Old 11-08-2021, 01:25 PM   #29
Butterballz
Drives: Black FRS
Originally Posted by GJR726WY View Post
This thread appears to have puttered out, but I just replaced my spark plugs and coil packs this weekend on my 2013 BRZ using the IP Quad sparks. Car seems to have a pretty large reduction in throttle response and overall power, I am not getting any CELs though, was wondering if anyone else had experienced similar results.
Let me know if you coil packs go bad. I was chasing a strange misfire and after doing a bunch of diagnosis that came back inconclusive, I swapped back to OEM and I think it stopped misfiring. Still need to log once more to confirm, but no CEL after swap.
Did not get any coilpack CELs when it was misfiring. Just misfire CEL on specfic cylinders.
Butterballz is offline   Reply With Quote
Old 11-09-2021, 08:15 AM   #30
GJR726WY
Drives: 2013 Subaru BRZ
A throttle reset appears to have everything mostly back to normal. Thank you guys for the suggestion, I would have never have thought of that.
Now that I have throttle, car runs superbly with new plugs and IP coils. Acceleration is smooth and improved. I am very pleased so far. I also notice quite a noticeable reduction in valvetrain noise. I will post if I have issues with the IP quads, but happy so far here at the start.
GJR726WY is offline   Reply With Quote
The Following 3 Users Say Thank You to GJR726WY For This Useful Post:
bcj (11-09-2021), Brz-123 (11-09-2021), jflogerzi (11-13-2021)
Old 11-13-2021, 10:53 PM   #31
jflogerzi
jflogerzi's Avatar
well this sucks. Was kinda hoping the hood vents would help fix this. So far I have only had the code for the CP on the passenger front one. PITA to replace these. When it goes out I can trigger the code every time at the top of 4th. Normal driving is just fine.
2013 Series 10 FRS #553
Old 02-04-2022, 11:21 AM   #32
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
Well I have a possible CP issue now. The past couple of days I've gotten a flashing CEL when going WOT at highway speeds in 4-6th gear. It'll go out after anywhere from 5-10ish flashes. There's also a little studder/hesitation when I first try to get on it. Yesterday on my way home from work It stayed on. I checked the code when I got home and it's a P0301 (cylinder 1 misfire detected). So I swapped the #1 & 3 CPs to see if I can get the code to move to cylinder 3. I didn't drive the car again until today on my way to work. I was able to get the flashing CEL, but not steady yet. I'l try again on my way home. If that doesn't work, any thoughts on what else it could be?
Details on my car: it's a 2013 FRS, 107K miles, of which 105K have been boosted.
kmbkk is offline   Reply With Quote
The Following User Says Thank You to kmbkk For This Useful Post:
jeepmor (09-08-2022)
Old 02-04-2022, 02:42 PM   #33
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
fuel air spark
I'd guess if it's not spark plugs/coil packs it'd be injectors. Did you replace the plugs at 60k miles?
ineedyourdiddly
Old 02-04-2022, 04:02 PM   #34
acro
Drives: GT-86
I've seen many, MANY IP coil packs get used by folks tired of OEM coil packs going bad at the track. Have yet to see an IP coil pack bite the dust.
Add me as first to the list.
acro is offline   Reply With Quote
Old 02-04-2022, 09:03 PM   #35
CSG Mike
CSG Mike's Avatar
Are you on quad or plasma?
Old 02-04-2022, 09:11 PM   #36
acro
Drives: GT-86
IP-A149401
Old 02-14-2022, 10:38 AM   #37
ROADRACER
Drives: unlimited cheap build N/A track car
Here is a little bit of gold for everyone having coil pack issues. I hate to see all the suffering and money wasted replacing coil pack, especially people thinking they need high dollar ones.
I had been throwing miss fire codes on both banks intermittently for many track days. I would just clear the code and continue. It got progressively worse so I decided to investigate.
The problem is the electrical plug at the coil pack. It is poorly designed and the electrical connection is not great.
I decided to do an experiment and tweeked the male pins on the coil pack with needle nose pliers. I just twisted them 10 degrees or so to preload the connection and put them back on the car. Its been about a year (5 or 6 track day weekends) and I have not had another issue. I hope this works as well for you guys as it did for me.
ROADRACER is offline   Reply With Quote
The Following 6 Users Say Thank You to ROADRACER For This Useful Post:
blsfrs (02-14-2022), Brz-123 (02-14-2022), jeepmor (09-08-2022), jflogerzi (03-05-2022), sato (02-14-2022), Tanstin (03-17-2026)
Old 02-14-2022, 03:45 PM   #38
sato
sato's Avatar
Drives: Dodge Patitas
Can you provide a bit more info regarding the circumstances? Heavy track use, for example?
Pretty nifty trick I'll be trying once I replace my new coils.
sato is offline   Reply With Quote
Old 04-02-2022, 01:51 PM   #39
Aztec
Lost in the twisties
Aztec's Avatar
Drives: 2014 BRZ Dark Gray Metallic
I love this community
I have an Edelbrock SC and just got a P0301
I want to try your trick with the coil pack electrical plug change. Did you take any pics when you tried that?
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft
Aztec's Build Thread
Aztec is offline   Reply With Quote
Old 06-23-2022, 02:11 PM   #40
acro
Drives: GT-86
daily driven frs no track days. hot climate. car has hull exhaust and is tuned
Old 06-27-2022, 02:40 AM   #41
jflogerzi
jflogerzi's Avatar
which way did you twist or rotate? Diagram would be super helpful
Old 06-29-2022, 08:18 AM   #42
GrandSport
GrandSport's Avatar
Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
Originally Posted by DarkSunrise View Post
FWIW I’m trying a few different things this year, namely DEI gold wrapping the coil packs and using the Verus fuel rail and DI ecu brackets to allow more airflow across the coil packs. A few people on the forum have tried one or the other and say they help. Too early to know but I’ll report back with the results. Interested to see what other solutions people have.
I have cooling out the arse, vents in my hood, AC delete, foil, etc. My coils still overheat.
2014 BRZ: WRL Build (GP2) MCS, AP, Motec, race wiring harness, blah blah blah
2014 FRS: Similar WRL Build. Back up / parts / practice race car.
2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc.
1999 NB Spec Miata: 1.8 w/ all the goodies.
2022 CT5 Blackwing: Stock.
GrandSport is offline   Reply With Quote
IP Coil Packs bozack Engine, Exhaust, Transmission 6 03-06-2022 01:36 PM
2013 Coil Packs, where did you guys get them from? Keenercarguy Issues | Warranty | Recalls / TSB 24 05-25-2018 08:43 PM
Stock 13/14 coil packs shaynek Want-To-Buy Requests 1 04-26-2018 08:20 AM
Do I have bad coil packs or a failing DI pump? xkalelx Forced Induction 16 03-15-2016 01:56 PM
Vendors/Members, Anyone have coil packs in stock? ZionsWrath Engine, Exhaust, Transmission 3 05-12-2015 02:04 PM
