do you have access to build custom AN lines and buy the correct fittings? And build your own mount? Those are really the biggest of the reasons to piece your own together, to customize those things.
Old 06-30-2022, 02:14 AM   #3
First off, I suggest you get a new phone -
Second off, unless you're tracking your car, I don't reckon it needs an oil cooler.
I'll summon ol @Ultramaroon for you - he has an oil cooler but doesn't track his car, nor does he live in a hot climate.
(so, why did he install an oil cooler? - )
Amputechture (07-19-2022)
Old 06-30-2022, 02:19 AM   #4
86TOYO2k17
Drives: 2017 toyota 86
I am now 6 for 6 for building my own setups with zero issues. Pretty simple and easy really. Saves a decent amount of money too.
Old 06-30-2022, 03:18 AM   #5
MrSkubi
MrSkubi's Avatar
Drives: 24 GR Yaris, 23 GR86
Second that. I really wanted JR one but during 2020 it was a shitshow shipping anything from US/UK to Poland so I did my own heavily inspired by JR mounting style but using only Setrab/Aeroquip parts. Can't remember the total cost of the build but it was quite a bit cheaper than buying any kit available locally to me. After getting the Setrab core and doing all the measurements designing mounting solution became a fun little project.
MrSkubi is offline   Reply With Quote
Old 06-30-2022, 08:44 AM   #6
86TOYO2k17
rivnuts, straight brackets, and L brackets. Make mounting oil coolers / trans coolers a breeze.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
MrSkubi (06-30-2022)
Old 06-30-2022, 10:01 AM   #7
Espi
Espi's Avatar
Drives: 17 BRZ
I vote for R&D and tried and true but it's a little costly.
I went with peace of mind and use the HKS cooler. Works great! Highly recommend.
Good luck with your project!
Espi is offline   Reply With Quote
Old 06-30-2022, 11:46 AM   #8
86TOYO2k17
Definitely a nice kit for sure.
But there is nothing special or propriety about it, or any kit.
It’s basically just an oil cooler, some fittings, some hoses, a sandwich plate, and a method for mounting.
Can purchase all that for about 1/3rd the price yourself. Coming up with a mounting solution is also incredibly simple.
Espi (06-30-2022)
Old 06-30-2022, 02:03 PM   #9
CSG Mike
CSG Mike's Avatar
You can always piece together your own kit for less, but what is the value of your own time? Do you already own the necessary equipment to fabricate the parts?
Most folks will go with a pre-made kit that's tried and true, for just plug and play ease. Some folks like to make their own stuff, and will go that way.
If you want a ready to go kit, CSG has many options in stock.
DarkPira7e (06-30-2022)
Old 06-30-2022, 02:29 PM   #10
86TOYO2k17
For an oil cooler you can literally buy all the exact same components used, same setrab cooler mocal thermo plate or whatever brands of your liking. Can literally peice together a replica without the markup.
The only thing remotely “proprietary” is the mounting solution.
With rivnuts, straight brackets, and L brackets you can easily mount the cooler in any fashion you like, almost exactly replicating any other kits or doing it a unique method/location of your liking. No frabrication, R&D etc… does not take much time at all either. If you have the ability to install an oil cooler you can make your own that’ll be just as effective.
You can obviously start adding some complexity with a ducting solution if desired. How you bring air in / vent air out etc.. but most kits solution for this is either little to none, or incredibly easy to replicate. IE just dremel out fog light bezel and installing a vent/screen on fender liner.
MrSkubi (07-01-2022)
Old 06-30-2022, 09:41 PM   #11
Grady
Grady's Avatar
I agree with everyone else here. If you have mechanical fabrication skills and tooling then yes you can put your own setup together with no issues. If not buy a pre made kit it will be less expensive in the long run.
Old 06-30-2022, 11:40 PM   #12
FreeCAD
respect
Old 07-01-2022, 02:31 AM   #13
MrSkubi
MrSkubi's Avatar
FreeCAD
respect
Hah that's it . I never did anything else than 2d vector graphics before but it's quite a friendly software once you start going. Not my preferred one (I did try a few else too) but for such an easy project it wasn't bad and too time consuming.
The Following User Says Thank You to MrSkubi For This Useful Post:
Ultramaroon (07-01-2022)
Building a BRZ in 1/24 Scale Tcoat Off-Topic Lounge [WARNING: NO POLITICS] 63 06-29-2019 09:48 AM
SOLD - RacerX Oil Cooler with Auto Transmission Cooler and Temp Gauge tws98 Engine, Exhaust, Bolt-Ons 0 05-28-2019 10:50 PM
Building my own oil cooler Basket Case Engine, Exhaust, Transmission 13 01-06-2015 09:40 PM
Building my FR-S Gillams Scion FR-S / Toyota 86 GT86 General Forum 5 09-06-2013 12:37 PM
