Old 06-27-2022, 03:39 PM   #1
waterpanda
Melted off exhaust hangers...
Attended HoD's open track day @ NJMP Thunderbolt this past Friday (Jun 24) - met a fellow 86 owner from VA - if you're reading this sup Andrew!
Open track days are awesome - get on and off whenever. Very few accidents during the day as well - overall a great day.
Anywho, after a few sessions, I noticed that the exhaust tip was in contact with the bumper and the left side of pass. exhaust hole was melting. Upon closer inspection, both the exhaust hangers were melted off, and basically the diffuser was holding up the exhaust in place. I take that the exhaust just swung side-to-side during corners and melted off the bumper.
I haven't experienced melting hangers with the previous exhaust setup (Tomei UEL + stock FP + Invidia N1) at the track. I recently installed A350 header + Motiv catted FP + HKS Hi-Power v2 - and a dyno tune from EFI Logics in CT - this was the first event after the component updates.
My leading theory is that the Verus aggressive diffuser (present in previous setup as well) is interfering with airflow that would otherwise would've cooled off the exhaust enough to keep things intact... or is EGT just simply too high and there's a bigger problem I need to look into (logs report CAT1 temps ranging from 690c to 730c)?
What do y'all think?
Thinking of trying out the following:
1. Heat wrap the hangers + exhaust piping near hangers
2. Uninstall diffuser
waterpanda is offline   Reply With Quote
Old 06-27-2022, 03:43 PM   #2
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Who made the hangars? Name brand or china generic?
Old 06-27-2022, 04:08 PM   #3
waterpanda
Perrin exhaust hangers
Old 06-27-2022, 04:21 PM   #4
dragoontwo
dragoontwo's Avatar
Dang.
Old 06-27-2022, 05:43 PM   #5
ACT86
ACT86's Avatar
Drives: English, French, Swedish & Japanese
ACT86 is offline   Reply With Quote
Old 06-27-2022, 10:30 PM   #6
waterpanda
The story keeps building... upon further post-track inspection, the steering rack boot near the overpipe is partially melted on passenger side, no glaring hole from what I can tell but am getting concerned about the exhaust system + temps
Old 06-28-2022, 12:06 AM   #7
Joon525
Joon525's Avatar
Drives: 2016 BRZ
Interesting that this guy had the same problem as well (Verus diffuser too).
https://www.focusrs.org/threads/melt...angers.120646/
Joon525 is offline   Reply With Quote
Old 06-28-2022, 12:21 AM   #8
villainous_frx
Off to the track!
villainous_frx's Avatar
Drives: '14 Lava 86, '13 WRB BRZ
Well that's some unfortunate marketing...
villainous_frx is online now   Reply With Quote
The Following 2 Users Say Thank You to villainous_frx For This Useful Post:
Tcoat (06-28-2022), Ultramaroon (07-01-2022)
Old 06-28-2022, 10:31 AM   #9
ka-t_240
7+ years of tracking the BRZ and 15 years of other platforms, never had an issue like this. I have never bought fancy bushings like that so leads me to think its just poor quality aftermarket stuff. However, I have seen more than a number of melted bumpers on other peoples cars anything from Honda's to a Ford GT.
Have you contact Perrin about the bushing?
ka-t_240 is offline   Reply With Quote
The Following User Says Thank You to ka-t_240 For This Useful Post:
NoHaveMSG (06-28-2022)
Old 06-28-2022, 10:39 AM   #10
Code Monkey
Drives: Subaru BRZ
Re: steering rack boot, you probably have a small leak between the overpipe and the header. This is what happens when the leak becomes bigger.
Code Monkey is offline   Reply With Quote
The Following User Says Thank You to Code Monkey For This Useful Post:
waterpanda (06-28-2022)
Old 06-28-2022, 11:23 AM   #11
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I know of a couple guys with verus diffusers, and a few more like me with different diffusers with no issue of melting anything but the CV boot. I would say it's the hanger itself. Polyurethane has some very specific mix ratio's with the resin and curing agent. I have seen some of my poly parts crumble apart, stick together, or melt in the sun due to resin/cure agent imbalance or moisture in the processing system.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
norcalpb (06-29-2022), waterpanda (06-28-2022)
Old 06-28-2022, 01:04 PM   #12
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I recall Perrin having to re-design their engine mounts because of the poly melting. Hmm
Ohio Enthusiast (06-28-2022)
Old 06-28-2022, 05:20 PM   #13
waterpanda
I left them an email- waiting for response!
OH thank you for sharing! Will need to check for leaks stat
Old 06-28-2022, 08:59 PM   #14
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
I'd definitely get in touch with your tuner. Let him check your logs.
OEM Exhaust hangers nikitopo Engine, Exhaust, Bolt-Ons 0 10-07-2021 11:27 AM
Perrin exhaust with added benefit of melted plastic s30series Engine, Exhaust, Transmission 3 09-12-2014 08:44 PM
Exhaust Hangers FrSnake Engine, Exhaust, Transmission 11 01-20-2014 01:45 PM
exhaust hangers jazztennor Engine, Exhaust, Transmission 7 02-19-2013 09:57 AM
Exhaust hangers yomchi1989 AUSTRALIA 4 12-01-2012 01:15 AM
